I have a 260/6 in my e28, granted it’s likely an e28 trans as it has the holes for the bellhousing sensors, I realize it could have been drilled and tapped, but likely an e28 trans. I would not classify it as a shitty shift at all, it had an unknown short shifter in it as well. I would try a different shifter set up before condemning your trans. What oil is in it?szacsi72 wrote: Apr 03, 2024 7:54 AM How shitty are 260/6-s to shift?
I have a really poor quality, overly short shifter in my car. When I shift, it takes time before the shifter pops into gear - I need to wait for the RPM to drop. I started to wonder, is this normal with a short shifter, or maybe that larger E34 master cylinder is causing my clutch to not fully disengage?
No grinding or anything, goes into first OK at a stop.. Just takes time to shift.
My 260/5 I had before was similar, the difference being, that that one would grind when cold.
Thanks
szacsi72's 1984 Zinnoberrot 535i Build
CanadianMiniFan
Re: szacsi72's 1984 Zinnoberrot 535i Build
Re: szacsi72's E28 535i build thread - "The Reddie"
Mine stuck decently well. If I recall correctly I degreased and cleaned the surface first, but didn't do any other prep.szacsi72 wrote: Mar 27, 2024 8:03 AM Does this product stick OK to underbody coatings? Or do I need to adhere it to paint?
I'm not super keen on originality, but I don't want it to look out of place. So I'll stick to silver onesvinceg101 wrote: Apr 03, 2024 4:31 PMIt will matter just how close to OEM you want to get. Panici's gold reflective material may be extremely effective but isn't really spec. For mine I wanted/needed to match the original as much as possible and chose to install the reflective material in the original configuration (mostly on the passenger side) but I did take some liberties for performance reasons.szacsi72 wrote: Mar 27, 2024 8:03 AM There's a company who sells reflect-a-cool and others, but it's pretty expensive. 30x30cm goes for roughly 20 bucks. Instead I've found this product, it's also made by DEI:
https://race-shop.hu/ontapado-hoszigete ... x60cm.html
Looks like it's a cheaper, lower quality product. I think this would be fine, it's not a turbo car, I just want to add some isulation because the tunnel does get really hot in the summer.
I will also add sound and heat insulation and deadening from the inside too.
I chose a similar material that the Reflect-A-Cool (Cool-It Thermo Tec); it was self-adhering but I added some aggressive high-temp spray adhesive to ensure long-term adhesion.
You can read my write-up here on page 2 of my build thread: https://www.mye28.com/viewtopic.php?f=7 ... 5&start=25
I applied layers of other thermal and acoustic layers to the interior when I did the interior remodel later in that build thread. It all makes a difference; how much? It's hard to tell.
I believe ATF. Since it's an E34, those were filled with ATF. I'm considering going for a mix of 80w and ATF but I'm not sure. Some say go for Redline, some say go for ATF...CanadianMiniFan wrote: Apr 04, 2024 11:43 AMI have a 260/6 in my e28, granted it’s likely an e28 trans as it has the holes for the bellhousing sensors, I realize it could have been drilled and tapped, but likely an e28 trans. I would not classify it as a shitty shift at all, it had an unknown short shifter in it as well. I would try a different shifter set up before condemning your trans. What oil is in it?szacsi72 wrote: Apr 03, 2024 7:54 AM How shitty are 260/6-s to shift?
Thanks
Thanks, good news!
I had some free time and since I couldn't do anything with the engine, or the engine bay (waiting for parts and tools), I played around in the interior.
Previous owner left me a surprise
For the love of god. I understand that the shelf had to be cut for the big 6x9's to install but WHY THERE??
I was debating of making 6x9 to 6.5" round adapter plates but I think that having the speakers so far away from the sides would look awful, + doesn't help with the stereo sound either.
So now I have to somehow fill in these holes, before making new ones.... sigh
Welding is not an option right now, I would have to remove too many parts. I'm thinking of laser cutting a 1mm steel plate, and riveting it into place with some silicone glue to make it airtight. I will then cover the whole shelf with sound deadening so it won't look too awful, but I will have to come back to this later and fix it, because I will know it's there...
