foamy
Post by foamy »
reinstalled the rigged oil pressure sensor. she started leaking oil from the sensor again luckily i saved the old one witch also leaked but i had repaired it enough to not leak. its technically not an oil pressure sensor anymore i had burned the plastic out of it with a torch and soldered the hole shut so i could make it home and now its in there again because the replacement sensor started leaking. time to buy another one.
e28Sean
Post by e28Sean »
Plasti-dipped my front grill. Some quick teaser pics:
Earlier this morning:
The same spot, now:
e28Sean
Post by e28Sean »
Plastidipping before & after:
Image Image
Image :D
Opened the sunroof and windows, turned the stereo up to 11 and drove to Carlsbad via PCH through La Jolla.
Was told that the battery was dead. NBD, I'm not going any where. It's charging at the 2 amp setting. Amazingly the Rat lit right off as usual , except when it sits for a month.
L_N_Love
Post by L_N_Love »
Leatherique rejuvenator and pristine clean on the seats, new spark plugs, new valve cover gasket. Cleaned up valve cover with soap and water.
:alright:
ACHTUNG
Post by ACHTUNG »
Painted my grills. :clap:
TheE28Ranch
Post by TheE28Ranch »
Lots of grill action lately. I painted up a set a couple weeks ago. Wait this is the "today" thread. Today I fiddled about with some fuel injectors but didn't get too far. Went for a rip in the woods on the dual sport motorbike to blow off steam and got a rear flat miles from home. Good times. It was all worth it.
Chimi-Changa
Post by Chimi-Changa »
Summer wheels and new tires, check. ( tried for the vintage but oh well)
Dannyss
Post by Dannyss »
Today:two step paint polish by hand. Did the clay bar for the first time friday.
Reconnected the battery and drove it. Feels good being back on the correct side of the road.
ACHTUNG
Post by ACHTUNG »
Painted my side view mirror housings. :beer:
Painted my steering box and pulled apart a 140A alternator.
Saturday morning - new slave cylinder and a new load of MTL in the tranny. At the end of the return trip from Vintage it was getting difficult to catch a gear from a stop. Put 50 miles on it this morning and it feels good again.
Which means it's ready to go to Saratoga. :D
Slicktop City!!
TheYoungSir
Post by TheYoungSir »
Put a spare Fuel Pump Relay in the glovebox and fixed a budding no-start issue by replacing the factory-original main relay. :banana:
Serendiptaciously found 4 new 8 amp fuses. A buncha 16s and 25s too. but when I was going through my stash , I couldn't find any 8s.
foamy
Post by foamy »
fixed the radio so it would turn off instead of remaining on for an extra 4 or so seconds after the key.
jhall
Post by jhall »
cek wrote:Painted my steering box and pulled apart a 140A alternator.
I love stuff like this. I've got a couple of those to rebuild myself, great inspiration. Making old greasy and rusty things look and work like new is just so satisfying.
Pinstripe is gone. Eraser wheel worked out just like it was supposed to, which almost never happens. Still yet to polish her, that will be this weekend or next week.
e28Sean
Post by e28Sean »
Washed off all the evil green tree-spooge.
Fedaykin528e
Post by Fedaykin528e »
Looked at it lovingly from across the street on my way to work :D
TheYoungSir
Actually replaced the main relay, and put the new fuel relay in while I was at it.
(Previously placed the new main relay in the fuel relay socket while leaving the original in place) :oops:
rollcentre
Post by rollcentre »
I got my B&B catback installed.
It sure sounds sweet! :heehee:
ACHTUNG
Post by ACHTUNG »
Put meaty tires on then cried when they didn't fit.
Federico
Post by Federico »
Last week I refurbished my 528i's front struts.
New Sachs inserts, new BMW springs, bump stops, etc, etc. What a difference! It now rides like any BMW should: nice and taut but not hard.
These are the old shocks. Maybe they are the factory ones?
And this is what the strut bearings looked like. It seems they were rubbing against the spring perches when turning.
And by the date mark, it seems they have lived a long life. They were probably due for a change when the wall fell :laugh:
I put a 5-speed in my 528e.
(ok, its just in the trunk)
jhall
Post by jhall »
Swapped the red interior from the old eta into the Alpine '88. I like it better than the blue, and this may just be a step towards black, but for now I'm pretty happy. Also did some por 15 treatment in the floors while I was in there, nothing major at all. This is my first e28 without at least one hole or the start of a hole in the floor.
Side note, the eta's carpet had the pad attached, I thought the early cars had carpet and foam seperate, but not this. Odd considering the carpet in my 85 was the seperate padding.
wally
Post by wally »
I watched some wheel paint drying... :)
https://www.flickr.com/photos/by_wally/ ... otostream/
Leatherique. The steering wheel was especially hungry. It took a few coats before it stopped soaking it all up. I'll clean and finish it all tomorrow.
I'm not sure.
