# 5 fuse blowing
Posted: Jul 29, 2026 7:18 PM
Hiya folks. I have a fuse blowing issue on a 1987 528e.
Electrical is not my favorite- but, ive opened up and cleaned the light switch. Really gunky and nasty.
Ive now blown all my white fuses to check this issue at the moment.
Here is what i was trying so i could isolate the issue; this fuse (#5 white fuse 8 amps) covers the park-sidemarker-a taillight n.,rear foglight, instru. a. license plate illumination
the left blinker works(front and back), but the park marker lights dont work(front or back).
addendum- I had and am having problems with my speedometer(2nd time changing gears still erratic.) I did the battery renewal, it showed well for about a week so i think i have to resolder the contacts.
i unhooked the license plate lights, took out bulb at left rear marker and took out bulb at left side marker and front blinker/park light bulb also.
So in (my) theory- when i get some fuses i should be able in install and turn on switch without it blowing, and then one by one plug each bulb in to see when the fuse burns out?
does that make sense? if not how can i trouble shoot this issue? i do have a multimeter, just dont know how to use it well.
thanks in adavance.
d.wil
thanks in adavance.
d.wil
