Page 3 of 4
Long overdue update - EXHAUST
Posted: Aug 09, 2010 4:10 PM
by SpongeBob
Finally got her back from the fabricators - and I could not be happier - they did a very very very nice job,
Hightlights include -
1 turbo down pipe with vband and O2 port
2 waste gate mounting and down pipe
3 exhaust including high flow cat and magnaflow muffler
4 flanged in "test pipe" for running w/o cat
5 wastegate pipe merged into main pipe
6 cold side intake pipe - cleananced around AC compressor
7 hot side dump pipe to intercooler - clearance around AC compressor
8 3" exhaust
9 post intercooler up pipe to blow-off valve pipe
Posted: Aug 09, 2010 4:16 PM
by George
Boooooooooooo for kink bends.
Posted: Aug 09, 2010 4:21 PM
by cvillebimmer
What's the logic behind putting the dump pipe so far down stream?
Posted: Aug 09, 2010 4:27 PM
by George
cvillebimmer wrote:What's the logic behind putting the dump pipe so far down stream?
Post Cat.
Edit for the actual logic. When the WG opens up, thats the hottest exhaust coming out, dumping it into the exhaust stream after the cat reduces the back pressure seen by the turbine wheel.
Posted: Aug 09, 2010 4:34 PM
by cvillebimmer
Thanks for the explanation. Never seen that before.
Posted: Aug 09, 2010 8:36 PM
by Black Steel
Love the engineering that has gone into this.
Your all very luck to have the steering wheel on the other side
Posted: Oct 11, 2010 12:32 PM
by Adam W in MN
Updates??
Oct 2010 Update
Posted: Oct 17, 2010 6:16 PM
by SpongeBob
Posted: Oct 17, 2010 9:47 PM
by George
Your garage is cleaner than my living room.
Posted: Oct 18, 2010 6:36 PM
by Black Steel
Looking sweeeet
Your doing the best thing. While you can get to it, it's best to do all the cosmetic work.
Posted: Oct 20, 2010 9:11 AM
by T_C_D
Looks great. I am really looking forward to the results!
Posted: Oct 20, 2010 12:40 PM
by Brad D.
T_C_D wrote:Looks great. I am really looking forward to the results!
x2
Posted: Oct 20, 2010 12:59 PM
by George
Would the stock steering components worked if the turbo had not been in the way of the idler arm? Or were there other problems that arose?
Stock Steering....
Posted: Oct 22, 2010 1:48 PM
by SpongeBob
I think the answer is yes - w/o a turbo on the passenger side - the stock stuff should work.
The only challenge - would be the S52 exhaust - there are a lot of headers (ebay to big dollar Supersprint) for the S52, but getting them to work in an e28 engine bay might be a challenge.
I did think about going NA on this motor - but I live at 5000 ft and am already giving up 15 to 18% on a healthy engine - so FI was the only choice.
SBSP
Re: Stock Steering....
Posted: Oct 22, 2010 3:01 PM
by George
I was thinking more along the lines of giant top mount turbo + s52
Posted: Dec 11, 2010 12:47 PM
by itsbrokeagain
I spend 20 minutes looking for this thread lol...Im quite interested in the steering rack setup so I can ditch the steering box assembly. I ditched the turbo project and sold off the parts (still have the engine) and I plan on stuffing 2 more cylinders in the engine bay.
Posted: Feb 09, 2011 8:01 PM
by stratos
This is an amazing project! Really looking forward to the results!
Update Feb 11
Posted: Feb 10, 2011 9:58 PM
by SpongeBob
OK - it has been a while, but I have been working on my sled. Work has been a cast iron biotch - nothing better than work in high tech sales - where they cut the work force by 15% and you expected to take up the slack - I feel like I am being punished for being a survivor.
Recent updates include -
1 Wrapped up the power steeing plumbing with cooler and adjustment valve. This was multiple trips to the local "tubes and hoses" guy - having special lengths made. The adjustment valve needed to be mounted - so I had to make bracket - to mount to the block. The power steering cooler needed to be modified and mounted to the subframe.
2 Wrapped up the oil cooler - same deal - a few trips to the "tubes and hoses" guy to get it right.
3 Had to make a bracket to hold the idle control valve because I am using the e36 M52 idle control valve and an e36 M50 intake - and it needed to well placed because the starter and input/output ports needed to line up with the input port on the manifold.
4 Made a brackets for the dip stick - because I am using a e34 M50 sump, an e36 M50 intake manifold and a e34 dipstick - and required a fabricated bracket so it would work.
5 Made hold downs for the fuel rail - because I am using an e36 M52 rail with an e36 M50 intake.
6 Installed a turbo blanket for the hot side fo the turbo. Wrapped the turbo exhaust and waste gate tube.
7 Had a local paint shop make up can of BMW White (fill in the fancy name here). Prepped the front end for paint, filled in the holes in the grill area to accomidate euro bumper install. Did the body work - filling in the holes, sand, sand, sand, primper, sand, sand, sand, more body work, sand, sand, sand, primer again, sand, sand, sand, primer, sand, paint, sand, paint. Turned out way nicer than it needed to - it is 80% hidden by the bumpers. Stupid me.
7 Installed the engine back in the car last weekend with limited drama. A very good sign - my buddy came over and helped me and was surprised at the lack of "banging and slamming" required to install - I explained I want to run OLOA and having to work hard to do an engine fix in a remote location sounds like no fun - so if it does not work at home - I am screwed.
8 Revamped the turbo return oil line - more trips to the "tubes and hoses" guy. I am sending 1 of his kids to CSU this semester.
This weekend I will get the remaining balance of the stuff installed on the engine and start final fuel system installation.
See images below....enjoy.
Posted: Feb 11, 2011 4:00 AM
by Black Steel
Looking clean, tidy & detailed. Just the way I like to do things.
Don't rush it. Get it write first time.
Posted: Feb 12, 2011 2:47 AM
by red535t
that looks fair dinkum hot mate
a very clean looking engine setup
kudos to you spongebob
Posted: Feb 12, 2011 6:37 AM
by rjteeter
subscribed.
Posted: Feb 12, 2011 6:00 PM
by misha
That is a truly epic level project. Something for all of us to strive for.
Can't wait for more updates and for you to finish it.
Posted: Feb 23, 2011 12:52 AM
by Alfonso Bedoya
FREAKIN SHAGADELIC! YEAH! BABY! YEAH!
e28 528e
Posted: Feb 24, 2011 9:42 PM
by edlocke
Incredible
Update April 11
Posted: Apr 10, 2011 11:01 AM
by SpongeBob
Posted: Apr 10, 2011 11:13 AM
by Duke
Very nice.
I am a BIG FAN to attention to detail and you are there brotha.
Posted: Apr 10, 2011 2:43 PM
by T_C_D
Looks great! Did you push it or drive it out for the bath?
Posted: Apr 10, 2011 3:57 PM
by Nebraska_e28
Will the 528e badge stay? Hell, can you say ultimate sleeper?
Posted: Apr 11, 2011 5:11 PM
by E.rouzbeh.28
You should keep the badge. Next time you go to a BMW track event you should take a picture of the faces of all the M3 and M5 drivers when a "525e" passes them. You have done a great job. I may be doing this soon and this is a great source of information.
Posted: Apr 21, 2011 3:13 AM
by 528elover
Amazing! A think of beauty! Nice work!
