Page 14 of 19
Posted: Jul 23, 2012 9:50 AM
by T_C_D
Cool Otis. FYI, the e30 offers as much engine bay room as the e28.
Posted: Jul 23, 2012 10:15 AM
by Jeremy
20 psi on the first time out?? You're a brave man!
Posted: Aug 11, 2012 7:32 PM
by Good & Tight
Jeremy wrote:20 psi on the first time out?? You're a brave man!
24psi yesterday but it doesn't feel like it's faster, I think the engine can't take anymore air in.
I never updated the cage install, but it's all done now.
Dual 044's in there new home.
Fuel cell and battery disconnect switch.
Switch through the tail light, thanks Boris..!
Both seats with 5 point harness.
SFI roll bar padding NHRA rated.
Came out pretty decent considering it was my first rollcage install.
Car stiffened up a lot and I feel a lot safer now.
Next on the list is a C4 auto tranny and custom intake.
Posted: Aug 12, 2012 5:20 PM
by mooseheadm5
I like where this is going.
Posted: Sep 08, 2012 1:33 PM
by foolish
Otis you have a PM
Posted: Sep 17, 2012 4:46 PM
by Murfinator
Otis: what OD are your primaries on the exhaust manifold?
Posted: Sep 17, 2012 5:17 PM
by Brandon@BluntTech
Good & Tight wrote:
Posted: Oct 13, 2012 9:59 AM
by itsbrokeagain
Looking awesome dude. Personally I would make those wastegate tubes slightly longer to dump under the car....its gonna get really hot in that fenderwell, no need to set the undercoating on fire
Posted: Oct 19, 2012 12:38 PM
by rundatrack
Otis,
Its been great watching your journey. Having those calls 5 1/2 years ago when you got the turbo and now look at you.
Congrats brother
Posted: Oct 19, 2012 2:45 PM
by clongo
Looks great Otis! You going to make it to the vintage again next year?
Posted: Oct 19, 2012 6:43 PM
by Good & Tight
rundatrack wrote:Otis,
Congrats brother
G
Wow your right 5 1/2 years, your HX40 was put to good use for sure.
clongo wrote:Looks great Otis! You going to make it to the vintage again next year?
Oh yes looking forward too it for sure...!!!
Posted: Oct 21, 2012 1:18 AM
by Murfinator
Posted: Oct 22, 2012 7:32 PM
by Good & Tight
Murfinator wrote:Otis: what OD are your primaries on the exhaust manifold?
Murf the OD is 1"5/8.
Posted: Oct 22, 2012 7:36 PM
by Murfinator
Good & Tight wrote:Murfinator wrote:Otis: what OD are your primaries on the exhaust manifold?
Excellent. Thanks. That's the size I've been working with on my own setup. Interested to see what numbers your new manifold yields.
Posted: Dec 03, 2012 8:04 PM
by Good & Tight
Well after quite a few attempts to tune with the HX55 I've decided to down size the turbo. The twinscroll manifold spools it fast for it's size but the torque ramps up so fast it's going to murder me as traction is non existent at any speed at full throttle.
So going to try the BW S300sx 91/79, it's equivalent to a GT4088/94.
It's not the latest and greatest but for $$ it will get the job done. I was concerned about the size but it's similar to the 6466 with the compressor housing being 1" wider.
The BW weighs in at 27.5lbs and the 6466 at 23.5lbs
The HX55 will be going in 351w fox body project.
Posted: Dec 03, 2012 11:26 PM
by Shadow
So basically that hx55 went from no power to full power?
Sound like fun
But better then the little hx40 no?
Posted: Dec 05, 2012 6:28 PM
by thespeedfactory
Good & Tight wrote:Well after quite a few attempts to tune with the HX55 I've decided to down size the turbo. The twinscroll manifold spools it fast for it's size but the torque ramps up so fast it's going to murder me as traction is non existent at any speed at full throttle.
Thats what I saw with the HX55. Spun drag slicks in 3rd at 5000 RPM.
Posted: Jan 21, 2013 11:56 PM
by Good & Tight
Went out tonight after over a year, with the new manifold & turbo setup to stretch it's legs on 18psi.
My buddy has 2012 CTSV with a tune, upper pulley, heat exchanger it's pretty fast and just wanted to see were he was at.
Here's a 3rd gear roll at 50mph to 140, I cant hear his horn so I wait for him to go on both runs.
Here's a 2nd gear roll at 40 to 150, I spun but my buddy stays in it knowing that I'll be chasing him down.
Posted: Jan 22, 2013 7:05 AM
by T_C_D
Glad to see it back on the road! What does the CTS-V run in the 1/4?
Posted: Jan 22, 2013 9:46 AM
by Nebraska_e28
Any progress on the c4?
Posted: Jan 22, 2013 6:15 PM
by Good & Tight
T_C_D wrote:Glad to see it back on the road! What does the CTS-V run in the 1/4?
Not sure what it runs, maybe low 11's..?
He's running 15psi.
Nebraska_e28 wrote:Any progress on the c4?
Slow progress but starting to gather parts, C4 slip yoke, diff flange, Spicer 1310 U-joints. Paul is finishing up the tranny this month.
Posted: Jan 22, 2013 6:16 PM
by T_C_D
Posted: Jan 27, 2013 2:59 PM
by Good & Tight
Todd I hope I can make you eat those rofl's.
Posted: Feb 05, 2013 6:59 PM
by Good & Tight
A few updated progress pics.
I spent three hours re-aligning the head flange as none of the bolt holes lined up.
Welded a plate on the bottom to add all the vacuum lines.
Just need to drill and tap for 1/8 npt.
This is my first time welding aluminum and man you burn through a lot of rods.
Posted: Feb 05, 2013 7:00 PM
by T_C_D
That should be worth substantial HP where you want it! Great job.
Posted: Feb 05, 2013 7:01 PM
by Shadow
I have a feeling this is going to uncork some power alittle.
Posted: Feb 05, 2013 11:16 PM
by Brad D.
That is all sorts of bad ass. I can't wait to see the next dyno plot.
Posted: Feb 06, 2013 9:36 PM
by jim325
When will you be making those for b34 heads to sell?
If your not thinking of building some for resale, can you try to think of it?
Posted: Feb 06, 2013 9:51 PM
by clongo
jim325 wrote:When will you be making those for b34 heads to sell?
I would also be interested in one!
Posted: Feb 07, 2013 11:28 PM
by Shadow
T_C_D wrote:That should be worth substantial HP where you want it! Great job.
This guy used a 666 mani just like that on a stock m20.
Looks like it has a cam or something. You know how high rpm power completely dies on these engines normally.
I wonder if the m30 is more restrictive then the m20 though.
