My M5 S54 Build is DONE
athayer187
Update...front seats are done. As athayer said, POR doesn't come in a spray can. Single use brush is the best way that I've found. I then top the POR 15 with POR chassis black paint. Although Chassis Black also doesn't come in a spray can, I've had good luck using a Preval sprayer (google Preval..can be picked up at the local home improvement big box).
That is interesting. I wonder if the springs got swapped at some point. They were rusty/cruddy when I pulled them out so I assumed they were the originals. I have the original Canadian dealers paperwork (including the lease) from 1987 with the specs on the car which has the mtech body kit and suspension options listed as being on the car. From about 1994 until I bought the car last year there is a void of what was done to it other than the importation/federalization of the car in 2002. I have the original KPH speedo in a box that was swapped out for the MPH when it crossed the border. If the springs turn out to be too soft, I can always swap to something different in the future but thank you for the adding to my knowledge.
Re: My M5 Build...Sneak Peak (Updated 1/27)
Not so. All DC93 North American specification E28 M5 examples were built with twin-tube gas pressure Boge front shock absorber inserts (31 31 1 133 517) and the same front coil springs used on all North American Spec 535i and 533i models (31 33 1 126 024). In the rear, all North American E28 M5 examples were equipped with hydraulic self-leveling suspension. Bilstein shock absorber inserts were only used in European specification E28 M5 examples produced up to 10/1986 (front: 32 2 225 016 and rear: 33 52 1 129 241).Chuckne wrote:The car came from the factory with the mtech/bilstein suspension...no self leveling system.
Can you verify if your stabilizers are adjustable and confirm what color the coil springs and stabilizers were prior to refinishing them?
Best,
RCBMW
Black Steel
I noticed that you perviously referenced these Bilstein Part Numbers in another post:
I would love to see more photos of your amazing work on the M5. Great job!
Best,
RCBMW
The Bilstein part numbers you listed are in the old Bilstein part number format and correspond to the (B8) Sport version. BMW used the (B4) OE twin-tube series only in European specification M5 models up to 10/1986 production and the part numbers you provided confirm that the Bilstein absorbers were installed by a previous owner. I have a suspicion that your car was modified with an early Dinan suspension system.Chuckne wrote: Front F4-P36-0243-H203
Rear F4-B46-0607-H002
Best,
RCBMW
E.rouzbeh.28
Running stock ECU that has been burned to eliminate EWS and any inputs from the body side. Had to go with a DBW throttle pedal. From a functionality standpoint, I will have full dual vanos and the only thing I loose is cruise control. Engine will probably have to come out one more time to clearance the tunnel for the 6 speed as I'm not happy with where things are. Otherwise all is sorted.
When I did the 6 speed swap in my Hartge H5s and my fathers 666csi, I simply cut a section of the tunnel approximately 8 by 10 inches out up near the bell housing. I made all of the necessary adjustments using a hammer and dolley, then fabricated a 20mm oversize replacement panel. I welded (now) captive metric nuts to the underside of the tunnel drilled holes in the replacement panel, lined the replacement with closed cell foam and bolted the new cover right on. BTW it makes getting to those top transmission fasteners a bit easier. Just a thought though.
It looks like you started with a nice chassis, and motor. Keep up the good work and keep us updated!
Best Regards,
Justin
Best Regards,
Justin
oh man, that's sweet. I wasnt sure if the burn was more refined. when i first looked at the swap, i guess there were a lot of questions about how well the ecu would function, but this is good news!Chuckne wrote:Running stock ECU that has been burned to eliminate EWS and any inputs from the body side. Had to go with a DBW throttle pedal. From a functionality standpoint, I will have full dual vanos and the only thing I loose is cruise control. Engine will probably have to come out one more time to clearance the tunnel for the 6 speed as I'm not happy with where things are. Otherwise all is sorted.
Keep us posted on progress!
Murfinator
