84' 528e Heavy Misfiring + Wont Idle - Help please!
Posted: Apr 08, 2025 12:25 PM
I'm a bit lost on what the issue is with my car. I was driving home from work and it just sorta sputtered out and died on the highway. I was able to limp it home, and it will stay alive if you give it throttle, but it misfires heavily the whole time and dies the second you let off.
As far as I can remember, the ICV has never been plugged into anything. I believe the PO bypassed it in some way, and I never cared to change it because it ran just fine for many years, but it’s possible this could be good info. The distributor was replaced right before Thanksgiving for a trip I took, as was the timing belt. The coil pack was replaced about 3 years ago. The crank speed sensor on the transmission is really old and busted-looking, so I’ve got one on the way but I don’t really know how to test it without just swapping it out. I’ve got an intake boot and a valve cover breather hose on the way as well, but I don’t see any gaping holes that would make me think it’s a vacuum issue. Still, I’m not going to rule it out with how old some of these lines are.
So far, I’ve gone through and checked the following:
- Checked for spark: Spark light is getting good strong flashes. However, I’ve got an order on the way from FCP with plugs and wires, as the current ones are getting pretty old. I'm not confident this will fix the issue.
- Fuel pressure: I'm getting 40–44 psi while it’s running. When shut off, it slowly sinks back down. After about 3 minutes, it was at 20 psi.
- Checked injectors: Did the old screwdriver check, and they all sound like they’re ticking.
- Pulled plugs: They were all wet with gas.
- Cold start injector: I completely disconnected the cold start injector on the intake manifold to see if it was possibly stuck open and dumping fuel—no change.
- Grounds: Made a temporary ground with jumper cables from the engine to chassis and negative battery to chassis—no change.
- TPS: Checked the TPS; it does not seem to be working and is caked with old and new oil. I’ve got a new one on the way, but I’m not sure how much this could play a role or how long it’s been non-functioning.
- AFM: Checked the AFM via the pins, as I couldn’t open the black plastic due to some strong silicone used to reseal it previously. The temp sensor was within spec. I tested the resistance while slowly opening the flap (off the car), and it seemed to climb gradually as it should, with some dead spots. However, I don’t think the dead spots are the issue, as it sputters regardless of RPM or throttle. I then checked the voltage while the car was on and was getting ~7 volts while fully open. The battery was pretty dead, though, so that number is probably off. I checked the voltage coming from the ECU on the connector and am getting 10.25 volts. I swapped in a spare ECU and got the same number. What is the proper value here?
- Main relay: Swapped it out just to be safe.
