Page 2 of 5
Posted: Sep 30, 2010 11:40 PM
by Nebraska_e28
Well tonight I pulled the injectors & swapped in a thought-to-be-good set. Afterwards I adjusted MS for the change in injectors. Car ran exactly the same. This weekend I'll get the darned compression test done & expect some data pointing to the head being fubarred!
How is the ignition triggered on this setup?
The ignition is triggered off an e34 crank wheel & sensor.
Posted: Oct 03, 2010 12:42 PM
by Nebraska_e28
small update:
Skipped the comp test since Mike came by Friday. He touched my car in some odd manner & it now runs fine.
Problem
must've been an electrical connection. Will get around to a pull test eventually... It was running fine with the old injectors I swapped in. Put the new 42lbs ones back in & still all good. This must prove the issue
couldn't have been the head.
Figured out why MS wasn't reading afr right, I had it connected to the narrow band spare output side of the lc-1. Now I have MS & the afr gauge wired together into the same wideband output side of the sensor. Is this right? MS now reads fine, but there is about a 1 point difference between it & the gauge.
I'm reading on how to adjust the tune & it still seems a tad mystical. Do I just have someone drive the car while I adjust the table to 14.7:1 for a given rpm & load?
Headed to work now...
Posted: Oct 04, 2010 11:21 PM
by Jared S
I have my lc-1 wired to my gauge with one output and MS is getting the second output. I don't think you should be feeding both the gauge and MS from the same output, but maybe I'm wrong and it doesn't matter. I did have a problem where my innovate gauge and MS were almost 1 point different. The problem was the way I was grounding the lc-1. Originally I had all the lc-1 grounds together on one lug. I split them between 2 lugs and then my readings were the same between the innovate gauge and MS.
Posted: Oct 05, 2010 9:03 AM
by Nebraska_e28
Jared S wrote:I have my lc-1 wired to my gauge with one output and MS is getting the second output. I don't think you should be feeding both the gauge and MS from the same output, but maybe I'm wrong and it doesn't matter. I did have a problem where my innovate gauge and MS were almost 1 point different. The problem was the way I was grounding the lc-1. Originally I had all the lc-1 grounds together on one lug. I split them between 2 lugs and then my readings were the same between the innovate gauge and MS.
Well I was able to finally get MS to coincide with the gauge. I had to set TS to "wbo2 not listed" & then programmed in the hi/low voltage values into TS that the lc1 manual stated. Both are spot on now.
I thought the 2nd output on the Lc1 was just a narrowband out? Is this configurable?
Posted: Oct 05, 2010 10:04 AM
by M. Holtmeier
Nebraska_e28 wrote:I thought the 2nd output on the Lc1 was just a narrowband out? Is this configurable?
Both outputs can be changed. Give me a buzz if you need a second pair of eyes/ears to get that thing tuned in.
Posted: Oct 05, 2010 1:07 PM
by slammin_e28
Sub'd 4 pics and future ref!
Posted: Oct 05, 2010 1:37 PM
by Nebraska_e28
M. Holtmeier wrote:Nebraska_e28 wrote:I thought the 2nd output on the Lc1 was just a narrowband out? Is this configurable?
Incoming.
Posted: Oct 05, 2010 3:39 PM
by Nebraska_e28
10/5/10 update
I'll get a pic up sooner or later of things being cleaned up slightly. I fully understand now how making 1 part of your car look good brings out how bad the rest looks.
I'm running bille sports w/spax springs & was on the 2nd to lowest perch. I switched tires from Potenza re050a 255/40/17 to a Sumitomo htz III. I think the htz's have a slight wider sectional-cross-width & there was just a hair of rubbing on the driver side (typical). So I raised the rear up a bit from the 2nd to lowest perch to the 4th. This gained about 1" of height & stiffened the rear up even more. No rubbing now, though I think the car may have rode just a tad bit better having a flat stance. Still early to tell.
I've been playing with the tuning side of things trying to "self-teach" myself. There's a heck of learning curve, but I'll get there. Yesterday took the car out for it's first drive (longer than 2 blocks). Went about 15 miles trying to feel things out. Very VERY light on the boost here & there since I'm not ready to blow things up yet. It made the brief flight. Nothing fell off, broke, burned up or croaked. Not too bad eh? Granted I was slightly under speed limit feeling the car out.
Couple of things learned.
