Page 26 of 179
Posted: Aug 24, 2010 6:22 PM
by rmiddendorf
Thought about going to NAPA to get new parking bulbs... and drove it for work...
Posted: Aug 24, 2010 8:58 PM
by ilikemybike
Pulled it over on I-84 to puke. Being sick in the summer blows ass.
New speakers ordered. Infinity Kappa for the front, Focal components for the rear. The new deck pretty much blew the 23-year-old speakers.
Posted: Aug 24, 2010 9:03 PM
by luckyone
replaced my shifter, now its a whole different car
drove the hell out of it
Posted: Aug 25, 2010 9:47 AM
by Das_Prachtstrasse
purchase a miller maf/war chip.
Posted: Aug 25, 2010 3:18 PM
On the 533, the RHS SKF wheel bearing was slowly raising the white flag (French), so both were replaced. Damn inner races stayed on the spindle. Thank God for air tools. Busted off the ABS tone ring and we're good. Didn't plan on having to update to the later style nuts, though. Wasted an hour there.
Posted: Aug 27, 2010 12:14 AM
by tock172
Well over the past few days, I trailered the car from my home in San Diego to Prescott AZ, my new home while in college.
Today, I unloaded all of my stuff from the car, to my dorm. The car gained 2 inches of lift in the rear and also has much more power
Posted: Aug 27, 2010 12:23 AM
by Xenocide
Adjusted the valves, drove it. Looked longingly at the 885 head sitting in the corner
Posted: Aug 28, 2010 3:51 AM
by mithrites
Changed my headlights to H4s Thursday evening and didn't hit 2 deers on Friday morning...I swore I would've hit them if I had my regular lights(one of the best upgrades I did yet!!)..and bought some new wheels(can't remember what style they are but they're 17s
, pictures coming soon)
Posted: Aug 28, 2010 4:38 PM
by rmiddendorf
Finally bought new turn signal bulbs only to find out that the left front running light isn't getting power. Crap.
Posted: Aug 28, 2010 5:43 PM
by a
rmiddendorf wrote:Finally bought new turn signal bulbs only to find out that the left front running light isn't getting power. Crap.
wiggle the harness connector. I am trying to to diconnect the wonky ABS on B6II. On Marina's super E, I finally got the radio to take the code and replaced a few widgets with stuff from my parts cars.
Posted: Aug 28, 2010 5:52 PM
by rmiddendorf
I already tried that. No voltage at all. Not even a bump on a wiggle. Going to have to gain better access to it (remove the top bumper cover???) and shove the multimeter down the connector. Hopefully its just corroded. Also want to check the fuses but I can't imagine that they're not all on the same circuit. Haven't spent much time on it yet though... do have the .pdfs to use. Thanks!
Posted: Aug 28, 2010 6:46 PM
Traded one for an E21...
Posted: Aug 28, 2010 6:50 PM
by davintosh
FINALLY got some time to work on it (hour & 1/2
) & tried in vain to get the flywheel bolts loose/off. Going back tonight/tomorrow with a bit of angle iron to bolt up to the thing to keep the crank from turning. Cleaned a little more grime off the trans. Not quite clean enough to eat off of. Yet.
swatterssr wrote:Traded one for an E21...
Pics or it didn't happen.
Posted: Aug 29, 2010 7:09 PM
by jimoreno
I just finished replacing most of the front end. I bought new BMW upper arms, Powerflex bushings, BMW sway bar links, Turner Motorsports lower arms, both front wheel bearings, sway bar bushings, BMW strut mounts and BMW Motorsports springs. Changed the oil and filter with Mobil 1 15W-50 from Walmart ($21 for 5 quarts yes!). Still pending are the rear springs (BMW Motorsports) and sway bar bushings and end links. Already feels like a completely different car, Wow! I love my E28 (more than my E34 530 auto-tragic!) The PO had already put Bilstein HD's in it and now is not as "bouncy" as it used to be.
I guess I'll go take my Ibuprofen now as most of my 43 years old body hurts!
Posted: Aug 29, 2010 7:28 PM
by funfunfer
from the Bronzit, I pulled the dash, ignition wiring harness, the cracked diving boards, right side doors, heater, parcel shelf, HVAC wiring harness, miscellaneous other parts and bagged the keeper parts.
Posted: Aug 29, 2010 10:36 PM
funfunfer wrote:from the Bronzit
Posted: Aug 29, 2010 10:45 PM
This for
this.
Posted: Aug 29, 2010 11:08 PM
by twin55
Installed both rear window weather strips (outer) this evening.
