Page 23 of 31
Re: Maytag: The Alpine '87 528e Bench Player
Posted: Dec 14, 2016 1:27 AM
by tig
Posted: Dec 14, 2016 9:56 PM
You know, I think I keep my cars up pretty well. Not perfect, I don't throw money at them, but they work well. Engine compartment looks good compared to cars I look at. I do nice work, no broken bolts are kludged wiring. Quality work, no mickey mouse stuff. I've long thought I'd love to buy one of my cars sometime. But not anymore, now I want to buy one of CEKs cars.
Nice work Charlie.
Posted: Dec 14, 2016 11:10 PM
by tig
Mike W. wrote:You know, I think I keep my cars up pretty well. Not perfect, I don't throw money at them, but they work well. Engine compartment looks good compared to cars I look at. I do nice work, no broken bolts are kludged wiring. Quality work, no mickey mouse stuff. I've long thought I'd love to buy one of my cars sometime. But not anymore, now I want to buy one of CEKs cars.
Nice work Charlie.
Thanks Mike.
I just feel blessed that I have a hobby that lets me learn so much and then enjoy the results.
Posted: Dec 15, 2016 12:27 AM
by sail_or_drive
'Tis truly inspiring.
Posted: Dec 21, 2016 10:41 AM
by BenGerman
cek wrote:
Starting at rear. Plan is to complete it first then move to front.
Where exactly do you place the jack stands under the car?
- Nevermind, found all the infos in the pictures. -
The car looks like new, awesome progress!
Posted: Dec 21, 2016 11:03 AM
by leadphut
This is the 666th reply.
Posted: Dec 27, 2016 11:24 PM
leadphut wrote:This is the 666th reply.
667 actually.
Posted: Dec 31, 2016 9:12 PM
by tig
With the whole fam home I've been nervous about jumping in on the front end. If I screw something up we're down a car and someone is likely to gripe. But this afternoon after doing honey-doos (landscape lighting) I dug in with the goal of getting disassembly done. Victory.
However read on to see why I already know I've screwed up.
All the new bits ready:
Da fuq is going on here? How can this almost new slave be leaking? At least I think that's brake fluid and not oil. Sigh.
Yeah, those UCAs were shot.
All dis-assembled. Now that I've done it a few times, I actually feel like I know what I'm doing. The only fight I had was getting the steering arm separated from the steering box link. I had to destroy the old boot to get my my puller on.
What'd I screw up?
I pulled the front bearings off because I wanted to use the dust covers and hub nuts. That's when I realized I never ordered new back-side dust covers.
I'm screwed getting this back together tomorrow. Hopefully I can find some shields locally on Monday!
Regardless, next steps are:
- Clean, clean, clean
- Weld on steering box re-enforcement
- Reassemble
- Align
- Drive
Posted: Jan 01, 2017 5:03 AM
by davintosh
The gold-colored dust cover just presses in place; you might be able to get it off if you're careful. Really careful. Heat it up a bit first and you may get lucky.
Posted: Jan 01, 2017 9:19 PM
by tig
davintosh wrote:The gold-colored dust cover just presses in place; you might be able to get it off if you're careful. Really careful. Heat it up a bit first and you may get lucky.
Good call:
Didn't have tons of time today, so I set the goal of just getting it cleaned and getting the steering box reinforcement welded in...
I declare this is clean enough. That black stuff will come off with a lot of elbow grease and a brillo pad, but given how cold it is and how tired I was, and how this car will be just fine with a little grime under it...
Before attempting to weld in the steering box reinforcement dowel in, when i've never welded under something before, and given how much a welding noob I am I decided to install the 2nd dowel I bought into the subframe that will go in the blue car for practice. That subframe had been repaired by an PO. This is probably a fine weld, and probably strong enough, but I thought it ugly. So I cut it off.
I do love my new welding table. It's easy to move around enabling me to send grinding sparks outside the garage regardless of angle.
I was about to weld this into place when I realized somethings wrong with my welder. Wire isn't feeding right. I am aborting for tonight so I can warm up and go play some indoor soccer...
Posted: Jan 01, 2017 9:50 PM
by oldskool
Indoor soccer and welding shall never be mentioned in the same sentence. Ever.
Again.
