[SOLVED] New OEM BMW radiator causing overheating issues?
Sup mye28! I'm usually just a lurker here, but wanted to pick your brain(s) on a strange overheating issue I've been having on my M5.
TL;DR: After replacing nearly the entire cooling system and going through multiple BMW radiators, the car still climbs to 2 o'clock at idle and struggles to maintain a 12 o'clock position on 90F+ days. Is it possible the new OEM BMW metal radiators are defective? EDIT - Aug 6, 2023: Somehow, yes... EDIT - Jan 28, 2025: I ended up designing a new radiator in conjunction with CSF (link), SOLVED!
I have never once had cooling issues, and the car always ran around 11 o'clock (even the hottest of days); however, earlier this year I drove the car to lunch (60F ambient temp/5min drive), and when I came back into the garage and turned it off, the OEM BMW plastic radiator had cracked clean off at the upper radiator hose. As strange as it was, I chalked it up to old age as it was likely 10 years old.
I quickly ordered a new, OEM BMW radiator (which arrived w/ metal tanks in a BMW box), refilled it the system, and after a short 30min drive, was hit with a 1 o'clock temp gauge on a 60F day. Now that it's 90F+, the car is nearing the 2 o'clock range at idle while measuring around 215F at the upper radiator hose. Since the original incident, I have replaced/serviced the following parts (along with other unrelated items) without any luck in improving the situation...
4/02/23 (381,000) - OEM BMW radiator (17112226018)
4/02/23 (381,000) - Coolant flush using OEM BMW coolant (50/50)
4/10/23 (381,000) - Meyle fan clutch (11521466000)
4/20/23 (381,500) - Sachs fan clutch (11521723918)
5/21/23 (382,000) - OEM BMW 80deg (used) thermostat w/ seal (removed a Calorstat unit with 20k miles, tested both units, successful results)
5/21/23 (382,000) - Coolant flush using OEM BMW coolant (50/50)
6/01/23 (382,400) - VEMO radiator fan switch (61318361787)
6/01/23 (382,400) - VEMO radiator fan switch (61311378073)
6/15/23 (384,000) - VEMO coolant temp sensor (13621709967)
6/15/23 (384,000) - FAE coolant temp sender (62161360870)
7/03/23 (384,100) - A/C Solutions (CSF) high flow parallel flow condenser w/ 13" SPAL pusher fan (ACS-x)
7/03/23 (384,100) - Performed Bentley OHM values on coolant temp sender (successful results)
7/03/23 (384,100) - Removed cluster and cleaned and checked temp gauge for cracks/etc. (successful results)
7/17/23 (384,250) - Hepu 535i pump (11519070761) (removed an OEM BMW unit w/ no signs of failure)
7/17/23 (384,250) - OEM BMW radiator (again) (17112226018)
7/17/23 (384,250) - Coolant flush using OEM BMW coolant (60/40 water/coolant)
7/30/23 (384,500) - Performed head gasket combustion gas test (successful results)
[EDIT - August 6, 2023] → SOLVED TEMPORARILY
8/04/23 (384,600) - Installed a used (plastic) OEM BMW BEHR radiator (17112226018) with BMW coolant (60/40 water/coolant)
[EDIT - July 5, 2024] → SOLVED
7/05/24 (394,800) - Installed a prototype aluminum radiator from CSF Race with BMW coolant (60/40 water/coolant)
12/22/24 (398,200) - Installed a new CSF High-Performance Aluminum Radiator (CSF-7232) with BMW coolant (60/40 water/coolant)
Additional notes: This is a 3.6L Paul Burke stroker w/ that I've put about 90k miles in the past 6 years. I have experienced zero coolant loss over the duration of my ownership, and the expansion tank, cap, level sensor, and all hoses have been replaced with OEM BMW parts over the last 5-10 years.
Thanks in advance!
Thanks in advance!
Re: New OEM BMW radiator causing overheating issues?
Does the cooling system overpressurise? If you let it sit overnight does it still have pressure in it after cooling off?
Is this a M30 car or a S38 car. If M30 there's been some discussion about the SA radiators with round tubes not cooling well. If S38 IDK what the options are. Check out this thread. viewtopic.php?t=154621
I just pulled the cap off after about 3hrs, and it didn't seem to have a ton of pressure in it. No excessive pressure overnight.turbodan wrote: Jul 30, 2023 8:06 PM Does the cooling system overpressurise? If you let it sit overnight does it still have pressure in it after cooling off?
88 M5 (S38), so unfortunately there are only a few options. I'm reluctant to go to an aftermarket radiator unless I need to, but would much prefer a NOS plastic OEM M5 radiator to rule out the new metal ones from potentially being defective.Mike W. wrote: Jul 30, 2023 8:23 PM Is this a M30 car or a S38 car. If M30 there's been some discussion about the SA radiators with round tubes not cooling well. If S38 IDK what the options are. Check out this thread. viewtopic.php?t=154621
Ok, now this is an absolutely crazy thought, but since you're kind of in a spot and it has metal tanks, what about a recore? Not many do it anymore, but I see you're in Sac so there ought to be someone over there that still does it. I didn't have them done myself, but I've had a couple that came in cars I bought and they always performed well.austin_caccavo wrote: Jul 30, 2023 8:50 PM
Not totally crazy - I've thought about it...Mike W. wrote: Jul 30, 2023 9:31 PM Ok, now this is an absolutely crazy thought, but since you're kind of in a spot and it has metal tanks, what about a recore?
