Thanks, for pointing that out. I've already done thorough research into this topic, and updating the vanos is part of the plan/budget. Haven't nailed who/how the work will get done, but it will get done.635L6M3 wrote:Awesome build!
Just a heads-up...even though your S54 has very low miles I would consider bulletproofing the vanos system before you drop it in. Cracked/broken hub and loose bolts is a common issue...anywhere from low to high mileage. Beisan has a cheap fix for any of the common issues....pasted below.
http://www.m3forum.net/m3forum/showthread.php?t=441481
Minerva: The S54 powered, better than new, E28
Re: Project 'Blue': The perfect, S54 powered, DD E28
This is gonna be awesome! What's the plan for course? Build, sort, then paint and interior or?
Good question. I've thought it out, but now that you ask I realize I haven't ever written it down...which crazy given how much I harp on people for "Have a plan. Write it down." I'm willing to be a lot of clarification comes from this...so here goes...86GT635 wrote:This is gonna be awesome! What's the plan for course? Build, sort, then paint and interior or?
(your summary is just about right: test/measure, build/modify, paint, assemble, do interior, drive)
- Get car on lift and inspect under-side (I've never seen it because I haven't ever put it on the lift yet!)
- Remove E46 engine mounts from engine.
- Remove S54 oil pan.
- Install M50 oil pan/pump/pickup (still need to source; may do the steps below w/out an oil pan at all).
- Install Marco916's engine mounts on engine and attach tospare sub-frame.
- Build engine/tranny cradle for table-lift. The idea is a cradle (with wheels) that the table-lift can slide under and then lift the sub-frame/engine/tranny in a stable way. I am itching for my first real welding project…
- Hoist 'er up (table-lift)/drop 'er down (4-post lift) for a test fit.
- Verify Marco916's mounts put the engine where I want it.
- Determine what mods to the transmission tunnel are required to fit the 6-speed.
- … (a whole bunch of stuff relating to the brake booster, oil cooler, intake muffler, wiring, …)
- Assemble everything so that the engine can start. The car will not be drivable due to lack of interior and there's no point in really going that far, but I want to be completely sure the engine electronics and accessories are sorted BEFORE the car is re-painted (e.g. brackets fabricated and welded into place).
- Build a dolly that will let me move the chassis around without any suspension (see Kohler/bkbimmer's threads for ideas). Another fun welding project!
- Strip all parts off the chassis.
- Transport the chassis to my body/paint guy. He's got a rotisserie…
- … (a lot of details about sound proofing, rust prevention, under coating, body work, prep, paint) …
- Let cure… for a long time.
- Start re-attaching parts (learning a lot from Kohler's treads on how to phase all this).
- Interior comes last (or close to last).
So what you're saying is there's still time to decide on paint color, I vote Montego! Good luck Charlie, this is a real whopper of a build.
Great thread..that car looks familar?????
CEK - I have rebuilt M5 (RED tag) steering box available.
PML
PML
If you use my thread for ideas your build will fail. I don't write things down or have spreadsheets. Sorrycek wrote:Good question. I've thought it out, but now that you ask I realize I haven't ever written it down...which crazy given how much I harp on people for "Have a plan. Write it down." I'm willing to be a lot of clarification comes from this...so here goes...86GT635 wrote:This is gonna be awesome! What's the plan for course? Build, sort, then paint and interior or?
You don't get off that easy. I see what I want to see in your threads.bkbimmer wrote:If you use my thread for ideas your build will fail. I don't write things down or have spreadsheets. Sorry
cek wrote:You don't get off that easy. I see what I want to see in your threads.bkbimmer wrote:If you use my thread for ideas your build will fail. I don't write things down or have spreadsheets. Sorry
Don't you see what you want to see from sea to shining sea?
- Location: Wherever the E28 happens to be parked- Morrisville, NY
Sibkbimmer wrote:cek wrote:You don't get off that easy. I see what I want to see in your threads.bkbimmer wrote:If you use my thread for ideas your build will fail. I don't write things down or have spreadsheets. Sorry
Progress sir, this board depends on your insatiable narcissism.
I don't log in here enough. This is going to be intereresting in more then one direction . You , like One Direction right?
Thanks for the pic and reminder, I agree, that is gorgeous.Mark 88/M5 Houston wrote:I've always liked the BMW Lapisblau and you rarely see it in North America.
Re: Project 'Blue': Yet another S54 powered E28
Anyone else worried about cek? Haven't seen him around for awhile.
Cek, you still there?
*shouts into the void*
Me: "CEK, WHERE ARE YOU?!"
*gets the sheering metal response of an S54 falling off the cherry picker*
Cek: "God DAMMIT"
Cek: "God DAMMIT"
Hopefully he came to his senses and got out of this hobby to pursue more worthwhile causes.
I know where he is.
I'm good. Just busy as f**k with a new role at the bookstore. Not that you REALLY care.
Thats just because you followed him home. How much milk is in his fridge?oldskool wrote:I know where he is.
i care, not like the rest of these knuckleheads.cek wrote:I'm good. Just busy as f**k with a new role at the bookstore. Not that you REALLY care.
I care a lot, we love you, big guy.
Now inspire us, please.
EventuallyAyrton wrote:Thats just because you followed him home. How much milk is in his fridge?oldskool wrote:I know where he is.
I hate it when he makes us begbkbimmer wrote:I care a lot, we love you, big guy.
I hate it when he lifts his leg.
Finally got a little time to poke around in the garage. Been a b z b.
Got the clutch and flywheel off so I could get the engine on the stand. Next step is to pull the oil pan so I can attach the mounts and front sub-frame. I'll then construct my engine cradle.
Also received a package of refinished fasteners. Oooh...
And I found a set of 740 trailing arms (thanks @az!). Inbound.
Those are berry berry nice. I forgot that the s54 has two cams lol. Thats what happens when M30 is life. It's a double Vanos valve system as well isn't it?
Yes, there are two Vanos valves.
Nice. Interesting mounts.
Where did you get the refinishing/cadmium plating done?
