turbo M30b34 anyone mind sharing a base map??
subconscious533i
Post by subconscious533i »
Hey guys finishing up my turbo setup ..... finally!
I have a m30b34 running an e34 b35 harness and ms2pnp.
-Tcd stage 2 turbo kit
-Bimmerheads performance head
(Ported/ polished, 284 cam, HD springs rockers and rocker locks)
-62lbs injectors
- 2x walboro 255 one in tank one out.
-adjustable fuel pressure regulator
-inovate lc2 wideband.
- stock distributor and coil
-stock icv
- 10.5 lbs wasgate spring going to run off gate for now I do have a electronic boost controller to install later.
Tail blow off valve
Planning on running 93 octane as that is the best I can get here in Vermont.
BONDOSPECIAL
Re: turbo M30b34 anyone mind sharing a base map??
Post by BONDOSPECIAL »
I can send you some, I have a pretty well sorted out M30B35 that is also an MS2PNP based on a M1.3 e34 harness. Also using an (old) TCD 61mm turbo, 60 lb injectors, B35 cam, LC2. Pocket ported B35 head, JE forged pistons, ARP head studs, MLS head gasket. It is currently wasted spark (a worthwhile upgrade) but I can dig up some tunes from back when I had a distributor (although my tune wasn't as well sorted out back then, but it drove okay). I have a 9 psi spring in a TiaL and an EBC and am running 15-16 psi right now.
PM me your email address.
BONDOSPECIAL
MSQ sent
