When I am able to do so, all rims will be widened by 1.5" thanks to new lips for the RS's. The widths will be 8.5" for the front and 9.5" for the rear, with 245 and 265 width tires respectively.
Sounds like a plan. It's not fixed in those pictures. I'm going to bring it to school, cut it and re-align it there while its on the subframes, and then heavily tack weld it with the mig. I'll tell him to go a little slower this timemooseheadm5 wrote:So is it fixed?
If not, try welding it with the subframes attached, and maybe clamp it to some temporary supports while he is welding it. Tell him not to weld in long lines but to tack it all around or it'll put too much heat into the joint and warp things.
+1 to what Moosehead said. I know one trick used by my cage builder was to brace opposing tubes with lengths of lumber to prevent twist and warping while welding. Tacking in crossbeams would have the same effect. Glad to see the progress, though!sbeckman7 wrote:Oh got it. Alright I'll tack some supports in as well
Me too! So, next will either be the roll bar or the floorpan. not sure what I should do next..Tammer in Philly wrote:+1 to what Moosehead said. I know one trick used by my cage builder was to brace opposing tubes with lengths of lumber to prevent twist and warping while welding. Tacking in crossbeams would have the same effect. Glad to see the progress, though!sbeckman7 wrote:Oh got it. Alright I'll tack some supports in as well
-tammer
I didnt find too many coins, I think it was right around a dollar. And some other things which will not be discussed...gidgaf wrote:I live in Los Angeles. A car in that condition is called "good/ fair" in CList terms around here. For that money you got a good deal. Please keep posting works in progress pics, as well as mechanical anecdotes as you go along.
BTW, how much money did you find in the back seat?
I found a key to a VW Socorro.sbeckman7 wrote:I didnt find too many coins, I think it was right around a dollar. And some other things which will not be discussed...gidgaf wrote:I live in Los Angeles. A car in that condition is called "good/ fair" in CList terms around here. For that money you got a good deal. Please keep posting works in progress pics, as well as mechanical anecdotes as you go along.
Will keep updating. Today is the first day of school after break WOOOOO