Took some measurements for the adapter plates.
Here are the 100mm Audison AP4s next to the original 6x4s:
And fitted the read seatbelts in the rear:
They will look much better once the red-stitched, semi-leather, m-rain interior is installed. It feels a bit ouf of place as of now.
Question #12: could you recommend me thicknesses for the sound deadening? Bitumen/butyl (the one that is for reducing vibrations)
I'm trying to place it strategically: thinner where it matters less/isn't that bad and thicker where it matters more.
I was thinking of:
4mm: around the front speakers, and the rear shelf
2mm: most of the underbody, tunnel, and the doors
1.5mm: trunk, and the part behind the rear seats (but not the shelf)
I probably won't do the roof as I've heard removing the headliner is a PITA.
I was thinking of:
Haven't updated the thread in a while.
I can finally ride again, so I threw together the street bike.
The track bike needs to wait... I can't do that just yet.
I started with the soundproofing:
Installed the front seatbelts:
That's about it... these were all just "side quests" I did while I was bored doing something else.
Next week the engine build will finally continue. I threw the block back on the hoist, installed the crankshaft, rods and pistons without rings.
I'm cutting some valve relief pockets into the pistons. 50mm diameter cuts for the intake valves, and 40mm for the exhaust valves.
After that, the block is finally, and ACTUALLY heading to the machine shop.
I'll have quite a lot of tasks while I'm waiting...
1. Collecting the rest of the parts - mostly seals, gaskets, bolts...
2. Preparing all the parts. Cleaning, polishing, painting, machining, welding...
3. Modifying the cam gear to be adjustable (needed for the KMcam)
I'd like everything laid out, ready to installed before I start the assembly. Once cleaned, I like to close the engine as fast as possible. I have a fear of dirt getting into the engine.
Once that's done, I'll do the serpentine conversion, start the wiring loom and re-paint the engine bay, then it's install time.
I'll make an exact to-do list, in priority order, because I'm easily confused and I'll start with the least important bit...
Last week's job was cutting valve reliefs into the piston.
I was given an old, cut-up cylinder head, with a 50mm cutter, which is the perfect size for the B35 intake valves.
However, that was only the intake side. So I bought a random valve that had a 41mm head, and an 8mm, longer stem, and went oldschool.
It worked surprisingly well.
Next, I re-installed the pistons, rods and crankshaft with the old bearings, without the rings. I used my mitutoyo dial indicator to set the pistons at TDC, then installed the cylinder head with two valves to measure the clearances.
Once I had that, I measured the piston top thickness in a getto way:
Then it was time to cut.
The finished product:
I now have 5.9 and 6.1mm of clearance at TDC. I think that's plenty...
I also finished painting the engine, ready for the machine shop.
The final values I'm bringing:
Hone to 92.02
Decking the block 0.2mm
Decking the cylinder head 0.5mm
My final compression ratio will be roughly 9.7-9.8.
Hone to 92.02
Machine shop time.
Chimi-Changa
Nice work on the piston cuts!
I'm thinking about getting them coated too. Ceracote C110 dry film for the skirts and C186 for the tops.
One can only imagine results if I attempted that.
Valve stem seal question.
There are three elring options that fit.
197.378 - black ACM
294.110 - green FPM
553.190 - red FPM
If I put the part number into Bárdi autó (local parts vendor), i get the black and green ones as options.
Elring lists the red one in their catalogue.
Autodoc gives me 774.456, which a 12 pack of red ones.
Which one do you guys use?
197.378 - black ACM
294.110 - green FPM
553.190 - red FPM
It appears the red and green are the same, Viton, which is what you want. I'm used to seeing green so I'd probably go in that direction. I would not use the black, it doesn't appear to have the same heat resistance as Viton.
Viton is the best, you do not want not want Buna N or nitrile or neoprene, they don't hold up.
I'll use Viton, that's for sure. The only thing I can't decide on is red or green. I'm not sure if there's any difference between them apart from colouring...Mike W. wrote: Jun 29, 2024 12:30 PM It appears the red and green are the same, Viton, which is what you want. I'm used to seeing green so I'd probably go in that direction. I would not use the black, it doesn't appear to have the same heat resistance as Viton.
