Different valve covers available?
328dabi
Post by 328dabi »
I’ve seen 3 different valve covers for the M21. One labeled ford which was used by Lincoln. One labeled bmw and another with the roundel on it. Functionally they are all the same (I think). Does anyone know if there are any differences? And why bmw made two different covers? I thought it was an early production vs late production change but after looking at over a dozen cars of various years there seems to be no rhyme or reason for which cover is used. Meaning I’ve seen both covers on 85’s as well as on 86’s. My North American spec 84 has the cover that says bmw.
Galahad
Re: Different valve covers available?
Post by Galahad »
My understanding is they're all interchangeable; no clue why they made different covers different years. My engine has a roundel cover, I think it was a later car (had ABS) but I can't remember which year off the top of my head
gadget73
Post by gadget73 »
I wonder if its an early/late thing but you're seeing cars that have had engine or just valve cover swaps. I've seen a BMW roundel cover on a Lincoln. I know it didn't come with that, but I couldn't guess whether someone changed the cover or the whole engine. My Lincoln has the Ford cover.
328dabi
Post by 328dabi »
gadget73 wrote: Dec 31, 2024 9:35 AM I wonder if its an early/late thing but you're seeing cars that have had engine or just valve cover swaps. I've seen a BMW roundel cover on a Lincoln. I know it didn't come with that, but I couldn't guess whether someone changed the cover or the whole engine. My Lincoln has the Ford cover.
If you look at all the bringatrailer and cars and bids auctions you will see what I mean. I’ve also looked at quite a few cars I found on marketplace before purchasing mine. I like the roundel cover best but I’m trying to keep my car as original as possible given its history, so won’t be swapping covers.
gadget73
Post by gadget73 »
I understand what you mean, I was just meaning that its not impossible that someone in the past changed the covers.  I wouldn't say that pics of 40 year old cars taken in modern times is a guarantee about what easily removed part it came with from the factory.
Boneyard Dynamics
Location: Bavaria, not far away from the place the e28s where build
Post by Boneyard Dynamics »
Hello,
it is an early / late thing:
- the version with the bmw emblem on top of the vacuum pump is the early version, used till early '86???
- the version labeled "BMW" is the late version, from early '86 onwards???
There are also 2 different timing belt covers. The length/end of the sublime rips was changed
regards,
Wolfgang
328dabi
Post by 328dabi »
Boneyard Dynamics" wrote: Jan 08, 2025 6:39 PM Hello,
regards,
Wolfgang
Thank you for the info. Which timing cover is the early cover?
