At what point do you need big brakes on a turbo e28?
Posted: Dec 09, 2007 5:17 PM
by turbodan
It looks like I've got a whole bunch of little hairline cracks in my front brake rotors. Kind've in the middle of the braked portion of the disk, radiating out from the center.
I've been really thinking about some e32 brakes. I guess its like "now" time...
Posted: Dec 09, 2007 5:36 PM
by Tammer in Philly
turbodan wrote:It looks like I've got a whole bunch of little hairline cracks in my front brake rotors. Kind've in the middle of the braked portion of the disk, radiating out from the center.
If they are really short, too shallow to feel, very numerous and not really at the edges of the disks, it's probably okay. It's sometimes called "crazing," and it indicates that you got your rotors really hot. If you are using the brakes hard enough to cause that on the street, then upgrading may be a good idea, just for the greater heat-sink mass of the larger rotors (and the venting in the rear rotors). Ducting is another option, but under most street-driving situations you don't need or necessarily want open ducts. If they look like the ones at this link, you're okay to continue using them.
You clearly have the power to push around a heavier brake setup, so seeing as you're clearly near rotor-replacement time, I'd just do the upgrade.
-tammer
Posted: Dec 09, 2007 6:00 PM
by Skeen
Also, notice the white on the brake pads. This is common on overheated pads and another good indicator of the temps you're getting.
Do any of the cracks go over the top (outer circumference) of the rotor--off the friction surface?
Posted: Dec 09, 2007 8:09 PM
by turbodan
They seem to stop well within the swept area of the rotor. Just looking through the wheel spokes, they seem to be between 1/2" and 3/4" long. Very much like the ones from the link.
I've had these suckers on there since the car was NA, and before that I put about 10k on them with my old white car, so they've dissipated a shit ton of heat in the last two years or so. I'm sure the pads are showing some signs too. I get them real hot a couple times a week. Thursday nights are real rough...
The rear rotors seemed alright, but I didnt look real close. They seemed to have a uniform, finely smeared appearance to them. That seemed odd to me with stock pads. They usually produce a flat, smooth, dull finish.
Posted: Dec 10, 2007 7:05 AM
by Mark 88/M5 Houston
With your reported power and speed capability I'd have already put the E32 brakes on! ;)
Posted: Dec 10, 2007 8:15 AM
by Jeremy
Yea, a turbo system definitely has the capacity to get the stock brakes really hot, really fast. I overheated the stock brakes on the street once when I was naturally aspirated, so bigger brakes got put on the "pre-turbo" to do list.
I haven't gotten any fade with a 750fr/540r setup and Porterfield R4S pads. Don't have any track time with the setup, but they're great on the street.
Posted: Dec 11, 2007 3:04 PM
by sommy
How much money that that setup cost you? ^^
Posted: Dec 11, 2007 8:19 PM
by Ken H.
"At what point do you need big brakes on a turbo E28?"
When you are 200 ft inside the instructor's designated braking point and 20 mph/1500 rpm above his advised speed for entering the turn. :shock:
Posted: Dec 11, 2007 8:54 PM
by Jeremy
sommy wrote:How much money that that setup cost you? ^^
Sorry, I don't recall. It was done a while back. They come up for sale in the FS section here from time to time.
Posted: Dec 12, 2007 10:58 AM
by Tammer in Philly
In general, one can find the 4 calipers from an E32 750i for $300, give or take. Rotors (front from the E32, rear from an E34 540i) aren't much more than standard E28 535i rotors. Pads are much cheaper usually, as they are the same size as the E36 M3 front and rear. This may be the biggest benefit of the upgrade; every pad you could possibly want is made in an E36 M3 fitment and they are widely available.
-tammer
Posted: Dec 12, 2007 12:02 PM
by Skeen
You can do the swap way cheaper than that. Go to a pull-a-part junkyard.
Posted: Dec 12, 2007 1:07 PM
by Tammer in Philly
Skeen wrote:You can do the swap way cheaper than that. Go to a pull-a-part junkyard.
I've not had luck finding the right cars in the pick-'n-pulls here. The "we pull it and you pay" places charge $250-350 for the four calipers. Certainly worth an attempt, though.
