Blunttech / Classic Daily S85 V10 E30 M3 Swap
jakeb
Post by jakeb »
Lubehead wrote:Do you know the weight of the V10 and tranny compared to the original engine and trans?
I'm not sure on the trans weight but s14 vs s85 is about 200lbs. The s85 is far from a small engine.
jakeb
Post by jakeb »
So to limit the amount of oil pan that has to be cut we are going to mount the steering rack as tight as possible. We are using a 2.7 turn Z3 rack and moved the lines to the top/front of the rack rather than the front. As seen here.
To mount the rack tight as possible the subframe is also the mounting spot. This started as 2" - 0.25 wall box and was cut down into a C. A few spots had to be notched out to make it all fit around the rack. This was cut witha plasma and still needs to be cleaned up a little.
Bolted to the jig
Starting to connect the dots
Trimmed down and more pieces tacked in.
Out of the jig
In the car
About how much will need to be trimmed from the pan.
Now this subframe is FAR from done. It will get a lot more reinforcements but we are still at the, "lets make it all fit" stage.
Pavel
Post by Pavel »
:shock:
:mindblown:
There must be a great heater in the shop. :up: :up:
jakeb
Post by jakeb »
the current shop has a 100k btu gas heater. It does the job but I keep it around 55 when working in the shop.
I actually am moving to a newer space soon....It's going to be nice to have a TON more room.
Here is a picture of the soon to be new shop. This is about 2/3 of the space.
jakeb wrote: Here is a picture of the soon to be new shop. This is about 2/3 of the space.
How will you ever get anything done in there. I'd get lost. :banana: Freakin' awesome though... :shock:
Bravo on the progress and congrats on the shop!
jakeb
Post by jakeb »
Here is one more....
There is a little more on my site, www.classicdaily.net . I post the updates there a couple days before hitting all the forums.
Also updates on instagram as I do work. @classicdaily
Harv
Post by Harv »
Kick Ass!
John
Mr.3-5-7
Post by Mr.3-5-7 »
word to the wise, replace the starter while the engine is still out of the car. And do all the gaskets now.
Great work, keep it up.
jakeb
Post by jakeb »
Pulled the pan to cut it apart.
Engine is VERY clean inside.
Time to cut the pan...
To keep it sealed up
This picture is without the trans on. The pan actually sits closer than this to the subframe/rack mounting.
The trans tunnel had to be opened up in one spot to get things to fit better.
A little bit of heat and a hammer did the job.
Getting closer to it's final home
jakeb
Post by jakeb »
A bit of a slow down with all my projects while I was moving to my new shop. Things are finally moving ahead again so it's time I update some build threads...
First of all the shell was moved from my home shop to a much bigger space. Let me tell you moving this car was nothing sort of scary. I am sure it was well more secure and nothing was going to happen.
Some pics of it's trip.
made it....
Back on a lift..
Working on the toe and camber adjusters on the rear subframe.
I didn't like how much was unsupported so I extended it some.
Freshly powdercoated bits
reinforcing trailing arms
A couple pictures of what has been holding things up...
New shop
and a new toy...
this thread delivers
I don't have a clue where to start for this kind of fabrication but reading through the updates in this thread are always impressive.
ACHTUNG
Post by ACHTUNG »
You must be loving the new shop. Tons of room!
jakeb
Post by jakeb »
Steve flew in to do some work on the M3 last week....
Got the bottom all re undercoated.
Before
After
Fresh rear subframe and painted diff bolted up.
Subframe in and trailing arms bolted up..new bushings, bearings, etc etc etc
undercoated in the wheel wells too
New brake and fuel lines run
Gas tank ready to go in
Delivering again. :up: :up:
Eddie in TO
Post by Eddie in TO »
excellent! :alright:
jakeb
Post by jakeb »
Well the subframe from before was a bust.... The z3 steering rack was wanting to be in the same spot as the header. So we start again.
The engine about in it's final location
This is the e30 m3 rack rotated slightly down to clear the header.
Rack in it's new home in the subframe jig.
Bending a piece to connect the dots
Trimmed down and tacked together
Testing and ears for rack
Boxing it in
You can see a piece of bent plate going under the pan here. This piece was fun to make.
Tacked together
Clearance to the pan...around 1/8-1/4"
Out of the car
I really like how this part came out. Some little open holes still.
Before (opposite side of after pic)
After
Still more cleanup needed.
Entire thing before welding...
Also if you are going to vintage in NC this coming weekend this car will be there. Not done but it will be there to check out.
I can't wait to see this.
oldskool wrote:I can't wait to see this.
Me too. Doesn't sound like we'll get to "borrow" it though. Shucks. :cool:
I drove the E12 last year. :D. Maybe next... ;)
jakeb
Post by jakeb »
Yeah sorry guys...won't be running or driving this year. But come on over and check it out.
Pushing over the next couple days to get it rollable.
:rofl:
i'd love to at least get a ride ;)
But admit it; just like the rest of us, you'd prefer to be behind the wheel. :haul:
jakeb
Re: Blunttech / Classic Daily S85 V10 E30 M3 Swap
Post by jakeb »
This update is from a few weeks ago but just finally getting around to uploading all the pics and posting.
Welding the new subframe up.
Starting on mounts
drivers side
These will be fully boxed and also a new set of plates will be drawn and then water jetted. These are the mock ups.
Subframe with mounts welded on
And with both mounts connected. All this will be powder coated
Steering clearance
Adding another joint
And a locator
This is JUST a MOCK up. We needed to have the car movable to take to a show so this locator mount was just tacked on so the car can steer. There will be a stronger more elegant solution once the engine comes back out.
Rebuilt rear axles
A quick shot from the front.
The coilovers are turned all the way down here and there is about 3-3.5" here. Yes it is close but the air boxes are about a 1/4" from the hood.
Here it is at the vintage in NC a couple weeks ago.
Also it is looking VERY good that we will be using the stock DME. nando has been working on cracking it and it's looking like it's gonna happen.
L_N_Love
Post by L_N_Love »
You are a BMW wizard.10 throttle bodies in an E30. Blows my mind!
:bow:
ACHTUNG
Post by ACHTUNG »
Craftsman...
John SCB
Post by John SCB »
Un f-in believable. Go man go.