Technical drawing to convert the stock timing chain sprocket to an adjustable one (36 teeth = 10deg/teeth, so you only ever need +/-5 degree to make it 360°. In case onebody needs it. I'm also making a washer out of 2mm stainless to help keep things together. In case anybody will even need this.
photo upload sites
Similar to what Paul Burke did.. just no fancy CNC machining.
Remember to use longer bolts...
Interesting. What are you doing about the locating pin hole?
Nothing, I'm just removing it.
Not much point in a locating pin if the gear is adjustable
shizzel669
Shouldn’t the holes be offset? In your drawing it looks like they aren’t.
As you see I didn't give exact locations for the bolt holes. They will be milled on a manual machine, locate the hole, rotate CW, CCW, doneshizzel669 wrote: Jul 02, 2024 11:49 AM Shouldn’t the holes be offset? In your drawing it looks like they aren’t.
Good and bad news today.
Good news:
I got the parts back from the machine shop.
Bad news:
Wasted money, wasted time and no progress at all.
The machine shop fucked up... x2.
1. I asked them to deck the head 0.4mm. I measured the height to be roughly 128.9~128,95mm. Of course, calipers are not the tool you would use here, but it's accurate enough to tell that it's not 128.6mm as it should be. Also, the maximum decking marks are still showing and I measured ~0.35mm on them... this is upsetting, but at least this is useable and if I really wanted to, I could install it as is.
2. I installed the timing covers on both the cylinder head and the block prior to decking and told them specifically that they need to be cut together as the head gasket goes between them. The upper timing cover was installed and cut, but they removed the lower cover and didn't bother ????
Now I have a 0.3mm step between them! For the love of god. I can't install the head gasket like this!
And the worst part is that I traveled 400km's, and spent a complete day on the trip. Now I have to do that AGAIN, another 400km, another whole day, another favour from a bud to help me, another 100 bucks on fuel, AND, the guy is on vacation until September. SEPTEMBER. I have EVERYTHING laying on my desk, and I mean everything. And now I can't make progress for 2 months because of this.
I'm so frustrated, I don't even know what I should do.
Probably ask for a refund and find someone else... but even then, lot of time wasted.
Good news:
Bad news:
Interesting how similar things can be a continent apart. Over the years I've found many marginal or incompetent machine shops. I've learned that if I find a good one, stick with it, don't look at the cost until later, just grin and bear it, it's cheaper to do it properly once than poorly twice. A good machinist is like gold and they seem few and far between.szacsi72 wrote: Jul 11, 2024 3:15 AM
Bad news:
Over here at least for the longest time all they really wanted to work on was American cast iron V8s. Most but not all would tolerate what they considered odd foreign stuff, but they for the most part didn't like it. And often the results showed. But where you're at I'm surprised, or at least I would think they would have lots of experience with lots of different engines.
That's what I did, this shop was the only one I used in the past 4 years, as they were normally very quick and precise and helped me with everything, even extreme stuff, like modifying the S50B32EU pistons to create a 3.2 stroker M50, or custom conrod bushings.. I think the guy was probably rushing due to him leaving for holiday and hence the mistakes. I would normally not be too upset, it happens. But 2 months waiting time and the 400kms don't help the case. I'll ring him today and see what we can do.Mike W. wrote: Jul 11, 2024 3:52 PMInteresting how similar things can be a continent apart. Over the years I've found many marginal or incompetent machine shops. I've learned that if I find a good one, stick with it, don't look at the cost until later, just grin and bear it, it's cheaper to do it properly once than poorly twice. A good machinist is like gold and they seem few and far between.szacsi72 wrote: Jul 11, 2024 3:15 AM
Bad news:
I talked to the machinist and now I'm not upset - I'm furious.
Problem 1:
"you must have mis-measured"
That's it. Whatever I told him he didn't listed. I asked him to take 0.4mm from the head. I measured before, and I measured after. I measured other heads. I looked in the book. I measured the dimples. It should be 128.6mm maximum. And it's 128.9mm. The dimples are still 0.3-0.35mm deep........