After doing some research on RealOEM, I noticed the euro M5 uses a different part number (17112226082) than that of the US M5 (17112226018). Does anyone know the difference between the two?
(https://www.schmiedmann.com/en/product/ ... -2-226-082)
It would be easy to verify that the radiator is functioning. Pull the fan and shroud, warm the engine until the thermostat opens and check if the radiator is hot from top to bottom. Cold spots indicate no flow.
Does it overheat when idling or only while running at speed?
What radiator cap are you using? I read here on my that the ///M motor needs a 1.4Bar cap not the usual 1.0 bar unit in the M30
Don't know if that will change the overheating, though.
Planning on doing this later today, but since I'm on my 2nd new radiator I'd assume it's "fine", but will report back! It overheats at idle as well as at slow speeds. On the freeway it takes a very long time to cool off and get back down to 12 o'clock.turbodan wrote: Jul 31, 2023 9:20 AM It would be easy to verify that the radiator is functioning. Pull the fan and shroud, warm the engine until the thermostat opens and check if the radiator is hot from top to bottom. Cold spots indicate no flow.
I'm using the 1.4BAR cap, but just ordered a new one (as well as a vacuum bleeder) to rule it out (17112227683).Blue Shadow wrote: Jul 31, 2023 1:43 PM What radiator cap are you using? I read here on my that the ///M motor needs a 1.4Bar cap not the usual 1.0 bar unit in the M30
I saw that you have replaced twice the viscous fan clutch but it's not the first time that non original clutches face issues with proper function. The viscous fan is engaging clearly audible in my car at around the half or slightly above mark on the gauge.
If this doesn't happen then rectify the issue here first. In idle you need airflow from a proper engaging Fan unit. If that fails you will have always temperature issues. Also keep in mind that the Fan disengages above a certain rpm. Best to test it at around 1500-2000 rpm in idle
You might have an air pocket. Did you also replace the thermostat? I highly recommend the vacuum fill. That's what I use on all my cars when changing coolant or doing cooling system work.
The fan clutch seems to be locking up correctly when it's hot, but perhaps not as much as necessary if there's a cold spot in the radiator (still need to confirm this).Rouven036 wrote: Jul 31, 2023 4:53 PM I saw that you have replaced twice the viscous fan clutch but it's not the first time that non original clutches face issues with proper function. The viscous fan is engaging clearly audible in my car at around the half or slightly above mark on the gauge.
Yes - the thermostat was replaced several times. The new vacuum fill kit arrives in a few days, so I'll be report back asap!marek wrote: Aug 01, 2023 11:37 AM You might have an air pocket. Did you also replace the thermostat? I highly recommend the vacuum fill. That's what I use on all my cars when changing coolant or doing cooling system work.
Update: I ended up sourcing a used BEHR E28 M5 radiator so I am going to swap that in this weekend and see if that makes a difference and/or proves my theory with the newer radiators being less efficient. Stay tuned.
Should be a 20 degree difference if i recall correctly. My M5 will idle quite a while in 90 degree temp with no problem wo the aux fan at all fwiw
IIRC S38s are a bit more crowded in that neighborhood, but the newspaper test for fan clutches is pretty easy and a good test.austin_caccavo wrote: Aug 01, 2023 12:14 PM
Newspaper? What is that? Where can we find one?
Yes, an artifact from an earlier era.
Also, for consistency sake, I kept everything else the same and did the same bleeding process (non vacuum fill) as I had been in the past with the same 60/40 water/coolant mix. Very thankful to say things are back to normal with successful results, but also very disappointed as this proves my theory that the new metal radiators run hotter. I looked through the one I removed, but there's nothing that would lead me to think it wouldn't work... so hopefully BMW can address this issue!
I did the "newspaper test" on all 3 fan clutches and they all seemed okay. After doing it again with the new (used) plastic radiator, it's working perfectly.Mike W. wrote: Aug 04, 2023 8:08 PM the newspaper test for fan clutches is pretty easy and a good test.
Re: [SOLVED] New OEM BMW radiator causing overheating issues?
interesting to note. mine also likes to get quite warm when idling, often getting in the 1/2-2/3rds range. as soon as there's airflow, temp comes right down to 1/3 and stays there, until i idle again for more than a few minutes.
new fan clutch installed yesterday made absolutely zero difference. guess these new radiators suck. at $600, that's frustrating...
Glad you got it working ok. Just for the record, did the new, expensive, but lacking, radiator have round tubes or conventional flat tubes?
Glad that fixed it, and it's no longer collecting dust in the shed.
Thank you all for your help! Glad to say it's back to normal, but it sucks that the new metal radiators are problematic. If anyone has a NOS/NIB plastic OEM BMW M5 radiator, please let me know - I'd be interested in buying it!
It had the conventional flat tubing similar to the plastic radiator. After looking at it further, I don't understand how/where things went wrong as it looks promising.Mike W. wrote: Aug 06, 2023 10:18 PM Glad you got it working ok. Just for the record, did the new, expensive, but lacking, radiator have round tubes or conventional flat tubes?
would be interesting to bring to a radiator shop to take it apart and inspect it.
I thought about that too, but it's already been returned to FCP/BMW...mottati wrote: Aug 11, 2023 1:39 PM would be interesting to bring to a radiator shop to take it apart and inspect it.
makes me wonder if the internal diameter of the tubing is smaller than that of the standard aluminum radiators... thus, causing the issues we have here.
Hello Austin. I am confused. FCP doesn't seem to sell any radiator other than the stock Genuine BMW 17112226018 for the M5.