Uploaded with
ImageShack.us
Posted: Sep 04, 2010 9:51 PM
by Jsanders
Installed new Meyle upper and lower control arms, sway bar end links and tie rod ends. I still need to get it aligned, but it already feels so much better.
I also found out that the PO installed Schwinn sway bar bushings, made of what I can only guess is a Schwinn bicycle tire.
Posted: Sep 05, 2010 1:11 AM
Now that is funny...or, maybe not.
Posted: Sep 05, 2010 2:21 PM
by Jsanders
I got a kick out of it. At least I know my bushings are Schwinn approved.
Schwinn Bushings
Posted: Sep 05, 2010 2:34 PM
by Tulsa6
Jsanders wrote:Installed new Meyle upper and lower control arms, sway bar end links and tie rod ends. I still need to get it aligned, but it already feels so much better.
At least the name sounds German.
Urethane Bushings
Posted: Sep 05, 2010 8:19 PM
by Tulsa6
Never again. I took mine off the road today, to have it ready to fix since it's no longer safe to drive.
At least when rubber fails, it goes gradually. FWIW, the heat shield was in place. Meyle HD's on my list.
Posted: Sep 05, 2010 8:27 PM
by w0014170
Made a panel, wired & Installed three aux gauges where the ash tray once resided, washed & waxed the beast. Going to Copelands for Veal then Cadilliac Cafe for some trim
Posted: Sep 05, 2010 8:59 PM
by C.R. Krieger
I'm discovering there are a lot more good rubber pieces on my ratty old Wisconsin parts car than on the formerly-of-Florida Kelvinator. Yesterday, after pulling the track tires off [Note: need rear pads.], I dug into the left rear door where the window was slightly open - just enough to make noise - and wouldn't move.
The first thing I discovered when I opened things up was more evidence of the 'butcher' who had hung the doors when they were replaced. The damn motor wasn't plugged in.
Even connected, though, it ran but nothing moved. After messing with it for awhile, I went into the garage where the Lachs Beast lurks to provide parts. I pulled the door card off (gaining an unbroken latch handle surround) and removed the (uncracked!) latch handle itself. Then I pulled the window lift mechanism and walked it over to the Kelvinator, fresh in the knowledge of how the thing comes out.
Even after it was hanging, the old one was stuck. WTF? I finally forced the lift pin along its track with some difficulty and, when it came out, the problem was obvious: it was rusted into place. No wonder the old motor clutch failed. Along the way, I'd noticed the window seals were still rubber on the parts car while they were pieces of hardened oxidized crap on the Kelvinator. So out with the old and in with the old-but-still-nice. Plenty of silicone spray and some white grease and we were in business.
I hit the window lift track heavily with grease and worked the nicely lubed replacement into place. After connecting it (
Ya hear that, moron?), it worked perfectly. As well, I recovered three panel fasteners from a door card to replace those done in by the butcher and replaced the door latch handle (butcher had cracked it and lost the little grommet for the link hook) and surround.
Next up: swap out the driver door latch and lock assembly. Somehow, the butcher didn't think it important that this door, of all the locking points, should work. Also plan to replace the belt with one that still has the button that keeps the link from falling to the floor.
Re: Schwinn Bushings
Posted: Sep 05, 2010 9:15 PM
by ilikemybike
Tulsa6 wrote:Jsanders wrote:Installed new Meyle upper and lower control arms, sway bar end links and tie rod ends. I still need to get it aligned, but it already feels so much better.
I think that's part of a hand grip. This was installed as a bushing?!!
Posted: Sep 05, 2010 9:38 PM
by rmiddendorf
Rotated my tires- but that didn't fix the shimmy. And still struggling with my not-operational front left parking lights. Switch works, fuse is good, now the front spoiler's gotta go so I can trace wires...
Posted: Sep 05, 2010 10:46 PM
by w0014170
rmiddendorf wrote:Rotated my tires- but that didn't fix the shimmy. And still struggling with my not-operational front left parking lights. Switch works, fuse is good, now the front spoiler's gotta go so I can trace wires...
Switch the socket from the other side first...you likely need a socket or harness connector, both accessible w/o removing the dam.
Posted: Sep 05, 2010 11:15 PM
by Jsanders
It sure was! Actually they still are. New bushings will be on the way shortly.
Posted: Sep 06, 2010 12:28 AM
E12 content:
Removed everything necessary, and then dropped the 4 speed box.
Tomorrow, in goes the 5 speed.
Oh yeah, drove the eta 5 speed to church and back.