Posted: Jan 02, 2017 2:46 AM
by leadphut
My best friend’s sister’s boyfriend’s brother’s girlfriend heard from this guy who knows this kid who’s going with a girl who saw Ferris welding at the indoor soccer stadium, before he passed-out at 31 Flavors last night. I guess it’s pretty serious.
Posted: Jan 02, 2017 9:34 PM
by tig
I played well. We lost but I scored two goals. Best things is no one got hurt. That's our motto: get some exercise and don't get hurt. Then drink beer.
Today I used my newfound welding skillz to install Ed "Mr Wrench" steering box reinforcement dowels on both the subframe destined for the blue car and the one on maytag.
I think I did ok:
This was taken after paint (paint's not dry in this pic). Not the cleanest weld...hard to weld upside down!
I also got the front struts/coil-overs all setup. This was more of a PITA than planned due to ineptitude, but now there's eptitude. The one thing I'm totally at a loss about is how to know how long to make these. The rears were easy because they were "as built" by the PO and I just made them about 1.5" longer knowing his car was pretty low. In this case, I had the lowers disconnected for cleaning and to get a replacement lower strut fabricated. I guess I'll just put 'em on and see how high/low it is. I think the only realistic way of changing the length is to unbolt them from the strut brace, let them drop and then spin; the shock rotates on the pivot mount, but not freely.
I also have no idea if the shocks are compressed right. They are both at the same setting and those nuts have not changed since the PO sold them to me (same as rears). I'll probably just leave it to the guy who does my alignment to tune them.
I got the steering linkages installed, along with the new pitman arm. I used the old steering links to eyeball the lengths of the new ones so that alignment should't be too far off.
Posted: Jan 03, 2017 8:22 AM
by davintosh
cek wrote:I got the steering linkages installed, along with the new pitman arm. I used the old steering links to eyeball the lengths of the new ones so that alignment should't be too far off.
That's what we all think when we SWAG the steering link length. Then the car drives like crap all the way to the alignment shop.
There are threads around here somewhere on how to do a quickie DIY alignment; I've never tried it, but some guys have had decent successes with it.
Posted: Jan 03, 2017 9:39 AM
davintosh wrote:cek wrote:I got the steering linkages installed, along with the new pitman arm. I used the old steering links to eyeball the lengths of the new ones so that alignment should't be too far off.
All it takes is a piece of string..
I do mine that way.
Not sure it'll work without stock suspension components though.
Posted: Jan 09, 2017 1:21 AM
by tig
After helping Mr. Quon buy just about the most perfect 1985 300SD from just about the most perfect 70+ yr old German couple, and after waiting for the power to come back on, I dove in...
Last time I did this, I assembled the strut lower plates and control arms with the control arms attached to the car. That was dumb. This was much easier:
As you can see I had the shocks way too low:
It's pretty easy adjusting these things once on the car. Just undo the 3 nuts holding the struts to the strut tower brace, letting the assembly settle onto a jackstand. Then just spin the top part of the strut counter clockwise to make it longer. I added about 3.8cm of length for my second try to decided it's close enough. When I get it aligned I'll have them dial it in perfectly.
Ta-da:
Then I tried my hand at the string-alignment technique. It was already pretty close to tits, but I was able to get it even closer. I didn't measure it, but the camber looks almost 0. The BC Racing coil overs have tons of camber adjustment.
Went for a spirited shakedown drive in the rain/dark/wind. Felt fine. Tracked straight, turned left and right as expected, stopped, and even went over some bumps. Nothing fell off (I checked when I got it back on the lift).
I had to use the freeway to get to my indoor soccer game and it felt a little squirlley. I think its a combination of both the front & rear not being aligned (I clearly have some (-) toe in the rear), the rear being about 1.27cm higher than the front (relatively), and the squishy sidewalls of the Nokian Hakkapeliitta snow tires. Ride feels great.
Hope to get it in to be aligned on tues or weds.
Posted: Jan 09, 2017 6:13 AM
by davintosh
3.8 cm... I lol'd.
Nice work.
Now I'll just wait until you tire of your fancy-schmancy suspension, return it to stock, and sell those lousy coilovers to, um, me.
At a nice discount.
Posted: Jan 15, 2017 2:05 PM
by tig
I hereby declare Operation "Coil-Overs + replace every suspension and steering component except the steering box" complete.
