The question I have is about which spring goes where. There are two, one about half again as beefy as the other. RealOem appears to have the larger spring bridging the adjusting screw, and the smaller bridging what it calls the "Expanding Lock" that attaches to the e-brake cable:
http://www.realoem.com/bmw/enUS/showpar ... Id=34_0335
I was able to install the springs with some needle nosed vise grips, but the larger of the springs was a bit slack, even after fiddling with the shoes. So I swapped them.
The Larger spring is at the e-brake cable:
The Smaller spring is at the adjuster. When the Larger spring was in this position it barely had tension on it.
Before taking these pictures I put the disc on and tried the e-brake function. It worked, but I am not sure with the springs the way they are it is positioning the shoes as they should be. The springs seem to do a good enough job of retracting them.
Any thoughts?
And yes, I used search and spent some time looking at YouTube videos to get some tips, about 90 minutes in total. I also consulted the Bentley before starting and read the relevant portions of the Brake chapter 2 or three times before starting.
