OPERATION TIGER'S TEETH -**Boltin on MO Power**
Here is the specs on the cam -Coldswede wrote:So it looks like .450 to .500 is the sweet spot for lift. What kind of overlap will you run? Will the thing idle smoothly or be a bit lumpy?
Trick Flow Stage 2 Hydraulic Roller Cam
Duration at .050
Int - 224 Exh – 232 with Intake lift at .542 and exhaust at .563 with a 1.6 rocker
Advertised duration is I – 286 and E – 294
No idea about the idle....hope it rocks the car!
Duke wrote:Here is the specs on the cam -Coldswede wrote:So it looks like .450 to .500 is the sweet spot for lift. What kind of overlap will you run? Will the thing idle smoothly or be a bit lumpy?
Duration at .050
Got-em!
Finding 1985 RX7 GSL (FB) rear brakes is not easy. I joined a RX7 forum and found these from a guy parting out his car. Everything is in great shape (even the rotors) and will need some cleaning and painting. No red brakes on my Tiger thank you.
I paid $250 shipped for all.......except the SS brake lines. I found those from another member.
- Beamter
What is the current/stock center opening ID? I'd think that would be a piece of cake for almost any CNC machining system that has the capacity for the OD of the rotor.Duke wrote:Decided to buy new rotors ($33). Looks like getting the center opening machined to 3.250" is going to be a PITA. Several machine shops told me they could not do it.
So, when I find someone who can, it will be with new rotors.
The current ID is 1 7/8"Mark 88/M5 Houston wrote:What is the current/stock center opening ID? I'd think that would be a piece of cake for almost any CNC machining system that has the capacity for the OD of the rotor.
Machine Shops in Kansas.mooseheadm5 wrote:What kind of loser machine shop can't bore out a rotor?
We have movement!
Install day -
Left side before,
Right Side after,
Gotta get out and do the left side now. Once they are in place, I can take measurements for the brake lines and get them. I then need to tackle the parking brake cable modification and then attachment. Right now, will only have it on the left side.
Install day -
Left side before,
Right Side after,
- Beamter
Schweet...Duke wrote:We have movement!
Install day -
Left side before,
Right Side after,
Now I'll really feel safe when I get that ride.
Alpines are cool....much less moola to get into one too.slammin_e28 wrote:Awesome! I really wanna see this car!
BTW, that Sunbeam I mention in another thread....just an Alpine
Much more detail on the brake install here - http://www.sunbeamalpine.org/forum/show ... hp?t=15458
I learned much about cables (steel rope) and swaging attachments. Most sailing rigs use "swagless" fittings. This is so that can easily make repairs while at sea. I tried to use a swagless fitting but it turned out to be too long for my application.Coldswede wrote:Maybe you should take up sailing so you can make your own rigging.
I always dug Alpines, my dad loves them too!Duke wrote:Alpines are cool....much less moola to get into one too.slammin_e28 wrote:Awesome! I really wanna see this car!
Hey there's Duke in the backround with black smoking jacket and glasses!
Just purchased the heads! AFR 185 PN 1388 with "upgraded" springs from the guy in a previous post.
They have 3K miles on them and were on a show car. Got them and the roller rockers for $700 less than retail.
Will drop them off at my machine shop (yes, found one I can call mine) to be cleaned and check once they arrive.
I love Craigs List!
I love Craigs List!