I got the car back from Kevin at KD Motorsports (same guy who's doing the Blue car; I wanted to compare his alignment service to Byron at Tru-Line whom I've used exclusively before) Friday night. He actually wasn't done with it when I went by there at about 7pm and so I was able to work with him on the final tweaks. Fun.
We did discover that I had over-torqued something causing steering to bind (not automatically return to center). This morning I discovered it was the nut connecting the idler arm to the subframe; I had over torqued it. Besides that he approved of all my work
Took it for a nice fast drive this morning and, damn, it drives well. I had started with the shocks at "soft" and could immediately tell it was too soft because bounce. I put 2 full turns in on all 4 corners and now it feels great. I may try an experiment at full "hard" to see the difference, but for now it seems great for how I use this car. Tracks straight at all speeds. Corners like it always should have (but never did). No wobbles. No shakes. Firm and crisp but not jarring. Color me happy.
And I think we got the ride height just right (see more details in
this thread).
Left Front: 568mm,
Left Rear: 545mm
Right Front: 565mm
Right Rear: 538mm
Summary:
Left Front: 568mm, Left Rear: 545mm (23mm)
Right Front: 565mm, Right Rear: 538mm (17mm)
Avg: 567mm F, 542mm R
Recall from above, stock should be (with 16" wheels):
Front: 589±10mm (23±3/8")
Rear: 527±10mm (20 3/4±3/8")
Diff front to rear: 62mm
Thus Maytag is about 22mm (.9") lower than stock in the front and 15mm (.6") HIGHER than stock in the rear.
Happy to have the RX wheels back on the car as I think they look swell. The snow tires are a bit squishy for super spirited driving, but likely necessary given the cold weather we've been having...
Posted: Jan 15, 2017 4:24 PM
by davintosh
Very nice. I sincerely believe Chuck would approve also.
Posted: Jan 22, 2017 5:18 PM
by tig
Completely forgot that I hadn't re-installed the fender liners until the set I ordered from Blunt showed up the other day...
Posted: Jan 24, 2017 5:35 PM
by foamy
man i wish my car was still clean like that underneath mines bathing in oil constantly and the harder i drive it the more oil gets out its never low in a 3000 mile interval though.
Posted: Jan 25, 2017 8:55 AM
by tig
foamy wrote:man i wish my car was still clean like that underneath mines bathing in oil constantly and the harder i drive it the more oil gets out its never low in a 3000 mile interval though.
There's nothing magical about getting it clean. No need to wish. It's just hard work. This car is leaking oil like a sieve too, from the HG between 3 & 4. I know that because I cleaned it.
Posted: Feb 19, 2017 12:16 PM
by tig
About two weeks ago Maytag started not starting on the first try.
I diagnosed it down to the in-tank fuel pump. 211,000 miles...
I decided to do the same single-pump conversion I had done on Vlad, using a TRE 255-LPF in-tank pump, with pump-by-filter delete.
Should be easy, right?
As I dug in, I realized I hadn't replaced the fuel lines at the back of the car when I basedlined it. I thought I had, but I must have been remembering Vlad. Much easier to replace the lines that go to the evap tank with the fuel tank out of the car. So it came out.
Then I noticed (remembered) the left-rear tow-hook was badly broken on this car. At some point in its life some hard force was applied and it sheared in two places. Good thing I now know how to weld...
I'll post more in the
in-tank fuel pump modification thread, but here's the rebuilt in-tank pump using the TRE unit:
Given the TRE pump is only $79 shipped, and you get to delete a point of failure, I can't imagine why anyone would want to not do this when their pumps fail.
Today's job is to fix that tow-hook, fix some surface rust on the gas tank, and get 'er all back together...
Posted: Feb 19, 2017 8:53 PM
by tig
After all that. Sigh...
I got everything back together after painting the parts of the tank I sanded surface rust from and painting the fine welding job I did fixing the tow hook... Didn't have any alpine white, but this is the underside...
Connected all the hoses and tested the new pump by jumping the pump relay. Made good noises and I could hear fuel pumping. Yay.
Still wouldn't start. Da fuq?
Previously in diagnosing the no start I found I had fuel (wet plugs) and spark (took a plug out and did the "see spark?" test). This is why I was convinced it was fuel supply and replacing the in-tank pump and filter would fix the problem.
