TPS Adjustment for the 1.3 conversion
jimoreno
Post by jimoreno »
So I just did the throttle plate adjustment to 0.002" but when I search for adjusting the TPS, all of the adjustments are for small three wire one (the one my B34 used to have) but nothing that references the round plug one. I understand that this one is more of a variable resistor instead of the switches on the prior version but is there a specific position or resistance value to hit when in idle? I couldn't find a pinout for the connector so I don't know which pins to read either.
jimoreno
Re: TPS Adjustment for the 1.3 conversion
Post by jimoreno »
Never mind. Installed everything and with the engine running (originally around 1200 RPM) rotated it all the way counterclockwise until the RPM dropped to around 850/900. What was interesting was that when I tightened the bolts the RPM's went back up so I had to keep some force on it while I tightened the bolts (good thing they are hex key now!).
