Page 103 of 179
Posted: May 25, 2013 12:54 PM
by OcCoupe
Wiped her down after returning from the San Diego clean car contest. Decided to do a light polishing of the hood and trunk followed by some carnauba wax. Then took her out this morning to Cars and Coffee.
Posted: May 26, 2013 2:27 AM
by a
Ordered the parts for the long overdue 4 yr/60k mile service. More like 7/ 75 List includes a 30$ GMB water pump. This is going into BB Shiftless.
Posted: May 30, 2013 4:25 PM
by BlackGold
Changed spark plugs and air filter. Fuel filter tomorrow. Re-painted hood vents and grille with Dupli-Color flat black trim paint.
Posted: Jun 02, 2013 10:55 PM
by BlackGold
pee beams
Posted: Jun 03, 2013 2:07 PM
by slammin_e28
Little late, but I changed the diff fluid, only to find no metal chunks or odd wear on the ring/pinion gears. Ran the car to 60mph while I was under it (car was on the lift) and I think it's the diff carrier bearings that are howling. Took the axles off, rebuilt them. Noticed the stub shaft was very loose (in and out movement) in the housing.
Posted: Jun 06, 2013 8:38 PM
by e28Sean
BlackGold wrote:pee beams ]
Niiiice pee beams!
Posted: Jun 07, 2013 5:00 PM
by orignal teile
finally got my rear caliper fixed, had to replace three bolts along the way from the PO getting overzealous with an air gun :/
replaced the airfilter with a mahle, oil filter with a mann, and have vr1 20w-50 in it now. next up, i have a couple quarts of royal purple diff oil, mines been slowly leaking, even though i had replaced the gasket last summer, might hit it up with some rtv
otherwise just glad to do some light canyon carving, and some dirt lot donuts :banana: :banana:
Posted: Jun 07, 2013 9:09 PM
by BlackGold
Niiiice pee beams!
thanks. I used the Krylon Stained Glass Paint
Posted: Jun 07, 2013 9:20 PM
by BlackGold
Actually did this on Monday but I'm just mow posting. Put in the e34 front seats that I got for free from tomcrinic. Big thanks to him for that.
old seats
new seats
and i repainted the window stripping stuff black. not really sure what it is. but its not the window seal I dont think
Posted: Jun 08, 2013 2:55 AM
by orignal teile
and also did this, from my last junkyard find, literally plug and play,
its an e23 headlight switch, when i was in the junkyard, i saw a e23 735i in amazingly good interior shape, realized the headlight switch was similar, with the same plug, and the screening on it, so i snagged it, and an e28 one, as i needed a replacement.
threw it in today after dusty donuts for donut day, and it works fine, better than the broken one in it :alright:
i've also nearly perfected the art of having the lower dash panel go in and stay in easier, or at least i tell myself every time, until its in my shins
edit: you can see the switch in e23's here:
Posted: Jun 08, 2013 4:07 AM
by Das_Prachtstrasse
orignal teile wrote:Image
I've got a set of German e23 switches (foglights, headlight) I was considering putting into the e28, but never got around to it. I'll do this, now.
Posted: Jun 08, 2013 7:27 PM
by ncpaladin
Brake system flush with Super Blue. Then throw a fit when the hose for the clutch master cylinder pops off, allowing new fluid to run out of the master cylinder reservoir. I swear, some complete maniac designed the brake/clutch system on these cars. And a maniac with very small hands at that. :laugh:
I trimmed off about a half an inch of the clutch hose, fitted a band clamp, and fought the hose back onto the reservoir nipple.
I think that when they designed the E28, they penned it, then made a model, then made the car, and then said, "Shit, we forgot to put brakes and clutch on this thing!" "Oh, here's a bit of remaining space tucked up over here. Let's cram it all right there." :roll:
Posted: Jun 08, 2013 9:37 PM
by orignal teile
would the e23 foglight switch work in the e28s? i didnt look at the pins, maybe next time at the yard, i'll look, though i dont mind the blank button, it just looks cooler with a label. big upgrade from my burnt out burnt out dimmer headlight switch that was in it before, also have a good working headlight switch i got just incase the endeavor didnt work out. to the parts hoard it is added!
Posted: Jun 08, 2013 9:51 PM
Let Das Beast go out to visit a few friends.
Posted: Jun 08, 2013 9:52 PM
by oldskool
What I did for my e28 today was to shop around for it.
Many great examples offered, just not for me. Yet.
