All ready for the track again Wednesday...
Posted: Mar 12, 2007 12:27 AM
by Kyle in NO
This time I installed some "track tires" along with the ugliest E36 wheels I could get my hands on! They seem to work ok, I just hope they hook up. I refuse to boil down my good set of tires in the name of traction!
Also installed today was the S3.25 diff and refurbished CV axles, courtesy of TCD, Duke, and my parts hoard. Okay, okay, and Booker, since I am an indian giver...Hopefully this would theoretically put me into the 12s in the quarter. I know this visit will yield slower times than previously seen, as the temperature (at best) will be 30 deg. warmer! :x :x :x I may just have to wait to see that 12.99....
I hope a cold front passes through on Wednesday!
Gross!!!
Re: All ready for the track again Wednesday...
Posted: Mar 12, 2007 1:15 AM
by GregATL
Kyle in NO wrote:
Shit Hot! Now you're looking good. :rofl:
Hope it goes well wednesday.
Posted: Mar 12, 2007 1:36 AM
by Kyle in NO
Yeah, no joke. Hotttt. I just went to the industriplex a few blocks away from my house to boil these things down to get to some soft rubber! Boy do they make some noise, nothing but screeching and howling! Several snaking black stripes and figure eights later, I think they still suck....just hope they get da job done.
Posted: Mar 12, 2007 8:14 AM
by johnnye23
Kyle are you going to drop the air pressure on the rears ? Or is there a minimum pressure you have to run ? Johnny
Posted: Mar 12, 2007 3:57 PM
by Kyle in NO
I have them at 25 psi. Wonder if I should go lower...
Posted: Mar 12, 2007 5:01 PM
by johnnye23
I would Kyle,more meat on the pavement. It would be an interesting test with no other changes made except dropping the rear air pressures. ;)
tires
Posted: Mar 12, 2007 10:28 PM
by h2dave
one thing i do know about is dragracing(still learning about e28 :laugh: )and you do not want to drop a radial tire down too far on pressure,the outside edges will only touch and it will not work as well.i went 10.10 on a 275/40/17 drag radial at 18 lbs.regular radials dont like to be as low as a drag radial.i would not go lower then 24lbs.
dave
Posted: Mar 12, 2007 11:29 PM
by Kyle in NO
Thanks for the tips guys! We'll see how it goes...
Posted: Mar 13, 2007 7:49 AM
by vance
Also drive around the water box instead of going through it for your burn out. With a radial street tire water can collect in the tread and trickle onto the track when you stage. Also try a "shallow stage" if you want to increase your trap speed and elapse time. After the first staging ambers on the tree light up, creap forward till the second stage start to flicker. As soon as they stay solid, stop. This will increase your roll out so the vehicle speed will be higher before the timer starts. :alright:
Have fun!
Vance
Posted: Mar 13, 2007 9:17 AM
by Kyle in NO
That's whaty I did the previous couple visits. I will repeat this time as well....
If it doesn't rain! They are predicting 80% chance of rain timorrow...Doh!
Posted: Mar 16, 2007 10:01 PM
by the Tanned One
Well ???? :shock:
Posted: Mar 16, 2007 10:21 PM
by Kyle in NO
Ahhhh, it was a rain-out...will try again next week.
Posted: Mar 17, 2007 2:45 PM
by booker
You should just leave your regular tires on instead of those pieces of shit. I predict a WORSE launch. :shock:
Posted: Mar 17, 2007 4:36 PM
by johnnye23
Kyle in NO wrote:Ahhhh, it was a rain-out...will try again next week.
