$12K I wish... more like "pennies from heaven", (errrr... '11 Jetta driver's insurance company). :D
You know what they say about "turning the other cheek"?
She'll shortly have memories of battle wounds on both sides, but w/o the scars. :cool:
Installed a new factory exhaust today.
Sherman, sorry about your accident, these things always suck.
Thanks, but it's all good.
So the SoCal competition stiffens.
And... you sure that's today? Sure looks like Christmas. :laugh:
1st 5er wrote:Thanks, but it's all good.
It was last night, I keep the lights up all year. Plug and play makes it so much easier. They're all clear bulbs so no one notices.
So they're not miniature Poinsettias, :oops: ?
1st 5er wrote:So they're not miniature Poinsettias, :oops: ?
Ha ha, no they aren't but my wife does fill the planter with poinsettias every Christmas.
So, do you have any photos of it on the car. Looks like it is on a table there. ;)
Ha Ha Ha... those previous four post should mess their heads too.
That exhaust does look really :banana: .
grey ghost
Post by grey ghost »
Built a cold air intake, new rear tires, 255-35-18. Drivers seat had no function. Pulled the seat and fixed that. Properly installed the grommet that goes thru the firewall in the glovebox. Mad heat coming thru. Washed and cleaned the wheels.
867535i
Post by 867535i »
In the past week I've been getting the e2hate ready to be road worthy for when I move. Had some help from my friends too.
Replaced control arms uppers and lowers
Tie rods
Window seals
Radiator hoses
Welded in a bung hole into my exhaust
Spliced in a new O2 sensor
Vacuum lines
Fixed the falling off rear vent things
Reattached the seat back
Put the steering column back together from the ign switch fix
Threw in the Dinan chipped ECU (which sucks until you get to 6000 rpm, which is great for .25 seconds before shifting again)
Upgraded to a 90 amp alternator
Tightened my squealing power steering belt
Finally, I washed the car which revealed its glorious Maaco glitter bomb of a paint job. I wish I had left it dirty. I'm taking its first 100 mile run today since I've owned the car. Crossing my fingers.
genzox
Post by genzox »
thespeedfactory wrote:Fuel pump, hoses, filter, rear diff mount, odo gears, 71 deg t-stat, outside window rubber trim.
Found the pump on amazon for $35. Identical in appearance to OEM. We will see how long she lasts.
Need a source for all 4 window channel rubber.
Back windows drag somethin fierce.
Could you send the link for the pump? I need one too
e28Sean
Post by e28Sean »
Found a quiet backroad, and went for a blast. :cool:
Drove it and it was awesome. Especially for driving a minivan for over a week straight.
Ordered my APEX 90mm lug stud conversion kit
Still under the hood of BB Shiftless. Between the mosquitoes and the heat , the pace has been snail like. I spend about equal time under the hood and in the house re-hydrating and cooling off. A wet cotton work shirt keeps me coolish. My bifocals are useless, they are covered in sweat and eye glop, So I'm feeling the work . I've worked up to the top end. It is just plugs , tighten the VC, put on new belts, replace the intake, add coolant and start. It has been a slow job. I hope to finish today :banana:
11AM Back in to cool and water. Just the coolant and the AFM left.
12 :30 , Back at it . engine was pretty clattery for a minute , but it soon settled down as I added coolant. I am running it at an Idle. The LF is blocked up , so I.m using the upper switch as a bleed. I ran it for 20 minutes with the heat on to burp the system . I added ~2 gallons of coolant. Running at idle with the cap off and no fan or shroud. The pump works , the ambient temp is 92 and its running with no pressure and no breeze cooling the radiator. Temp is 11 o'clock
The Beast just got a bath in preparation for the old school reunion at memorial park.
501 PM Back in, writing up the event on the back of a flap from the Bremi distributor cap box. It started to rain just as I put new wipers on and put stuff away. While i was inside the tank burped and I topped it off about a qt.
grey ghost
Windshield, glass sun roof, and here's a picture of the cold air intake I made last week. My windshield was cracked beyond belief. Here is a $35 junkyard windshield. New rubber I had. New locking strip was a gift from a board member. Thanks much.
