Got the dyno runs last night...
Really happy with the results. I was expecting ~285whp, got 303whp in a roundabout way. As you can see, the 4th gear runs went to crap from the knock controller I believe. The blue is 3rd gear, and it looks fine @8psi. The next run is green in 4th. It made 9.5psi, but the J&S knock controller destroyed the run(?). The real problem is temp. The runs were were made in 100deg temps
I should have made the fist run in 4th, but I wanted to see what it looked like fist. The IC was coolish for the fist run, hot for the 2nd and on fire for the third. The end of the 3rd the IC burnt my hand when I touched it. I guess it was nearly 160deg. The Dinan IC placement is total crap for dyno'ing, the exhaust manifold just cooks it w/o proper air flow.
Anyway, if the 2nd run was OK after 4400rpm, I extrapalted the torque would have made ~340lb-ft @ 4900rpm and ~315whp @ 5500rpm. Im sure that would have been pretty close, which is really great FOR A JUNK YARD ENGINE
I was also impressed with how the hp rose steadily to 5500rpm. I didn't think it would, but it did. If I had rev'd it to 6k rpm, It may have made another 5-10whp...oh well. Also, the hp and torque are closer in value than I would have thought. Only a ~15 spread.
And, this is all with 91octane CA crap gas. Im sure if I was to add some candy 100octane to mix up to say 94 like the guys in any other state, it would have made some more power easily. I think Im going to go back and make some runs when its cooler and can take a little time between runs and adjust out the knock controller a little to see where it is before the MegaSquirt install. Some tuning can make this moster a real beast.
I data logged the LM-1 for the dyno runs....
I marked the point where the AFM voltage knee'd @ 4900rpm. As you can see from the dyno, the torque peaked at 4900rpm, exactly where AFM stopped opening. As I said earlier in the tuning thread, I thought that would be the case. The eninge maxes air flow max AFM flap opening.
