What are you m30 guys using to block off the dizzy.....
Posted: Mar 30, 2006 2:45 PM
by terrybpp
when going with EDIS and coil packs? I've seen the plug for the m10 & m20 but not one to fill that big fat hole in the front of our. I know I could just leave the cap on, but thats too easy.
Posted: Mar 30, 2006 3:02 PM
by Boru
You can cut an aluminum plate (or other suitable material) that bolts on in place of the distributor cap.
Posted: Mar 30, 2006 3:04 PM
by terrybpp
It would have to have a very tight seal though, no?
Posted: Mar 30, 2006 3:17 PM
by Boru
The seal is deeper in the timing cover and seals against the rotor hub. There is also an o-ring on the black dust cover. That dust cover and it's o-ring can be retained, pressed into place by whatever you choose to replace the distributor cap with.
http://www.turbochargingdynamics.com/tcd_news_001.htm
Scrole down a few pics and you'll see Duke's engine with a cover plate.
Posted: Mar 30, 2006 4:03 PM
by RDAvena
Use the upper timing chain cover off of an e21 320i. Blocks off the hole, looks good, and it a stock BMW part.
Posted: Mar 30, 2006 4:36 PM
by Boru
Good info,Ray! So, its a direct bolt on? I'll have to hunt one down.
Posted: Mar 30, 2006 7:16 PM
by DMNaskale
Smooth... I got to get me a couple of those.
Posted: Mar 31, 2006 9:43 AM
by RDAvena
Sweeney wrote:Good info,Ray! So, its a direct bolt on? I'll have to hunt one down.
Yes, but for dual timing chains the one from the 1976 model needs to be used. That is if you have dual timing chains. Although the ETK only shows one part number so it may have enough clearence for both.
Posted: Mar 31, 2006 12:02 PM
by Bill in MN
You mean Duct Tape won't work?
Posted: Mar 31, 2006 1:25 PM
by stuartinmn
I seem to remember this came up once before, maybe last year sometime, and the end result was even though the 320i part looks right it won't fit on the M30 engine.
I have no personal experience so I'm not the authority, but it may be worth a search of the archives.
Edited to add: I think it was discussed during Duke's engine buildup, I'll bet he remembers.
Posted: Mar 31, 2006 2:59 PM
by Velocewest
I'm pretty sure I've got a 320i front cover somewhere, and M30 heads I got mucho right now. I'll try to check the fit this weekend.
Posted: Mar 31, 2006 11:24 PM
by Duke
DMNaskale wrote:Smooth... I got to get me a couple of those.
Hey guys BTDT.........................it won't fit. I was all over it too.
The cover I have on mine is from The Power Plant. I was charged something like $150 for it, way too much.
BNC has the contact info for The Power Plant
Posted: Apr 01, 2006 12:45 AM
by Jeremy
Carb'd m30s had the distributor mounted on the front of the head, correct? It seems that the mounting hole for the distributer would be a pretty small hole to close off for use with a distributorless ignition system. And since it had something there originally (the distributor), there should be an easy way to mount a blockoff plate.
Unless I'm missing something really obvious. Which is pretty likely since I'm attempting to think waaaay past my bedtime.
Posted: Apr 02, 2006 1:48 AM
by Velocewest
Jeremy wrote:Carb'd m30s had the distributor mounted on the front of the head, correct? It seems that the mounting hole for the distributer would be a pretty small hole to close off for use with a distributorless ignition system. And since it had something there originally (the distributor), there should be an easy way to mount a blockoff plate.
All M30's prior to Motronic DME had the dizzy poking out of the front cover toward the passenger fender. That would include anything up through the '82 e24. You could probably tap the dizzy hole and screw in a plug. The one for the timing chain tensioner might work.
Posted: Apr 04, 2006 4:51 PM
by Rich Euro M5
Velocewest wrote:Jeremy wrote:Carb'd m30s had the distributor mounted on the front of the head, correct? It seems that the mounting hole for the distributer would be a pretty small hole to close off for use with a distributorless ignition system. And since it had something there originally (the distributor), there should be an easy way to mount a blockoff plate.
Why tap the hole, I bet the hole for the dizzy would probably take a metric sized freeze plug. I was going to do this when I deleted the speedo drive on the G265 (from an E12) that I installed in my deceased 533i. I couldn't locally source a freeze plug, but I did find one of those rubber expanding freeze plugs which fit perfectly.
Rich
Posted: Apr 04, 2006 6:10 PM
by BDK
Your's was originally billet wasn't it, then powdercoated???
Posted: Apr 04, 2006 10:24 PM
by Duke
BNC wrote:The cover I have on mine is from The Power Plant. I was charged something like $150 for it, way too much
Yep, I was overcharged for the powder coating too. Don't get me started..........OK, he also charged me over $200 for the E34 60-2 dampener with a really bad spray paint coating. I returned it and got one from Jim "at the shop" for $30.
