Diesel Project
wmahaffey
Diesel Project
Post by wmahaffey »
I am considering a BMW Diesel project. I can find a 2.4 liter TD engine. However, I would lke to know if you can use a 2.7 liter ETA block and transplant the 2.4 liter TD head crank and rods? Does anyone know a diesel expert to whom I can ask that question, or have the answer to that question?
Better yet does anyone know where I can find a 2.8 liter TD engine that is rebuildable?
My plans are to put the engine in a E30 or the E28 that I already own.
Thanks in advance,
Bill Mahaffey
PassaTDIesel
better off to sell it
Post by PassaTDIesel »
i think the costs are going ot be quite high and outwieght the advantages of running diesel, so you're better off selling your engine to me so i can put it in my 524TD LOL
wmahaffey
Post by wmahaffey »
My project has been put on hold. I have located a 524td engine but it is in a flood car. The car has been under water. If you are interested I will let you know where it is located.
PassaTDIesel
interested
I'm very interested in the car if it's with reason. My MSN is hickster23@hotmail.com
altus22
Post by altus22 »
I'm going to guess that you can't because the pistons are what determine the compression ratio. It sounds like you are planning on using the pistons and block from the 2.7L engine. This will probably give you a compression ratio that you can use with petrol, not diesel. I'm not an expert, but I vote no. If you get custom pistons, then it would work. Good luck.
