what is the best street turbo for m30?
marc79euro645
Post by marc79euro645 »
Winfred,
Did you consider a thinner motor mount on the driver side to stand the engine more upright?
My 79 635 is the same platform as your 81.
Marc
winfred
Post by winfred »
i wouldn't get enough tilt before the intake hit the vacuum booster, the b35 intake is about 1/4" from it, the frame rail mod would be fairly easy for me. plus the tilt would probably keep the oil from draining completely during changes without doing something annoying like jacking up the left side of the car, might also put the fan too far out of position so that it hits the shroud
marc79euro645 wrote:Winfred,
Marc
altus22
Post by altus22 »
Brad D. wrote:I would be surprised if anyone pulls off the CAN control of a VNT. I also don't have any idea if anyone is actually using CAN enabled code to control anything with MS yet? I have done a fair amount of VNT tuning on OE Bosch and Delphi controllers and it is fairly complex, definitely not what I would call basic level tuning. It would require a fair amount of skill to modify the existing code to output the CAN commands. You would also have to have the turbo manufacturers CAN command dataset that it is expecting to see. This is something that might be possible through extensive trial and error (doubtful) and it is also something that usually isn't available to any one other than OE manufacturers/calibrators.
While I agree that it would be amazing to see this work, and would be a massive performance improvement, it is an extremely uphill battle to make it work.
There is a controller on the market that will control it standalone. I'm pretty sure that you set a boost target and go. It's ~$500 IIRC. Obviously you know better than I, but setting a boost target and tuning a PI(D) loop shouldn't be terribly hard to accomplish once you know the J1939 messages it is expecting. Not everyone has access to a CAN logger though.
marc79euro645
ok then, let's say a gt35r like George recommended.
which turbine for m30? t3 or t4?
turbine a/r .6, .8 or 1.1?
also has anyone tried the cheap turbos on ebay?
I've read on bimmerforums that all Garretts are made in China & Mexico now? makes me wonder if they're really worth the price?
marc
http://cgi.ebay.com/ebaymotors/GT35R-GT ... ccessories
I would go with a T4 turbine, with something in the 0.58-.6 range if you want a quick spooler (much like a TCD setup).
marc79euro645
Winfred,
Did you look at flipping the manifold over with turbo on top?
thx
marc
winfred
Post by winfred »
no i didn't but i am not a fan of top mounts so it didn't occur to me to check
thx
marc
charofire
controller for vgt
Post by charofire »
Can you tell me more about who makes this controller that you referred to in this thread? i really want to install a vgt hoslet.
Thanks,
Paul
my524td
Post by my524td »
i think im going with the HOLSET HE351Ve with a manual wastegate ill keep every1 updated
thrty8street
Post by thrty8street »
Brad D. wrote:I would go with a T4 turbine, with something in the 0.58-.6 range if you want a quick spooler (much like a TCD setup).
Where would be a good place to purchase a turbo such as the one mentioned?
You could call Todd at TCD and he can spec you out with exactly what will work for you. He can get you a turbo made to order, with the wheels (both comp and turbine) you want and AR that you choose (or have him recommend).
There are other sources but I doubt many will have as much BMW FI m30 application knowledge.
yert315
Post by yert315 »
Did anyone give this turbo a shot yet?
Year old thread, I know.