Glass was easy.... Iove it. Still need to adjust it a little.. but not today.
CAI, now that was a pain in the ass..... but it works great.. Before, the cone on the air filter would be extremely hot, now when I pop the hood and touch it, it ambient temp, not engine bay temp. I thought it may be restricted being I didn't remove a high beam, but on full boost, there is no lean condition..
Its sheet metal with two layers of cardboard on the inside covered with aluminum tape. No heat gets in there. The inside of the intake is always cool..
Speedster990
Post by Speedster990 »
Fixed slow/non-functioning windows by cleaning window switch contacts, replaced all fuses, leveled the hood, shampooed the carpet, cleaned all vinyl surfaces, installed new shift knob and door lock knobs, fixed electric headrests, replaced computer back lights with LEDs, somewhat fixed the speedometer issue, and then washed it.
This is my first post on this forum!
I am fifteen years old and my parents purchased this 528e when I was born.
Mine and my dad's to do list (any helpful hints are welcome):
-Replace all bushings and mounting hardware on shift console
-completely fix the speedometers erratic behavior
-remove spots from plastic interior parts
-repair the intermittently working central locking system
-figure out what is causing the slightly fluctuating idle (the manifold gasket has been replaced, as well as the cold start valve but there must be a vacuum leak somewhere)
-fix sloppy steering,
-stop the vent things behind the back doors from falling off
As I said before if anyone has experience with any of this I am open to opinions.
grahamular
Post by grahamular »
Welcome! Sounds like you got a good start on getting the 528e cleaned up. As for your "to do" list, I'd suggest first using the search feature to read some of the previous posts on each topic/question, and then posting any additional questions or follow-up in the Tech Talk section, using each to-do item as a separate post as you get ready to work on each issue.
-Graham
freetoride
Post by freetoride »
15?! Very well written my young friend! Nice car too. :alright:
Speedster990
freetoride wrote:15?! Very well written my young friend! Nice car too. :alright:
Thank you! And ya I have been interested in shark nose BMWs as long as I can remember. And having my dad their who has 15 years of experience with this car is nice too!
grahamular wrote:Welcome! Sounds like you got a good start on getting the 528e cleaned up. As for your "to do" list, I'd suggest first using the search feature to read some of the previous posts on each topic/question, and then posting any additional questions or follow-up in the Tech Talk section, using each to-do item as a separate post as you get ready to work on each issue.
-Graham
Thanks! Will do. This forum has some type of answer to virtually every problem I have now that I have looked into it.
Speedster990
Ok so I figured out where all the slop was coming from on the shift console! It was the stop buffer at the back. This piece functions as on of the main supports for the shift console and my console was rocking left and right so it would hit the sides of the transmission tunnels. This buffer was supposed to have two rubber prongs on it and in my case the top prong was completely gone. To fix this I took an appropriate sized bolt and lock nut and used a skate board bushing as a replacement for the rubber piece. I bolted it up (without dropping the driveshaft or exhaust) and virtually all shifter slop disappeared! WOOT! :banana:
djazz
Post by djazz »
Speedster990 wrote:To fix this I took an appropriate sized bolt and lock nut and used a skate board bushing as a replacement for the rubber piece. I bolted it up (without dropping the driveshaft or exhaust) and virtually all shifter slop disappeared! WOOT! :banana:
Yeah, you're gonna fit right in here. Good Job!
jhall
Post by jhall »
My brakes have been soft for some time. After doing some reading here today I realized it was probably my brake bomb/ proportioning valve. So I replaced the whole assembly tonight with one off my shelf. As Edd China would say: result!
Avoided a turtle.
Chimi-Changa
Post by Chimi-Changa »
Aero wiper on- Thanks Keith for part, and Chris K. for checking for one for me.
Post by unt0uchable »
Ordered $900 worth of parts for it.
dsmith
Post by dsmith »
Tore down my S38 to do the head gasket. Something fun to do, while I'm a vagrant.