Nope.
So I started from scratch again.
By the end of the day I:
Tried a backup 2.5 BAR FPR (and replaced all fuel hoses while I was "in there." I had never replaced the lower fuel hoses and they were still original. I was waiting to replace the engine since getting to the nipples by the steering box is a bitch). No Joy.
Pulled the disty and rotor off. The cap broke on me. I figured "YAY, that's it". The brushes were pretty scored/corroded too, making me think "that must be it". I don't remember if I replaced the cap & rotor when I did the timing belt (11/2013 @ 202k; now has 212k), and my records don't indicate. I'm guessing not because a Bosch cap that new should not break.
Got a new cap/rotor and installed it. No joy.
Double checked that I was getting spark. Yep...but not blue. Yellow.
Tried a backup coil. No joy.
Tried a backup ECU. No joy.
While in the glove box noticed I had a spare main relay in there. Figured, "Might as well try it".
Joy. Started right up.
Mother-fudger. ALL OF THAT AND IT WAS THE MAIN RELAY THE WHOLE TIME. Yes, Ivo, I know you said to check it. Don't know why I didn't.
Anyway I got a bunch of stuff done to the car that I had been planning on doing anyway at some point. Some of it was actually kinda fun. And I feel better knowing those fuel lines have finally been replaced.
The oil leak from the head gasket has spread to the drivers' side... I gotta get that M20B27 build moving along real soon now.
Posted: Feb 26, 2017 10:42 AM
by tig
The whole point of this coil-over job was to learn. Well, I'm learning.
I now understand, very viscerally, how spring rates affect how a car rides and handles.
PO had put 9Kg coils front & rear. This is not only much stiffer than what BC Racing normally provides (7Kg front/6Kg rear) but a different ratio. Because drift.
The end result was a pretty bouncy ride over larger depressions/bumps at speed.
After consulting with the nice guys at BC Racing (great customer support, BTW) I went with their stock setup:
Installed them yesterday. Rare glam shot.
Much, much better, but now I need to re-dial in the dampener hardness setting again.
Also replaced that leaking clutch slave. I was going to buy another rebuild kit to rebuild the OE steel unit (again), but given the rebuild started leaking after about 5k miles and the new FTE unit was about the same price as a rebuild kit, I went plastic.
Oh and I re-organized my wrench drawer.
Posted: Feb 28, 2017 1:47 AM
by Kenny Blankenship
You make me feel insignificant...
I would ask what you intend to do with the car and how do you want it to feel? If you want the car set up for aggressive handling, then 7 kg (400 lbs/in) might be appropriate. However, if you want a little more balance with better ride, maybe consider 5.3 - 6.2 kg (300-350 lbs) in front. In order to maintain a decent ride with stiffer springs, you'd want to consider increasing compression in the struts minimally (or not at all) while increasing rebound.
What is your rake front to rear? Measure at the rocker panel line or at the moulding, behind the front wheel well and in front of the rear wheel well. Depending upon how you want the look, I'd recommend 3/4" to 1 1/2". I like 1" to 1 1/4".
When I had my M7 I had compression (compared to stock) minimally increased but rebound was up 33-40%. You don't have to be that aggressive, though...
Posted: Feb 28, 2017 2:01 AM
A plastic clutch slave??? I've never heard of that. Assuming it's strong enough, which I suspect it is, and since a clutch is never going to get a mash it thru the floor pressure like brakes, it doesn't actually sound all bad, if it's the right plastic. But the thought of it has me shaking my head.
Posted: Sep 16, 2017 1:58 PM
by tig
I just read this whole thread again. Conclusion: The OP is insane.
Posted: Sep 17, 2017 12:16 AM
by dsmith
cek wrote:I just read this whole thread again. Conclusion: The OP is insane.
For reading 28 pages of a 528e? Yes
For keeping a solid, no rust 528e in good knick? Hardly.
Posted: Sep 17, 2017 12:30 AM
Yes, but not nearly as crazy as someone who would do it to a Toyota Corona/Corolla/Camry/Cwhateverthefuck, and I'm sure there are those who do. Besides, I'm not a fan of etas, I've never wanted an eta, I've never owned an eta, but now I want one.
Yours!
