535 water pump tool list
ealinn
Post by ealinn »
Gotta round up some tools to go swap out a grenaded water pump on my '87 535is and was wondering if you guys could help me round up a tool list.
Thanks
Bimmerguy2002
Post by Bimmerguy2002 »
-10mm 3/8" socket
-13mm 3/8" socket
-6" extension for 3/8" drive
-3/8" drive ratchet
-screwdrivers or knife for hoses
-32mm or 1 and 1/4" open end wrench
-hammer for fan clutch and fan shroud
-Vise-Grips for pulley if you dont intend to use it
-22mm open end for automatic radiator
-your good looks
DJM1986-5
Post by DJM1986-5 »
add anti-seize to the water pump bolts when you put them back in - observe the torque settings when bolting on the new WP If you use a high quality sealant such as Wurth DP 300, no need to use the paper gasket.
