Well I've gone an bought someone's unfinished project
Posted: May 21, 2024 2:25 AM
Hey, I'm new to this forum and I have never owned a BMW before, despite really wanting to. I'm not new to mechanics, as I've been a professional mechanic for more than a decade and have owned many classic cars. Nevertheless, I know nothing about BMW and this franken-car leaves me with many questions such as "why have I done this" and "I'm already restoring multiple cars" and so on.
Anyhow, here are some photos.
So I've always wanted an e28 and I realize this is an E12 and this is an e28 forum, but you know I hope that's ok because the price was right and someone has already (poorly) done the engine swap I would want into it, and it has nicer bumpers.
So I bought this cheap because it was in shockingly unrusty conditon for a 1979 528i in Canada, and it has what is allegedly an M30b35 with that I think is called the 265? 5speed transmission and it ran and drove onto my trailer.
My main question is whether it actually is an M30b35.(it does appear to have the toothed tone wheel for motronic 1.3) I also have many misgivings about the quality of this engine swap.
So this photo is of the oil filter housing, now I'm a non-expert but the b35 in photos I've seen has this top loading cartridge set up, but this guy looks like it's from the original engine or maybe the whole bottom end is original who knows, all I know is it's facing downward and is jammed so hard into the engine mount that there is no way you can change the oil.
Another thing that I have no photos of is the transmission mount, it only has one mount on the passenger side, the transmission case has right and left flanges for mounts, but the bracket only has accommodations for one mount, also all the nuts are finger tight on the mount.
The engine has strong indications that it originally had an engine driven clutch fan which is missing for obvious reasons, there is a small electric fan operating as a pusher in front of the rad, is this original? Or has someone put this there, also I have yet to see it do anything.
The transmission has a strong whining noise in neutral. Maybe there is no oil in it? Who knows.
There are a few other things I have questions about, I appear to have most of the vacuum lines for the evap system missing? Is this going to cause all kinds of issues for me? There are also many electrical plugs that are just plugged into nothing and I have no idea what they are supposed to be for. That said, the engine runs just fine after I changed a fouled spark plug.
I've ordered a number of parts to hopefully get this recommissioned.
The main issue I have at the moment is actually the fact that the person who swapped this bodged the throttle, and the original parts from the E12 chassis that I need to hook up the throttle cable and make it work are missing.
Namely "lever" Part #: 35411113233 and "rod" Part #: 35411107644
also, nothing electrical works except the power sunroof.
Now, I've ordered these from pelican parts who claim to have them even though they are discontinued 20 years ago, but I don't have much faith in that.
My main question for you kind-hearted forum users would be to pursue my photos and see if you can eyeball anything I might not notice that I should be paying attention to. I would also love some wiring diagrams for this engine, so I can trace down this rat's nest, otherwise it will never be reliable.
