I took BBShiftless on a small trip downtown to get some stuff and to get some summer air for the tires. Between CVS and the Shell to air up, the LCL lit . DOH. In typical fashion, I drove home without drama. I opened the hood and there is coolant everywhere. I'm getting a little wound up. Until I wiggled the hose to the radiator. It was loose on the thermostat end. I let it cool down, then I redid the connection . I also tightened a loose bracket bolt. I also ground down a piece of 1 1/2 ID conduit and drove into the remains of the Boysen muffler I bought from Rexmo so long ago. I now have enough of a tail pipe to attach chrome tips to. I took another drive just long enough to see if the fix took, So far, so good. :D
1st 5er wrote:Image
Great mod. I love my e24 shocks.
Norbecke
Post by Norbecke »
Not today, but on friday i got her professionally washed and waxed and detailed interior.
I took BBShiftless on an 80 mile drive this PM. The front end shimmies going over bumps . I'm thinking the 26 yr old Boge hydraulics have expired , maybe the LCAs BJs , TREs,and UCA bushings . Time to try Paul's bushings. The ABS lamp is lit. That isnt a high priority. But I'm gonna crawl under the front end soon and do some shaking.
My 75K mile engine re-fresh took well. Cool runnings in heavy traffic, no warning lights lit. The engine is strong as usual. I will check the valves after the first killing frost when the mosquitoes aren't so bad.
Post by unt0uchable »
I opened the doors to let it air out. It's been cooking in the sun for weeks and the black interior was getting a little sweaty.
Matt in SC
Post by Matt in SC »
Cleaned up my euro headlights that I just purchased.
shagrath wrote:Image
Plans for that? Trimming them down or going to run spacers?
I plan to run mild spacers. I also kinda like the look. Plans for GC coilovers next year or so.
Snob got new right rear pads today.
waynet1
Post by waynet1 »
Reminds me of these;
DanOKC
Post by DanOKC »
Installed new clutch master & slave using the syringe method I learned from reading this forum. Flavor injector was my syringe of choice, only one I could find at BedBath & B.....
Made a small mess on my driveway but had fun trying a new method.
kzolee
Post by kzolee »
Added the E28 between items in Wootocracy. :D
http://wootocracy.com
jhall
Post by jhall »
I took the 535is for a bit of a spirited dive down old Illinois 2. First time I have done that in a while. The road isn't the most exciting one out there, but the sun was setting, rolling countryside, windows down, and all the right tunes playing on the ipod. We are all so lucky to have such an amazing car.
louielouie
Post by louielouie »
Completely flushed the cooling system and put new 'stat & WaterWetter in to combat overheating only to find that a loose ground strap on the right motor mount was causing the issue with the temp gauge reading properly and the subsequent lack of battery charging :brick:
I was fashioning heat shields for the B35 manifold & down-tubes and must've loosened the strap.
On the bright side, the stock Bilstein comfort insert & spring up front totally balances the HD shock & E34 spring in back - over bumps and such the whole car reacts as one. No more 'hobby horse' rocking between front & rear.
I got her a new radiator since the old one was well beyond its years (2).
Also had the rear calipers rebuilt and added new rotors, pads, and hoses.
$2,150.00 makes me a :D camper.
Got a nice, resurfaced lightweight flywheel in the mail.
Replaced the trunk gasket. Again...
I'm not sure.
Chimi-Changa
Post by Chimi-Changa »
Day off fun: Roth Bracket 4.1 for clutch pedal, and installed extra brake light Kit and HO bulbs. Then slapped in Ciebe front, flat lens low and high beam with Pee beam film on highs-Libby helped with the cleanup:
Now enjoying a firm clutch pedal, and great night visibilty- Thanks Dave ( bracket) and Andy (lights) for great products and service.
KegCoyote
Post by KegCoyote »
Today, I troubleshot my ABS system with the help of a friend, passenger with a multimeter, a flashlight, and a computer(with wiring diagram/notepad. Debating whether to attempt a sensor swap and potentially have another connector crumble or just buy a new one and try to do a high quality splice.
geordi
Post by geordi »
Finally decided on a set of new tires for the OEM M5 wheels. Ordered four Michelin Pilot Sport A/S 3s. :haul:
geordi wrote:Finally decided on a set of new tires for the OEM M5 wheels. Ordered four Michelin Pilot Sport A/S 3s. :haul:
You'll be glad you did when you start Rolling Three Sisters.
The Beast is getting new stickies too. :haul:
Matt in SC
swapped out dash.
1st 5er wrote:The Beast is getting new stickies too. :haul:
Snob turned in to a real road hugger this weekend with the Direzza Sport Z1's destined for The Beast.
