WTB: Chrome windshield trim
drosas
Post by drosas »
Anyone have or know where to get Front and Rear chrome windshield trim for an e28?
Thanks
jimoreno
Post by jimoreno »
Are you referring to the plastic part or the polished aluminum one? You can buy the plastic piece on most online vendors and buy two fronts. The pieces for the rear are more expensive than the single front one, just cut it.
As for the aluminum ones, the dealer is your best bet. They are a pain to get installed as the ones I got didn't had the right shape when delivered (and it cam in a huge box so it wasn't bent on shipping).
Wally59
Post by Wally59 »
Purchased mine from Autohausaz. As mentioned above, buy 2 fronts and cut for rear window.
drosas
Post by drosas »
I'm referring to the chrome trim on the front (and rear) windshield. Like on Jeremy's old e28
jimoreno
Post by jimoreno »
drosas wrote: I'm referring to the chrome trim on the front (and rear) windshield. Like on Jeremy's old e28
The trim is composed of several pieces. The front windshield has one plastic chrome trim piece (#2), two aluminum corner pieces (#4 & #5) and one aluminum bottom strip (#3). The rear one has four aluminum corner pieces (#8, #9 & #12), three plastic chrome strips (two #7 & #11) and one aluminum bottom strip (#10). See below:
drosas
Post by drosas »
Where can I purchase these components?
jimoreno
Post by jimoreno »
Wally59 wrote:Purchased mine from Autohausaz. As mentioned above, buy 2 fronts and cut for rear window.
Here you have one, you can contact the guys at Blunttech (forum sponsors) or your local stealer, err, dealer.
Also, please fill in the location in your profile so people know where you are from.
drosas
Post by drosas »
I went on autohaz but I could not find anything by searching window trim. I will try again.
I'm in California
jimoreno
Post by jimoreno »
Here you go:
http://www.autohausaz.com/search/produc ... %20Molding
They only show the plastic chrome moulding though so you will need to source the other parts rfom either Blunttech or other online original BMW parts place.
drosas
Post by drosas »
So would #51311820622 be the #2 in the image? and #51311820623 would be #11?
jimoreno
Post by jimoreno »
Yes, but just buy two #51311820622 and cut the one for the rear as needed. Its cheaper than buying all four different pieces.
Blue Shadow
Post by Blue Shadow »
cheaper at BMW. Try Bluntech when you figure out what you really need.
drosas
Post by drosas »
jimoreno wrote:Yes, but just buy two #51311820622 and cut the one for the rear as needed. Its cheaper than buying all four different pieces.
Thank you. Just purchased a pair :cool:
