Dieselboost's 524Compound Biturbodiesel
DieselBoost
Post by DieselBoost »
Engine timing for dumb people...
First check that your crank is on position O/T
next check that your cam is on this position...
use that square on cam to line it
Then try put your injection pump lock pin to place
Injection pump can be 180degrees wrong.. so if car does not start you can try to turn it...
and remember remove lock pin before you start :laugh:
Have you considered upgrading to an MLS? Do they make em for the TD's?
I love ghetto 'let's not take ourselves too seriously' style mechanics, that's the most fun. Great projects!
Das_Prachtstraße wrote:Have you considered upgrading to an MLS? Do they make em for the TD's?
Me too. As I am one. When I don't have time working against me on avehicle I need immediately the last two days making the frankenshaft and installing front bilsgeins in my boys car Was good fun.
DieselBoost
yes... and my friend has mls in hes 524td...
no problems with 2.6bar boost and with very high performance ip
but these are quite hard to get for m21 engine...
DieselBoost
Now i have mls gasket... so no more exploding gaskets...
vexu524tdic
Post by vexu524tdic »
Hope this solves your problem, as it did mine's.
Did you get any video or pics of my 524td on track day?
DieselBoost
vexu524tdic wrote:Hope this solves your problem, as it did mine's.
only few good pics and those are from that e30 m3 turbo racecar...
i will upload some videos soon... but only that m3
it is shame that i dont have pics of your 524...
but maybe next time... maybe dynodays or that 1/4mile event which i told you...
but nice to see you in here... welcome :D
Welcome New Member, new member's car pics, in your own thread of course, are mandatory, read the FAQs. ;)
Neel
Post by Neel »
Fuel wrote:I demand a video of blowing some smoke ;)
I second :)
DieselBoost
I second :)
Maybe tomorrow... when i get my engine running with new parts
Five two eight eye
Post by Five two eight eye »
Sweet :cool: :haul: :haul: :haul: :haul:
Awesome!
DieselBoost
Crap!....
little problems with head bolts... but operation will be continued
DieselBoost
New m51 bolt compared to m21 bolt
DieselBoost wrote:Now i have mls gasket... so no more exploding gaskets...
:up:
CoyoteStarfish
Post by CoyoteStarfish »
I'm going to need one of these MLS gaskets. And a set of M51 head bolts. Mmmm... Can't wait!
DieselBoost
Im starting to make new exhaust manifold for my engine....
i sold my older one to my friend...
this manifold will be copy of Herlevi's Valtra pulling tractor exhaust manifold
Like in this http://irc-galleria.net/user/Laskeuma/picture/102080331
DieselBoost
Collector welded for cylinders 1 & 2
New turbine chamber for my turbo, bit larger than old one
Old was a/r 0.63 single inlet, this new is a/r 0.84 dual inlet
Me and my little turbo, now you can realize how large is turbo for 2.4litre diesel engine which have power goal of 350hp
and this turbo actually spools in about 2000rpm
DieselBoost
Project continues with new exhaust manifold, finally i got welding machine to adjustments...
It will be something like this...
i will make two collectors more for 1&2+3 and 6&5+4
and i will lift turbo a bit
CoyoteStarfish
Looks like an angry octopus with only 6 arms...
Love it.
Handsome devil, if you ask me. (yes homo)
DieselBoost
Few quite old pics... but i like these...
you can see how opel ascona c irmscher rear wing fits to e28
little fixing in future and it is perfect
DieselBoost
Project goes on....
few part where quite tricky to get on right place...
i did little mishap with measurements... so manifold is little bit too far from the engine... but i tried it to the car... and it fits...
i can still make final collectors turned little bit to the engine...
this way turbo will be in correct place...
DieselBoost
little progress with my manifold
Aamir_bt
Post by Aamir_bt »
this project is awesome! i was just thinking the other day if anybody was actually doing any kind of E28 diesel build, and that it would be kickass if someone was.
will be checking in for updates.
DieselBoost
we have one quite angry one...
http://youtu.be/PWAt_Lhe8lc
Tasty!
DieselBoost wrote:we have one quite angry one...
That is pretty bad.
DieselBoost
Ok... moving on with my project...
im working with my exhaust manifold and with little bit better finishing quality...
I tested these 1-2 pipes with paint... it looks quite good
DieselBoost
Almost ready... 1-2-3 welded up with collector...
only 1 collector and turbo flange + waste gate lines and it is ready!
