Sbeckman7's Project: BR1
Great news today: My metal has arrived! I got it at 10 this morning in San Rafael, then drove home with it in my friends pickup. It's a lot of metal. Anyway, once I got that put away I began cleaning up garage space to start cutting the floor tubing. My friend needed the welder back for a few days, but I'll be cutting my material for a while Anyway. Here are some pics.
I was worried that the massive bell housing from the v12 would cramp my foot room but I ended up with plenty of space.
my wonderful 535i in the background
The wheels are dialed in at full camber
You can see why I needed to do some cleaning.
Mock-up floor plus leg shot from a very determined friend. He's been working out.
The seat is mounted on the same level as the top of the rear subframe mount, which is 5" higher than the dip in the main side pipe. Visibility is much improved and the car still looks proportional!
Bag O' Wires, pedal set, and one massive alternator. I weighed the wires at 60lbs and hopefully I'll be getting a much smaller/more efficient alternator as well. I believe it will be fairly to modify the e32 pedal set to accommodate the e28 clutch pedal. More on this later.
e32 steering column, weighs half as much as the cast iron unit from the e28
The little band saw I got off Craigslist... Hope it works well!
And finally, lots of metal! If you squint really hard, it sorta looks like a car...
Hopefully I can start cutting tomorrow.
These may very well be the last set of Renderings that I post. I don't think I'll need to work on this CAD model any more as all the dimensions for the frame and engine fitment are complete. The only things I may need to add are the engine mounts, but everything else is as it will be on the final product. I may also update the model with a set of 17" style 5's if I feel like it.
Tammer in Philly
Tammer in Philly wrote:That design is so, so much better than your initial drawings and ideas. I commend you for accepting constructive criticism and asking questions. Now hurry up and finish the damn thing. I wanna drive it!
-tammer
X 1 billion.
It all looks really good, and am eagerly awaiting progress!
Tammer in Philly
Well, I can show you what the Caterham does.
There's only one continues piece of metal going from one side of the car to the other, and it's at the back (bar closest to the diff in pic 1). There are no others that go across the whole car at the bottom of the trans tunnel, there's one at the top at the front, and some braces between the two sides of the tunnel...
So in short, make the ones that go down the tunnel (not across the car) the uncut ones.
Picture 1, diff area, one brace (furthest from diff) and one solid that continues along the whole width of the car.
Picture 2, the front of the tunnel, just the transmission mount (which I'm sure is structural) and another brace between the two sides.
So in total, 3 braces, and one bar at the bottom that goes all the way across... of course there are more, but no need to fill this thread with those pictures... and I'd need to take them anyway, and most of the frame is hidden by aluminium.
Hope this helped... even just a little bit
So I successfully created a hybrid e28/e32 pedal assembly using the gas and brake from the 750 and the clutch from the 535i. It was actually really straightforward; all I needed to do was to swap the bolt that the pedals pivot on (for the longer one) and stick the e28 clutch pedal on. Then I had some clearance issues with the oversized 750 brake pedal so I decided to make it the same size as the e28 brake pedal. And now I successfully have an OEM 3 pedal set.
e28 assembly on top, e32 below
e32 brake pedal too big
my cutting template
cut e32 vs e28 brake pedals
back of pedal
new pedal set
still need to adjust clutch throw... I accidentally broke the spring assembly trying to adjust it so I may need to order a new one.
my cutting template
back of pedal
new pedal set
The spring doesn't adjust clutch throw. Once the clutch master is in place the pedal will be at the correct height within a cm or two. After that you use the eccentric bolt that the clutch master pushrod mounts on to set the free pedal height. Use an adjustable stop on the floor to limit the clutch pedal movement downward. That spring is just an overcenter helper spring. Don't mess with adjusting it.
Good to know. I will replace the broken part when I make more progress on installing the clutch down the road.mooseheadm5 wrote:The spring doesn't adjust clutch throw. Once the clutch master is in place the pedal will be at the correct height within a cm or two. After that you use the eccentric bolt that the clutch master pushrod mounts on to set the free pedal height. Use an adjustable stop on the floor to limit the clutch pedal movement downward. That spring is just an overcenter helper spring. Don't mess with adjusting it.
I was watching an oldish Top Gear just now, and this comparison popped up.
http://www.youtube.com/watch?v=8bhnE2rAWuA
From the dimensions of your project I'd imagine it'd be closer in performance characteristics to the Veritas than to the R500. The Veritas has slightly more kit too... little bit more luxurious than the Caterham.
Any more updates?
Any more updates?
Well today is a bit of a happy and sad update
At 1pm I will depart for Australia. I've been planning this trip with my cousin from Connecticut since June and it's finally about to happen. We will be in Sydney for the first week and will spend the remaining time working on a watermelon farm in Bundaberg, a city about 800 miles north, still on the coast. We will travel after work to other areas of Australia as well as New Zealand, returning sometime in February. So this will probably be the last post for several months
Here is my new welding helmet and gloves I got at cyberweld.com, as well as the metal cut for storage in the garage.
I'll be in touch.
Spencer
I'll be in touch.
