Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
Re: Euro 535i LS Turbo Build Thread
I just joined this forum to comment on this build. I love it!!! I have a lot of experience with the LSx platform and I can say that a built bottom end can take 15-18 psi comfortably as long as you have the fuel to feed it and don't go too crazy with the timing.
Maybe this weekend.
Well, now you will have something to drive over here this Fall
Great to see you back at it.
Finally some progress. I was ready to install the heads but couldn't find the pins that locate the cyl head. Bottom end is buttoned up.
Recap:
99mm bore
82.8 mm stroke
5.1L
9.5CR Forged pistons
Cam specs image below
Stock freshly rebuilt 799 heads (LS6)
LS7 lifters
Comp Cams pushrods
Trunion kit for rocker arms
Safe 7k rev limit. Peak HP at 6500rpm, in theory anyway. Planning to run 10psi for whatever it yields.
Recap:
99mm bore
82.8 mm stroke
5.1L
LS7 lifters
Comp Cams pushrods
Typo on displacement? http://www.bgsoflex.com/cgi-bin/displac ... illimetersT_C_D wrote: Recap:
100mm bore
90mm stroke
5.1L
Looks like fun though!
Corrected. Thanks.Brian D wrote:Typo on displacement? http://www.bgsoflex.com/cgi-bin/displac ... illimetersT_C_D wrote: Recap:
100mm bore
90mm stroke
5.1L
3.25 (ish) stroke, shades of the old 327! Takes me back...
Hey todd, this is awesome, pure motivation for me to get back at the car, except im not sure what i want to do now. i do have a couple questions though and forgive me if i missed it but what tranny are you using and what is the new engine classed as? ---- Never mind about the trans question, just saw where it said T56, not sure why but read that as the turbo the first time around.
It's a Gen 3 LS motor. Block is a 2005-2007 L33 Aluminum 5.3. Bore is 99.1108mm. Crank and rods are from a 4.8 LSbornagain wrote:Hey todd, this is awesome, pure motivation for me to get back at the car, except im not sure what i want to do now. i do have a couple questions though and forgive me if i missed it but what tranny are you using and what is the new engine classed as? ---- Never mind about the trans question, just saw where it said T56, not sure why but read that as the turbo the first time around.
Touched it today.
Almost ready to install. Need to install the harmonic balancer and plug the oil dipstick tube in the block. I am using a dipstick in the oil pan.
Where did you get the LS plastic Dummy Block? I would like to get one for mock up in my e12.
I borrowed it from a friend but they are available everywhere. Try summitracing.bkbimmer wrote:Where did you get the LS plastic Dummy Block? I would like to get one for mock up in my e12.
Finally moving forward.
+1 !Greg E34 wrote:YES!
- Beamter
+2 !!M. Holtmeier wrote:+1 !Greg E34 wrote:YES!
NICE! About time, thought you were turning into another Rich In Houston
