Page 3 of 5
Posted: Nov 03, 2009 6:21 PM
by T_C_D
Guys let's do a group buy on Clutch Masters. I just opened my account last week.
Who is interested and what level? I'll supply pricing tomorrow.
Todd
Posted: Nov 03, 2009 7:29 PM
by kipwinger
I'm interested in being a part of the GB but, it would probably be for the stage 1.
What would the time frame be?
Posted: Nov 09, 2009 7:22 PM
by T_C_D
I have spoken to CM again today. I am personally going to try a material called Fiber Tough. It's holding capacity is 70% more than the organic with much better capacity to with stand the heat from slipping than kevlar or metallic.
Posted: Nov 09, 2009 11:27 PM
by Shadow
I'm interested too but needs to hold 550tq
and still drivable. No pucked etc.
Posted: Nov 09, 2009 11:56 PM
by Brad D.
Shadow wrote:I'm interested too but needs to hold 550tq
Yup, same here. Unfortunately clutches can be cheap, streetable and hold the power. You get to pick two.
Posted: Nov 10, 2009 8:27 AM
by mart154
Big Bronze Rim wrote:Shadow wrote:I'm interested too but needs to hold 550tq
Cheap + streetable + hold the power
http://www.youtube.com/watch?v=DXepVDthxe0
1.7 @ 60ft for times and times.
I have used it on streets for about 3000km for now and no problems yet.
CNC machined M20 flywheel + m30 disk (with custom frictions) + audi S4 pressure plate.
pressure plate is mounted according to pressure test.
Does anybody know any SFI approved clutch setup for M20?
Local drag rules require SFI clutch, so I have to change it.
Posted: Nov 10, 2009 9:06 AM
by T_C_D
That's badass. 12.4 @ 112 is no joke!
Posted: Nov 10, 2009 10:27 AM
by turbodan
Cheap too?
Posted: Nov 10, 2009 10:41 AM
by Brad D.
The key is he had a custom disc made. There is a lot of grey area there that makes that whole setup work. I suppose it could be cheap, but it also might not work as well as his particular setup.
Posted: Nov 10, 2009 12:09 PM
by Good & Tight
For anything close or above 600ftlbs a Tilton 7.25" setup is the way to go. The problem is getting a flywheel that accepts this type of setup.
Posted: Nov 10, 2009 1:13 PM
by Jay Bee
for the m30 you can use the s36b36 flywheel.
Posted: Nov 10, 2009 1:42 PM
by Scottinva
Good & Tight wrote:For anything close or above 600ftlbs a Tilton 7.25" setup is the way to go. The problem is getting a flywheel that accepts this type of setup.
They are damnnn expensive though.
Posted: Nov 10, 2009 1:48 PM
by Good & Tight
Scottinva wrote:Good & Tight wrote:For anything close or above 600ftlbs a Tilton 7.25" setup is the way to go. The problem is getting a flywheel that accepts this type of setup.
eBay sells Tilton setups fairly cheap, but the flywheel needs to be machined to accept it.
Posted: Nov 10, 2009 1:50 PM
by Scottinva
Good & Tight wrote:Scottinva wrote:Good & Tight wrote:For anything close or above 600ftlbs a Tilton 7.25" setup is the way to go. The problem is getting a flywheel that accepts this type of setup.
Wow your right, thanks for the heads up. They have some amazingly cheap deals, I have been seeing $1000+ for these setups, they are a quarter of this on the bay buy it now.
Posted: Nov 10, 2009 2:10 PM
by Brad D.
In regards to the Tilton setup, what needs to be done to the flywheel? Can you can use discs for any 10 spline 1 1/8" input shaft (ie- GM)? G&T, you are using this setup. Would you say the multiplate Tilton is streetable?
Posted: Nov 10, 2009 3:22 PM
by Good & Tight
Big Bronze Rim wrote:In regards to the Tilton setup, what needs to be done to the flywheel? Can you can use discs for any 10 spline 1 1/8" input shaft (ie- GM)? G&T, you are using this setup. Would you say the multiplate Tilton is streetable?
