I had hope, but I guess I was wrong. In saying this, it is abundantly clear that you just don't get it. What Ray suggests is that you equip your car with tires that make the traction limit lower and less sharp. That way, you can learn about transitional handling. You know: that place between "massive understeer and snap oversteer". Camber correction won't teach you a damn thing about that because your tires prevent it by giving you more grip than your experience can deal with. OBVIOUSLY, a lifetime around racing and one autocross event hasn't taught you much more than my not-yet-driving 11-y-o daughter with her similar background. Unless you plan on a lifetime hobby of idiot-proofing your cars so they'll cover up every ham-fisted mistake you ever make (not to mention writing off a couple along the way), you should figure out how to drive your car as it is before changing it.jcbe34 wrote:haha no thanks. If you are trying to tell me that stock suspension and bottlecaps is a better setup that coilovers and aftermarket wheels and tires I'm going to respectfully disagree. I Somewhere along the way I'll probably end up learning how to drive the damn thing. I appreciate your analogy though!rlomba8204 wrote:Try this because it will be cheaper and easier and you will learn more: Get a set of 15 inch bottlecaps. Mount 205 tires. Sort the stock suspension and make sure everything is sound. Then go drive the car again and go slow to go fast, preferably at a HPDE. I suspect your conversion will be as stark as that of Saul on the road to Damascus.
Incremental progress is the key to developing a good feel for automotive handling dynamics. Your analysis of what's wrong with your car (as opposed to what's wrong with how you drive it) is as sophisticated and valid as if you'd climbed into an Indycar and drove one day - which is to say, not much. Learn to drive slow cars fast. Then you'll be better able to drive fast cars fast.