Spencer
I had to write something.
Australia has been an amazing adventure. Sydney is amazing and the work on the watermelon farm in Bundaberg paid well for the 6 weeks that I was there. I'm back in Sydney now with my cousin to plan our next leg of the trip: the fun one. We will be taking a diving course next Wed-Thurs to get our Diving Licenses that enable us to scuba dive anywhere in the world. Friday we leave for Adelaide and Melbourne... In my new car! Bought a '94 318i with a 150k miles on the clock and a 5 speed for $1500. It's such a fun car. Here are a few pics:
After Melbourne/Adelaide, my cousin heads west and I return to the Sydney area, possibly to work for a family friend at his mechanic shop for a few weeks. We'll finish Australia up north sometime mid to late Feb and I return home after that.
In terms of the project, there obviously isn't much I can do on it from here but I've still been thinking about it pretty much every day. In terms of the stripped V12, I have two options. Option 1 is to clean it quickly, throw it back together, and run the M70. Option 2 is to leave the M70 alone and purchase an M73. This is something I will want to do sooner or later Anyway, I just don't know if it makes sense to do it now or wait until I get the car running on M70 power first.
The M73 for sale is from the same guy I'm getting the transmission setup from. Here it is with the tranny attached:
All in all, that's about it. Can anyone else think of stuff I need to spend money on but haven't thought of yet? This list so far is:
Parts Needed:
-850 CSI Radiator (Nissens, Behr, Performance Radiator, Silla, Zionsville Autosport)
-Honeycomb floor material
-Fiberglass
-LED’s and light system
-Speakers/wiring system
-Microsuede for interior trim
-Tilton Pedal Assembly
-Analog Gauges (VDO, etc.)
-Steering Wheel (Momo Mod78/88 or Nardi or Personal)
-Engine chip (if I "need" it)
- Wheels/Tires
- Exhaust fab w/ bike mufflers
Tools Needed:
-Torque Wrench (Teng, Norbar)
I'm just trying to come up with a budget plan. Did I leave anything out?
Parts Needed:
-Fiberglass
- Wheels/Tires
Tools Needed:
I missed this thread somehow since before your October updates. I've been wondering about it over the past couple weeks. The design looks great and I'm excited about the progress. I agree with Tammer about hurrying the hell up.
I also still think you should have stayed with the m30, but I'm much more confident in the v-12 now than I was when you first suggested it. Even an s52 would have been fun and maybe easier.
A few costly items that I can think of off the top of my head are:
hard lines for brakes/clutch hydraulics
hard lines and rubber for fuel
associated clips to mount the lines
spare rear tires
spare rear tires
Thanks for those! Yeah, I know man, pretty much any other BMW engine would have done the job. But, V12!!! It sounds like heaven...tsmall07 wrote:I missed this thread somehow since before your October updates. I've been wondering about it over the past couple weeks. The design looks great and I'm excited about the progress. I agree with Tammer about hurrying the hell up.![]()
spare rear tires
And hell yes, speakers. I need something to listen to on my road trip from SF to Indianapolis besides constant explosions
Pfftt, speakers are over rated... so are doors, sound dedening, windows, comfy seats, being out of the rain, snow, sleet, hail, and mud... incase you were wondering, yes, I love driving my Caterham in the winter
I look forward to when you get back state side, and seeing this project come back to life.
Your time in Aus sounds pretty good, it's been a long time since I visited my home country. Enjoy the rest of your time! And remember, the gear shifter is left, with first away and up
. The indicators are on the other side of the steering wheel, and most importantly, they drive on the left
This!!! Everything else is fine except for the occasional flick of the windshield wipers whenever I am turningmtnman533 wrote:And remember... The indicators are on the other side of the steering wheel, and most importantly, they drive on the left.
Glad you're giving your Caterham some outdoorsy love
Very nicesbeckman7 wrote:This!!! Everything else is fine except for the occasional flick of the windshield wipers whenever I am turningmtnman533 wrote:And remember... The indicators are on the other side of the steering wheel, and most importantly, they drive on the left.
Yum, environment!
It occurred to me that, although I don't need cats to register the car in january under a special-construction vehicle, I will need them to register the car in August/September when I drive it to school. So for now I'm planning on running them unless I get so far behind that it won't be finished by then.
Stupid CARB compliant cats are twice as much as the rest...
http://www.amazon.com/Magnaflow-36306-U ... &carId=001
And now the quest for a rasp-free V12 sound
davintosh wrote:Cats? Bah. All you've got to do is escape California.
I do actually have two very good pieces of news. Firstly, I'm buying that lovely 5.4 M73 with the white valve covers shown above. I don't know if I should sell the M70 or just keep it as "back up." Secondly, my friend figured out how to properly use the Frame Generator/FEA stress analysis in Autodesk, so I'll actually see how well engineered my frame is!
Lastly, hoping no one think's I've lost it, I am hoping to install some sort of HHO injection system on the engine after it's running. I'm hoping for one of two things. The first is a mileage increase with the same power output. The second is an increase in power output with the same mileage. Wish me luck.
