Posted: Mar 21, 2012 12:28 AM
My wifey says I need to host a Harvestfest.Mike W. wrote:Hammerfest, ...
Looks to me like the fender did that damage when it moved backwards into the area directly under the windshield. Since it's bolted to the inner fender all along the upper surface, I think it's more likely that the shock tower moved as well.slimdevil27 wrote:I seriously doubt that the shock tower reinforcement moved back and caused that damage, it's possible but I think the more likely scenario is the door opening did that damage....
I think that's the more likely scenario, but cars will flex quite a bit in accidents and spring back. When my E12 got rear ended the door gaps were good, but you could see where the paint got chipped from contact. Regardless, an eighth of an inch isn't much even if it didn't spring back all the way, body alignment wasn't measured in thousandths back then. Again, not having seen it yet I can't say for sure, but I think it's eminently repairable, albeit to less than a factory standard. But a presentable and functional car.ahab wrote:Looks to me like the fender did that damage when it moved backwards into the area directly under the windshield. Since it's bolted to the inner fender all along the upper surface, I think it's more likely that the shock tower moved as well.slimdevil27 wrote:I seriously doubt that the shock tower reinforcement moved back and caused that damage, it's possible but I think the more likely scenario is the door opening did that damage....
Edit. I retract the shock tower bit, but I still think the front impact to the fender, and not the door did that punch under the windshield. I'd still fix it however.
I agree, looking at the picture again. Sorry, I was speculating while working and then out looking at my car.Mike W. wrote:I think that's the more likely scenario, but cars will flex quite a bit in accidents and spring back. When my E12 got rear ended the door gaps were good, but you could see where the paint got chipped from contact. Regardless, an eighth of an inch isn't much even if it didn't spring back all the way, body alignment wasn't measured in thousandths back then. Again, not having seen it yet I can't say for sure, but I think it's eminently repairable, albeit to less than a factory standard. But a presentable and functional car.ahab wrote:Looks to me like the fender did that damage when it moved backward into the area directly under the windshield. Since it's bolted to the inner fender all along the upper surface, I think it's more likely that the shock tower moved as well.slimdevil27 wrote:I seriously doubt that the shock tower reinforcement moved back and caused that damage, it's possible but I think the more likely scenario is the door opening did that damage....
Mike W. wrote:Hammerfest, we need a Hammerfest, not a Wrenchfest. 2X4s, chains and 8 pound sledges. Take no prisoners.
