4 holes to give reason to changing your timing belt
Re: 4 holes to give reason to changing your timing belt
I thought this might be good for new members.
Andy
Andy
What caused this ^^^ ?
If my S38 ever suffers that I'll cry...
Exactly what I said. What could have possibly gone so catastrophically wrong?!tn535i wrote:What caused this ^^^ ?
Had that happen to a m30b35 I was parting, except it had a whole in both sides. The rod let go and all kinds of crap hit the fan.
Andy
Andy
Man, I bet valve reliefed pistons never looked so good, huh?
This went boom at 160mph. I think it was the combination of lack of maintenance, chipped ECU (speed limiter removed, rev limiter raised) and the fact that the guy never let it warm up properly. The car sat for 4 months in the winter and he started it and went directly to the freeway to test the top speed.
I've seen a trown rod before but I really wonder how the pistonrings end up between the valves!!
There is no room between the piston and the cilinder wall, how the heel get they past that?
Owh, and the rod was gone, like we never found it!! Mostly there is still a piece connectec to the crank....
Why do 'tuners' insist on doing this? Unless you are racing, what benefit is a raised/removed rev limiter?Jelmer538i wrote:...chipped ECU (speed limiter removed, rev limiter raised) ...
Forum signature lines.cek wrote:Why do 'tuners' insist on doing this? Unless you are racing, what benefit is a raised/removed rev limiter?Jelmer538i wrote:...chipped ECU (speed limiter removed, rev limiter raised) ...
Thought that a friendly reminder to the 528e people was a good thing.
Andy
Andy
You are a good man.south26 wrote:Thought that a friendly reminder to the 528e people was a good thing.
Andy
