Paul B - what do you reccomend for a head gasket?......
George
Post by George »
turbodan wrote:Theres no way an M20 turbo could get away from an LS1. Its unpossible.
Didn't yours pull away from a 335 with ease? I think acceleration times are about the same arent they?
Entropy_Engineering
Post by Entropy_Engineering »
It may have been a 5.7 GTO but it's no bull. I've seen it pull (admittedly) to my suprize an LT1 z28 on the "e" head. Do the math. X amount of boost generally makes X power with X configuration. Launches with a 3.73 LSD. Vehicles weigh this much. Perhaps the driver shifting gears in the other lane is slow to the draw. I will admit that it has a bit more lag from a stop now because we removed and welded on a tooth on the trigger wheel to retard the timing, but it certainly pulls pleasantly from a low roll on. I vividly recall it pulling a new STI as well, but again, consider the power and weight (and pray for no corners).
Entropy_Engineering
Come to think of it, I drive an '81 928 with two 2.25 y-pipes into a single open 3" exhaust (it's loud) that I estimate 250ish at the crank. I have a weight advantage (distribution and overall) at about 3150 empty, close ratio 5 speed, and better traction. Last time we raced for fun I got destroyed once he got moving. Need my own forced induction damnit. Tired of building quick cars for everyone else.
Mine has pulled a lot of cars. I was just keeding.
Entropy_Engineering
Sorry for hi-jacking the thread a little. TurboDan, you ever break that stupid aluminum bracket for the motor mount on the passenger side? I'm about to make a steel one as I've had two break on different cars/occasions now.
I've never had a problem with the motor mounts. I've destroyed subframe bushings and guibos, but motor and trans mounts haven't given me trouble.
