m535is wrote:dunnojack, the reason we didn't want to use the E34 tank was 2 fold. First it is much larger and therefore harder to fit. The second is that we wanted to be able to run an E28 stock coolant pressure which the max comes with the E28 M5 and the cap is not the plastic cap of the later cars, it is a metal cap which will only work with the earlier containers.
Currently we are using the stock e28 aux fan and wiring. There is no melting of the fuse box at this point. We are looking into upgrading the fan to the E34 fan potentially and then changing the wiring at that time, but as for now the larger problem is determining how to prevent the AC fuse holder from melting. Chris and I are working on a really cool "BMW" solution for this problem. Chris can give more details on this when he is done at the end of the weekend.
Black Steel,
I also plan to run my car very hard. At this point though I am still working on the custom exhaust and have to get the 1200 break in miles on the motor before I can really start to push it. Once I get to that point if we run into a problem, like I mentioned above we will probably go to the E34 aux fan and do some upgrading to the wiring. But like it is has been said we are running an e28 535i manual trans radiator. We are using the e28 535/M5 fan clutch and black fan, e28 aux fan, and E36 coolant temp switch.
No more melting fuse boxes!
http://www.m535i.org/e28info/fusebox/IMG00058-fuse1.jpg
Note to the observant the fuse sizes on #13 and #14.
A relatively simple fix, that hopefully avoids the biggest issue of the E28 fusebox which is the melting of fuse block 13 and 14.
Note that while people complain of melting fuse block #17 (aux fan fuse), it's actually been the issue on 4 out of 4 E28s I know personally very well that it's fuse block 13 and 14 that tends to melt.
The fusebox fix, in fact, takes a page out the E24 book but running a dedicated circuit for the blower motors instead of piggy-backing on fuse 14.
And yes, the blower motors will blow an 8 amp fuse. Tried it.
More info here:
includes wiring diagram.
-Chris