Posted: Jun 08, 2013 9:56 PM
by a
In between honey doos, I drained the block, removed the cap shroud and fan . I jammed a screw driver into the alternator pulley and loosened the WP pulley bolts, easiest I've ever done it. I am pleased with the baseline service I did right after buying the car in '05. I didn't just replace parts I fixed stuff so that the engine would be easy to service, the next time around .That time is here and so far ,so good. :cool:
Posted: Jun 09, 2013 2:14 AM
by djazz
1st 5er wrote:Let Das Beast go out to visit a few friends.
Great pic!
Posted: Jun 09, 2013 2:23 PM
by a
A bit more progress I pulled the plugs and set the rotor ball parked to #1 cylinder. Having numbered wires makes this a no brainer. One is in line with the inboard-cap screw , BTW I found TDC by putting the battery hold down rod in the plug hole and rocking the crank with a 7/8 ratchet . After clearing off the belts, there it was , the timing marks highlighted in white. I like to set the engine at TDC before changing the TB. This time , per Matt;s experience with having the sheet .metal idler gear let go, I have a cast gear to install. 30 bucks is short money . I should have ordered plugs but the outfit wanted me to buy 2 4 packs. The NGKs I took out were running pretty clean and ~evenly coated. Maybe a tad lean. The tips were worn on 1 side like a worn heel .I can probably get them locally. I will check records, but the plugs have about 40k miles , IIRC.
Posted: Jun 09, 2013 2:49 PM
by TheE28Ranch
In the middle of troubleshooting right now. Headed to lunch to meet the fam the 528 died on me taking a turn, seemingly in sync with the switching on of the blinker. I managed to land it in a parking spot and walked to lunch. Same thing happened a few days ago, but started right up. This time it didn't. Cranks, but won't start. Lunch is now over, headed back to car.
The E28 lifestyle is a never-ending adventure.
Posted: Jun 09, 2013 3:28 PM
by rmiddendorf
Minotaur wrote:In the middle of troubleshooting right now. Headed to lunch to meet the fam the 528 died on me taking a turn, seemingly in sync with the switching on of the blinker. I managed to land it in a parking spot and walked to lunch. Same thing happened a few days ago, but started right up. This time it didn't. Cranks, but won't start. Lunch is now over, headed back to car.
There's a great quote by Pete in the 2011'RTT video which reinforces this.
Posted: Jun 09, 2013 4:16 PM
by TheE28Ranch
Yesterday I was on a gravy train with biscuit wheels, today it's back to the usual grind.
Update...yup the 528 started right up after a 1 hr lunch, I then went to gas it up, as it was hesitating a bit on the hills and the gas-o-meter is wonky. Almost 11 gallons went in the tank. And then it wouldn't start. Tried to a bit. So I parked it there at the station and walked back to my garage, and warmed up the M5. Took a spin to feel the car out, went by the 528 (it'd been about 25 mins since I parked it) and it still wouldn't start. Keeping toes crossed that it will start in a bit and directly in the garage it will go. Daily recreational driver is going to be the M5 until the eta gets sorted. Sounds good.
Posted: Jun 09, 2013 9:28 PM
oldskool wrote:What I did for my e28 today was to shop around for it.
A piece at a time, huh? :laugh:
Posted: Jun 09, 2013 11:04 PM
by davintosh
Yer doin' it wrong, son. http://www.youtube.com/watch?v=rWHniL8MyMM
Posted: Jun 11, 2013 10:09 AM
by tig
Put my new license plate on:
Posted: Jun 11, 2013 10:25 AM
by unt0uchable
Yesterday, I watched it drive away. Sold it to an e30 guy who lives a couple cities over. It was a sad day since I no longer have an e28 to drive on my daily adventures, let alone one that I can shift at will. I guess I should get my but to work on this one. It's the first day without it but I want it back already. :(
Posted: Jun 11, 2013 3:08 PM
by foamy
rubbed 75/140 gear oil all over it to hide the sun faded paint.
Posted: Jun 11, 2013 8:52 PM
by OcCoupe
Went to the dealership so they could replace the battery.
Posted: Jun 11, 2013 9:11 PM
by oldskool
OcCoupe wrote:Went to the dealership so they could replace the battery.
I have news, but by looking, no one will believe you. It's not under warranty anymore!
Posted: Jun 11, 2013 9:14 PM
by OcCoupe
Au contraire, it was covered under warranty!
Posted: Jun 12, 2013 3:10 AM
I did this recently, also. They found the old battery (which mind you was a freebie from my housemate who works in the parts department at the local dealership) wasn't up to standard, and replaced it under warranty with a spankin' new one.