This was a stock M10 flywheel machined for a Tilton setup, it was also lightened quite a bit . I bought it like this and it was actually a triple disc but was missing a floater plate and disc, they were nla so I had the cover plate legs machined down to use it as a twin disc.
Also modified the stock clutch fork to make it work and extended the master cylinder rod. Took me about 6 times taking the tranny in and out to make it work.
So far I have replaced the disc's once, still available through tilton. The GM splines are a touch loose and not recommended by Tilton, BMW splines are smaller.
Streetable? well not really with the cintered metallic disc's, engagment is instant and abrupt, but if you slip it too much it greatly reduces the life on the disc's.
I have not checked but there might be an organic replacement disc's that would make it more streetable.
Posted: Nov 13, 2009 3:18 AM
by mart154
Big Bronze Rim wrote:The key is he had a custom disc made. There is a lot of grey area there that makes that whole setup work. I suppose it could be cheap, but it also might not work as well as his particular setup.
Actually the custom disc is like stock. Only the chopper content is a bit bigger in the frictions. The disc mod cost lika $40 or something.
Audi pressure plate is ~$150 here. (Stock, not SRE)
CNC machining the flywheel might be expensive
I have good friends that helped me
Posted: Nov 23, 2009 12:46 PM
by Brad D.
Well, as of this morning I have one of CM's "Fiber Tough" clutches coming from Todd. It should hold 450ish ft-lb of tq atw and still be streetable. I am excited and am looking forward to being able to turn up the wick. A full review will be forthcoming in a few weeks.
Posted: Nov 23, 2009 12:53 PM
by Russianblue
so what's the 'fiber tough' reference?
Posted: Nov 23, 2009 2:05 PM
by Brad D.
It's one of the materials that Clutchmasters makes their discs out of. It's supposed to be comparable to the Kevlar disc as far as holding ability and streetability but be a bit more tolerant to heat. FWIW, It appears that most of their Porsche offerings are made of it. I believe that Todd ran the same clutch on his car when it made 440wtq and ran a low 12 second 1/4 mile.
Posted: Nov 23, 2009 2:18 PM
by Scottinva
Then more videos with more boozt? Oh yes plz!
Posted: Nov 23, 2009 2:40 PM
by Brad D.
I'd like to have it all ready to go for a late December dyno day.
Posted: Nov 23, 2009 2:50 PM
by Scottinva
No dyno videos, I hate the noise lol.
Posted: Nov 23, 2009 7:24 PM
by Jeremy
Big Bronze Rim wrote:I believe that Todd ran the same clutch on his car when it made 440wtq and ran a low 12 second 1/4 mile.
I'm pretty sure that was the UUC organic. Whatever it was, it's still in the car and holding up reasonably well considering the abuse it took at the strip.
Posted: Nov 23, 2009 7:50 PM
by Brad D.
Jeremy wrote:Big Bronze Rim wrote:I believe that Todd ran the same clutch on his car when it made 440wtq and ran a low 12 second 1/4 mile.
Hopefully Todd will chime in and confirm or correct me, but since I'm pretty sure thast CM made the clutches for UUC I would guess it's the same disc.
Posted: Nov 23, 2009 8:32 PM
by T_C_D
I believe what UUC calls the performance organic uses the fiber tough material.
Posted: Nov 23, 2009 8:48 PM
by Shadow
http://www.clutchmasters.com/shop/?page ... &AppID=559
Claimed 110% over stock.
So let's say you get a pretty good 200tq to the wheels
N/A. That's only 420tq
You would think "clutch masters" would have something that held a little more then that.
Posted: Nov 23, 2009 10:07 PM
by Brad D.
Well, Todd's car is a good indication that it'll take the abuse and hold.
Posted: Nov 23, 2009 10:33 PM
by Scottinva
I believe I looked up Brad's current clutch and found it to hold a maximum of 250torque, and he drives it daily without issues, at about 300torque if i'm correct. I guess they are being really safe with their calculations.
Posted: Dec 10, 2009 6:36 PM
by Brad D.
