Most of this language isn't applicable any more.
Ok, now I'll stop whining.
Fedaykin528e wrote:This.
Not trying to convince anyone...just stating an opinion from the standpoint of having lived through the whole experience. Heck, from a performance standpoint, my 72 Bavaria easily out-handled and out-performed the E28 M5 when it came out (speaking from direct experience on track at Summit Point against friend's M5 and M635CSi back in the day).M. Holtmeier wrote:You're going to have a hard time convincing anyone on this forum that an e90 m3 is better than an e28 m5.
I don't necessarily agree with everything here, but I bought my E90 Sport because it specs out so similarily to the E28 ///M5. Its not near as engaging to drive though.CSBM5 wrote:Fedaykin528e wrote:This.
Having bought a 1985 535i (5spd, LSD) in 1986 when it was almost new, I don't see how the language isn't applicable anymore. If anything, it's the inverse in most all regards. The 535i was for my wife's daily driver as our first kid was born since we wanted something safe (first year of ABS, good crash design of E28) and fun to drive. However, a totally stock 535i needed help right away in our opinion hence it got the (new at the time) adjustable Konis, Dinan sway bars f&r, and 16" Rial wheels (to ditch the awful TRX junk). My daily at the time was a heavily modified E21 and an even more modified E3 Bavaria.
Today she's been driving an E90 330i (loaded up with most everything but still with a 6MT) for almost 8 years now, and it is a great car. Loads of fun to drive, excellent sport package seats, faster than an E28 M5 and much better handling, gets 32-33mpg at 75mph, 0-60 in 5.6, 99mph trap speed in the 1/4 -- the most interesting part of that car is it is the most reliable car I've ever owned. With 119k miles on it now, it's been 69k miles since the warranty expired, and has only required a door lock actuator, valve cover gasket, and oil filter housing gasket.
Perhaps I'm just skewed in my view of "modern BMW" to some extent (although I've been a BMW fan since 1971) since I attach most of that view to my E39 M5 and E90 M3. The M3 is an incredible machine. I've done one mod to it (Dinan front sway bar) for F-stock SCCA tire class autocross, and the car is unreal on course. The S65 torque curve is perfect as it can really put down the power coming off elements and hits so damn hard up high, but he progression allows it really shine. It's a blast to drive, by far the most fun, stock, BMW I've ever owned/driven although the E39 M5 is a close 2nd.
Drive an E90 M3 like it's meant to be driven...the language (mentioned above) is far more applicable than it was in 1985.
http://www.bcables.com is an inexpensive solution to full diagnostics and coding capability. Autoenginuity also has a full featured solution that I've used for years now.Murfinator wrote:Especially the over-complexity of the newer models often necessitating a trip to the stealership for diagnostics because many of BMW's trouble codes show only generic descriptions on standard readers.
So tell me more about that cable. With an E36 and E39 in the stable OBC is a reality and useful, but vague. Would I really need the early adapter for an OBC II car with the round plug too? Any additional software or does it come with all of it? Looks interesting.CSBM5 wrote:http://www.bcables.com is an inexpensive solution to full diagnostics and coding capability. Autoenginuity also has a full featured solution that I've used for years now.Murfinator wrote:Especially the over-complexity of the newer models often necessitating a trip to the stealership for diagnostics because many of BMW's trouble codes show only generic descriptions on standard readers.
I lived through the transition from carbs to FI and bitched about it like a baby 35 years ago; now in my 50s I've totally accepted and gone with the flow of modern systems. It's really not that complicated for 99.5% of stuff (like how the internet makes battery registration sound like a disaster when in fact it takes one mouse click in either of the above).
Can't comment on the E36, but on all my current cars, I simply plug into the OBDII port and connect to the car in the s/w. I've not done any coding yet in NCS Expert, but at some point plan to enable Euro MDM mode in the M3...it's apparently just one click and a write command.Mike W. wrote: So tell me more about that cable. With an E36 and E39 in the stable OBC is a reality and useful, but vague. Would I really need the early adapter for an OBC II car with the round plug too? Any additional software or does it come with all of it? Looks interesting.
I've been wanting to draw the exact same comparison to the carb/FI thing on this matter as well but have been too lazy to type on my phone that much.CSBM5 wrote:http://www.bcables.com is an inexpensive solution to full diagnostics and coding capability. Autoenginuity also has a full featured solution that I've used for years now.Murfinator wrote:Especially the over-complexity of the newer models often necessitating a trip to the stealership for diagnostics because many of BMW's trouble codes show only generic descriptions on standard readers.
VW has a similar system, it's now known as VCDS, formerly known as VAG-COM. For many DIY services, it's a must have, down to simple stuff like rear brake pad changes (there's a function in the software to retract the rear caliper, this is a result of a few unnecessarily complex bells and whistles in the braking system).Mike W. wrote:Interesting, I should probably get one now before my next E39 abnomality, like Internal memory module checksum error like I got a few years ago. Must be a huge program, needs 20 or 40G HD space depending on how you set it up. I wonder if my old laptop is fast enough, I do have plenty of HD room though. Thanks!
