Posted: Feb 13, 2006 10:33 PM
by T_C_D
Order submitted 1/9/06.
Order ships 2/14/06.
I'll have all 8 sets next Monday and shipped to everyone Tuesday.
Todd
[Edit by T_C_D on [TIME]1140552531[/TIME]]
Posted: Feb 14, 2006 1:00 AM
by gol10dr1
O YA BABY! big boost here we come!!!!!!!!!!!!!!!! ~0
Posted: Feb 14, 2006 1:52 AM
by Tjn182
[QUOTE="gol10dr1"]O YA BABY! big boost here we come!!!!!!!!!!!!!!!! ~0 [/QUOTE]
+1 hehehehehe :p
Posted: Feb 16, 2006 7:04 PM
by bmw335is turbo
Hey todd what comp will the pistons make 8:0:1 in the e28 3.5 or lower like 7;5;1
SORRY IF I ALREADY HAVE ASKED THIS JUST WONDERING. THANKS
Posted: Feb 16, 2006 8:32 PM
by T_C_D
[QUOTE="bmw335is turbo"]Hey todd what comp will the pistons make 8:0:1 in the e28 3.5 or lower like 7;5;1
SORRY IF I ALREADY HAVE ASKED THIS JUST WONDERING. THANKS [/QUOTE]
Pistons come in any comp ratio you want. This order had 8.0 and 8.5 using the m30b35 cyl head.
Todd
Posted: Feb 16, 2006 9:10 PM
by jimbixjr
I can't wait to get mine!!!!
Posted: Feb 21, 2006 3:08 PM
by T_C_D
If you paid, they ship tomorrow. Pictured from right to left is the stock 9:1 m30b35, 8.5 and 8.0. Theya re so much lighter it's amazing!
Thanks guys!
Todd
Posted: Feb 21, 2006 3:11 PM
by russc
Sweeeet.
Posted: Feb 21, 2006 3:45 PM
by Tjn182
That's mine in the middle (maybe not)--- so purty and shiney
Posted: Feb 21, 2006 7:35 PM
by OldgreenE34
So Todd,
I guess the 8.5's are mine....the block is waiting. me too!
Cheers,
Dave
Posted: Feb 22, 2006 11:45 AM
by Rich Euro M5
[QUOTE="T_C_D"]Theya re so much lighter it's amazing!
Thanks guys!
Todd [/QUOTE]
FWIW: The stock M88/3 pistons per the ETK weigh 660 grams, or 28.31 oz, which is 1.46 lbs. My JE pistons weigh 350 grams, or 12.36 oz, which equals .77lbs. Multiplying by 6 results in a total weight of 8.76 lbs stock vs 4.62 lbs with the JE for a reduction of 4.14 lbs. Basically a 47 % reduction in internal reciprocating weight. If you think of this in terms of what a lightweight flywheel does for initial acceleration, it's almost comparable to switching from the stock 535i flywheel to the light 533i / M5 flywheel.
Rich
Posted: Feb 22, 2006 11:56 PM
by LonZo
Todd,
What is the price of the JE Pistons (6 for the M30 B35)?
Whats the price of your MLS?
Thanks
Lonzo
Posted: Feb 22, 2006 11:57 PM
by T_C_D
[QUOTE="LonZo"]Todd,
Thanks
Lonzo[/QUOTE]
$900 for pistons, rings and wrist pins rated to 720hp
$209 for the MLS
Todd
Posted: Feb 23, 2006 1:45 AM
by bmwmike
btw, what size are the pistons in the M30? Im picking up a spring compressor to install the pistons and need to know
Posted: Feb 23, 2006 6:37 AM
by Boru
[QUOTE="bmwmike"]btw, what size are the pistons in the M30? Im picking up a spring compressor to install the pistons and need to know[/QUOTE]
92mm
Posted: Feb 23, 2006 7:32 AM
by Shawn D.
[QUOTE="bmwmike"]Im picking up a spring compressor to install the pistons and need to know.[/QUOTE]
I'd like to see you perform that feat!
