TheLazyDog wrote:tn535i wrote:Sounds like it's driveshaft related to me. I thought I heard it chage as you load or unload the drivetrain. Rain and other pavement conditions may mask the noise but I bet it's still there.
That sounds very likely. You are right, it is always there. And it does feel like it changes with drivetrain load.
steve 87 535is wrote:I seem to agree with driveline related. Tranny whine, shaft bearing or diff noise??
Is it more noticable in third gear or does it happen in all gears?
It is not any more noticeable in any single gear.
I'm good as convinced it is the driveshaft. The support bearing or something. If Kyle were here I think he'd tell me to replace the whole driveshaft... is that about right?
Is there anything I can do to check and make sure it is driveshaft related?
how do you go from "rubbing the strut" to driveshaft!?
as steve said, put the rear wheels up and spin them. I actually did this "test" to pinpoint noise and it helps a lot.
do it first with the heat shield in place, that bugger can hit the drive shaft and cause noise that you probably wouldn't ever think to fix, well especially you, you probably would blame it on the wipers or something.
under load, everything moves just a bit--so you have to take that into account too!
so get under your car, and start from the front. check your motor mounts, then check your transmission mounts, check your shift linkage, check your exhaust "hangers", then spin the rear tires with the car off and just listen carefully to "rubbing" noises. if it's not your csb, it could be your trans or diff--but listen carefully.
then test with your heat sheild off. have fun getting those bolts off and don't lose them--they're a special type.
after that--do your trans and diff fluid, drive around and see if it's happening still.
