help me spool up!
Drilled rotors are a gimmick for the most part, all they will do is make your rotors prone to cracking. Stick with blanks, or maybe slotted.jaredd624 wrote: Also for others assuming i went straight for power... you're wrong i have installed upgraded suspension (eibach springs and shocks) and Borbet style T wheels (used) with new Pirelli P-zero tires.i was going to upgrade brakes next ie drilled vented rotors and carbon ceramic pads (Brembo Big brake kits were a nice thought...), then i got curious about turbocharging...so sue me.
http://www.m535i.org/officers/ra/articles.html#brakes
Check that out. Lots of inexpensive bolt on factory brake upgrades! Check your local junkyard.
I gotta say, this is the first time I've seen someone apologize and listen to board vets on a thread like this. Respect!
It really doesn't. Not to a noticeable, appreciable extent for street driven car in any case. Vented is nice if you're weighing upgrade options, but slotted rotors tend to wear the pads really fast (they act a bit like a cheese grater on the pad surface), and the drilled rotors are more prone to cracking. Stick with a quality name, regular style rotor. They're less expensive anyway.jaredd624 wrote:i assumed the drilling helps keep heat down...