You'd have more success using a piston ring compressor!
Posted: Feb 23, 2006 9:16 AM
by papajetta
todd, are you planning on doing rods also, or are the stock rods good enough for those power figures?
Posted: Feb 23, 2006 9:44 AM
by T_C_D
[QUOTE="papajetta"]todd, are you planning on doing rods also, or are the stock rods good enough for those power figures?[/QUOTE]
Stock rods are forged. I don't expect to upgrade mine.
Posted: Feb 23, 2006 10:45 AM
by bmwmike
[QUOTE="Shawn D."]I'd like to see you perform that feat!
You'd have more success using a piston ring compressor![/QUOTE]
lol, typo, yeah thatd be a good idea!
Posted: Feb 23, 2006 10:46 AM
by gol10dr1
stock rods have been proven to hold 710 crank hp @ 6500 RPM on an m30 in sweden.
question..........what makes these pistons good for 720 while some are rated at over 1000, etc? is it the forging process and does that cost more for the more work that might have to be done in order to make a stronger piston?
Posted: Feb 23, 2006 11:09 AM
by T_C_D
[QUOTE="gol10dr1"]stock rods have been proven to hold 710 crank hp @ 6500 RPM on an m30 in sweden.
question..........what makes these pistons good for 720 while some are rated at over 1000, etc? is it the forging process and does that cost more for the more work that might have to be done in order to make a stronger piston?[/QUOTE]
The wrist pin is the limitation not the piston.
Posted: Feb 23, 2006 11:34 AM
by bmwmike
[QUOTE="T_C_D"]The wrist pin is the limitation not the piston.[/QUOTE]
So is there someway to cure this?
Posted: Feb 23, 2006 11:45 AM
by T_C_D
[QUOTE="bmwmike"]So is there someway to cure this?[/QUOTE]
Sure, upgrade the wrist pins.
Posted: Feb 23, 2006 6:33 PM
by gol10dr1
wait i thought these turbos came with upgraded rings and wrist pins?
EDIT: PISTONS NOT TURBOS! should probably proof read a little more before i post a question!
[Edit by gol10dr1 on [TIME]1140752689[/TIME]]
Posted: Feb 23, 2006 6:51 PM
by russc
[QUOTE="gol10dr1"]wait i thought these turbos came with upgraded rings and wrist pins?[/QUOTE]
Hu,
The wrist pin is the connector between the piston and rod. Why would it come with a turbo?
Posted: Feb 23, 2006 7:00 PM
by Boru
A piston that will tolerate higher loadsthan the ones we ordered will have more material left, thicker walls, etc. Couple that with stronger wrist pins, yada,yada, blah, blah.... This all equates to high load tolerance and, of course, more weight.
Posted: Feb 23, 2006 7:12 PM
by russc
Right,
I guess to bemore clear, those componets go with a engine, not a tubo. Unless you ordered them from TCD as a separate item and are re-building the engine to use them, you dont need them. I guess I can finish Andrews question with when you ordered the turbo kit, you weren't rebuilding the engine at the time, so theres no reason to have rings and pins.
Posted: Feb 25, 2006 5:03 AM
by jimbixjr
Everybody should sleep with their pistons the first night. It helps them feel more comfortable and later on when your boosting over 20 psi they take it easier and will last longer when you drive it like you stole it. Im definetly gonna be sleeping with my pistons for the first week and im definetly gonna be driving it like I stole it everytime I put my foot on that pedal!
Posted: Mar 03, 2006 3:33 PM
by gol10dr1
i wish i coulda slept with my pistons, but they went directly to the shop and now the block is at quicksilver race machining in frederick, md getting bored out and honed and assembling the bottom end. we are only a few weeks away now!!!!
Posted: Mar 04, 2006 12:00 PM
by Bill in MN
I got the head back yesterday, the crank and block will be here on Wed. From there it's anybody's guess as to when it gets put back together.
I kept a piston on my nightstand. Does that constitute sleeping with one?