-tammer
Posted: Dec 12, 2007 9:25 PM
by Russianblue
if you can find some junkers, go to rock auto and order some remanufactured Cardone units. They are only $41 each for the e32 fronts with a $40 core charge.
Rear 540's are around $60 each with a $50 core.
Wonder if they'd take your e28 brakes as an even swap for the core charge.
Another place you might consider is O'Reilly's. Looks like the prices are the exact same (nearly) there and they sell Cardone rebuilds.
I have HEARD of people who ordered online and got their products delivered and then actually go to the store (offered as an option) to turn in their cores. I am fairly sure they don't really care WHAT kind of core you turn in at the store and frankly i am not sure how they police that, especially for brakes. They'd need a unit to compare it to in order to tell an e28 caliper from that of an e32...or....they'd need to be a BMW expert. I am not advocating it....but you are looking at $250 ish for a fully rebuilt set.
Posted: Dec 12, 2007 10:32 PM
by M. Holtmeier
Russianblue wrote:if you can find some junkers, go to rock auto and order some remanufactured Cardone units. They are only $41 each for the e32 fronts with a $40 core charge.
You'd still need the carriers though right?
Posted: Dec 12, 2007 11:27 PM
by Russianblue
looks like you are right, but luckily the pkg with the carrier is only like $5 more or something.
they've got a crap load of part numbers, combos and all kinda stuff pre loaded with pads etc etc. A lot to sort through but seems like there is a decent value there.
Posted: Dec 13, 2007 12:04 AM
by M. Holtmeier
Russianblue wrote:looks like you are right, but luckily the pkg with the carrier is only like $5 more or something.
That is very cool news!
Posted: Dec 23, 2007 12:20 AM
by Steve Haygood
I have the complete brake setup WITHOUT core charge :)
300 front
400 rears
buy front and rears and get better pricing
includes, reman calipers,new rotors and pads
Posted: Dec 23, 2007 2:13 PM
by M. Holtmeier
Steve Haygood wrote:I have the complete brake setup WITHOUT core charge :)
300 front
400 rears
Interesting. What are the specifics of this setup, i.e., pads, vented rears? How much better pricing for both front/rear?
Posted: Dec 23, 2007 5:07 PM
by turbodan
300 front
400 rears
I was planning on this, but TCD made an offer I couldnt refuse.
If I find that the e34 535i brakes (302x22mm) are still not enough, I'll be in touch about the e32 setup...
Posted: Dec 23, 2007 5:17 PM
by Steve Haygood
the rears are the 540/M5 rears, so yes,vented. Rotors are Brembo, pads are Repco organic. Metal masters are available as well as Mintex at slightly different pricing.
20.00 off on the front and rear set combined if ordered by 12/28/07
Posted: Dec 23, 2007 6:06 PM
by Jeremy
I got the "metal masters" when I ordered pads from Steve a month or two back on his recommendation. They're called PBR Axxis or some such thing now. I've been VERY impressed with them thus far in combination with Balo rotors.
Posted: Dec 23, 2007 7:13 PM
by JamusMcFamus
I second Jeremy's opinion. I've had this setup for about 3 years now, and it's fantastic. I've only used it on the road and a few spirited mountain drives, but they're quite nice.
Posted: Dec 23, 2007 8:54 PM
I've got those on the 535 according to the service records - pretty dusty. They stop the car though, which really isn't as important to me as the dust factor. I guess if that sort of thing is important to you, go for them.
Posted: Dec 23, 2007 11:17 PM
by vance
wkohler wrote:I've got those on the 535 according to the service records - pretty dusty. They stop the car though, which really isn't as important to me as the dust factor. I guess if that sort of thing is important to you, go for them.
Just so that I'm clear on your thought rational, you would rather have clean wheels than to be able to stop well. Are you joking, or did SEB get your sign on info?
Vance
Posted: Dec 23, 2007 11:19 PM
Vance
Remember that dry wit I have?
Posted: Dec 23, 2007 11:22 PM
by vance
Trust me, I was giving you the benefit of the doubt, and was going with dry wit. :laugh:
Vance