I'm so f...g angry guys I don't even know what to do.
The sheer arrogance he talked to me with.... He acted like if I was an idiot running around with plastic calipers. I tried to explain to him that I measured with 3 calipers, 2 micrometers, in 3 different ways, at 6 different locations...Mitutoyo, not some chinese garbage... NOTHING.
And other than a bad review, there's nothing I can do.
Problem 2:
"I just can't do it"
Regarding the fact he didn't cut the lower timing cover. That's it. I asked what to do about it... because now there's a bump there.....??? A 0.3mm bump? I don't think it's a great idea to install the HG like that. He doesn't know because he never does them, just the block itself.
Time, money and stress down the drain... Don't you just love reputable shops?
Problem 1:
Problem 2:
I've had plenty of bad experiences with machine shops as I said earlier, but I don't know if I've had one that bad. About all I can say is I feel your pain.
Beyond crude, but I've seen upper timing covers cut on a belt sander, a bench unit, not handheld. But I've also got one that's probably got .4MM out of square from front to back. It can be cut on a sander, slowly and carefully with lots of measuring and testing on the block.
There is a guy who said he could do the lower timing cover for me on a fly cutter. It doesn't matter much if its a bit too low, but if it's too high, I can't properly tighten the cylinder head. So, fly cutter it is.Mike W. wrote: Jul 16, 2024 12:37 AM I've had plenty of bad experiences with machine shops as I said earlier, but I don't know if I've had one that bad. About all I can say is I feel your pain.
In the meantime, a couple updatese.
I cleared out the front of the car in preparation for the engine bay paintjob.
Finished the strut mount on the other side too. Now I can finally open the hood like a normal person...
However I'm not sure what to do about the hood latch wire. It's currently basically deleted, and the lever is mounted under the car body (yes. I know what you are thinking, and I'm thinking the same). I could install a bowden/wire in the originnal place but all the guides have been deleted, + I don't want a wire there, it's such a clean engine bay otherwise. Any tips? I'm thinking of somehow hiding it under the left wing.
Welded in the steering box mount reinforcement..
Some parts..
I'm refreshing the underbody coating first, then I'll move towards the engine bay and start sanding and bondo-ing.
My custom billet DSSR is also in:
Dave
There's always a way. You could pull the dowels out on the upper cover, I've seen that done before when it wasn't cut but the head was. Or if it was just too much, you could always cut the front "loop" of the HG off and RTV the upper to the lower. But it sounds like you finally have it under control and what I just mentioned are not good ways of doing things, just what can be done just in case.szacsi72 wrote: Aug 09, 2024 8:24 AM There is a guy who said he could do the lower timing cover for me on a fly cutter. It doesn't matter much if its a bit too low, but if it's too high, I can't properly tighten the cylinder head. So, fly cutter it is.
Nice background!
Yep, many ways around it but having invested upwards of 4-5k in an Engine, I don't want workarounds.Mike W. wrote: Aug 09, 2024 12:09 PMThere's always a way. You could pull the dowels out on the upper cover, I've seen that done before when it wasn't cut but the head was. Or if it was just too much, you could always cut the front "loop" of the HG off and RTV the upper to the lower. But it sounds like you finally have it under control and what I just mentioned are not good ways of doing things, just what can be done just in case.szacsi72 wrote: Aug 09, 2024 8:24 AM There is a guy who said he could do the lower timing cover for me on a fly cutter. It doesn't matter much if its a bit too low, but if it's too high, I can't properly tighten the cylinder head. So, fly cutter it is.
I need to look at your car once in a while to remember my E28 is an actual vehicle and not just a bunch of parts sitting in my garage...
Your own work? I have a custom shift rod but it's one-sided - had Send Cut Send make it for me. Sad they don't have that in Europe
Sure is. I made them double sided so that I could use precision/matched bolts - or whatever their proper name is. It's ISO 7379. Apart from the middle being 10mm-f9, meaning a really nice fit with BMW's selector joint, I can adjust the preload, to dial in slack and tension, or make up for wear over time.