I now know what
slight detonation sounds like under boost & and have no intentions of making repeat performances.
Though a blowoff valve would be a cool novelty, I'm digging the swoosh of the bypass valve. I can see where this would come in quite handy in avoiding some "revenue generators" with red/blue lights.
After being on pins & needles just making a 20 mile round trip drive, I gotta wonder how I was gonna have kahunas big enough to drive to the last 5erFest.
There's a new need for me to re-learn how to drive an automatic. I have a new found anxiety of punching it & it down shifting from 4 to (something to low) hence immediately blowing shit up. Guess I'll have to play with the kickdown a bit.
There's a direct mathematical proportion increasing RPM near 2500ish to Holy $hit levels.
A fast car can make you more mindful of the speed limit, more or less.
Posted: Oct 13, 2010 12:06 PM
by Nebraska_e28
Posted: Oct 13, 2010 12:14 PM
by T_C_D
Awesome! Automatic, loose converter and boost is really awesome!
Posted: Oct 13, 2010 12:31 PM
by skip535i
Where did you get that wicked-awesome gold valve cover??
Posted: Oct 13, 2010 1:01 PM
by cvillebimmer
Wow! That looks fantastic. At first glance I thought the color of your valve color was "cosmoline."
Posted: Oct 13, 2010 1:58 PM
by M. Holtmeier
Man that is looking good. I'm jealous of your chrome strut bar.
When are turning that thing up?
Posted: Oct 13, 2010 4:23 PM
by JesterMX6
what is the old license plate shielding under there?
Posted: Oct 13, 2010 5:01 PM
by Nebraska_e28
T_C_D wrote:Awesome! Automatic, loose converter and boost is really awesome!
skip535i wrote:Where did you get that wicked-awesome gold valve cover??
And you probably thought it'd never get used.
Came in handy after all & looks pretty darned good, or at least I hope I do it justice.
cvillebimmer wrote:Wow! That looks fantastic. At first glance I thought the color of your valve color was "cosmoline."
Camera phone pics suck.
M. Holtmeier wrote:Man that is looking good. I'm jealous of your chrome strut bar.
I'd love to turn the boost up but there's a few things I'll probably address first to maximize efficiency at 7.5psi.
1. I need to get my radiator shroud/shelf installed. Hopefully this will aid in airflow through the HE & radiator.
2. IIRC we were seeing IAT of 140 degrees under sustained boost. That sounds like somewhat of the norm, but I'd like to see a sizeable drop. Is sub 100 too much to ask?
3. The intake charge pipe needs to be sealed off from sucking any air from the engine bay.
4. I'm still clueless at this whole map thing & will be bugging ya soon for more insight.
5. Electric fan is a must! Now that I have the engine temp gauge mounted I see the temp sits around 195 average. My goal here is to hover in the 185 neighborhood.
I have a few other tricks up my sleeve & probably a few I'm forgetting but am hoping all of this will gain some additional HP. Trying to get the most bang for my buck!
JesterMX6 wrote:what is the old license plate shielding under there?
That's called the "I need 1 more piece to get this damn thing on the road" shield!
Posted: Oct 13, 2010 6:36 PM
by George
I'm not running a shroud and I routinely see about 175F.
Your IATs are going to be dependent on a ambient. I generally see about 15-20F above ambient. Although, like Mike, I've upgraded just about all of the system.
Have you made sure the intercooler system is properly bleed?
I recommend these two books for the basics on MAP based tuning (although they cover a lot of the same material)
http://www.amazon.com/Designing-Tuning- ... y_b_text_b
http://www.amazon.com/Engine-Management ... y_b_text_c
Posted: Oct 13, 2010 11:13 PM
by Nebraska_e28
George wrote:I'm not running a shroud and I routinely see about 175F.
What are you running for a HE or HE's? 15-20F above definitely seems acceptable in my book! When we saw it hit 140, I think ambient was around 75ish outside at night. I'll let Mike chime in if he thinks different.
After the install I ran the intercooler pump & checked the water level in the IC, then topped off. Since then I've checked the level periodically. I suppose I should pop the screw from the tank & do a visual there also. Is there some additional process I've skipped?
Posted: Oct 13, 2010 11:18 PM
by George
Nebraska_e28 wrote:George wrote:I'm not running a shroud and I routinely see about 175F.
I'm currently using the Bosch cobra pump.
Part#: 0392022002
I'm using a custom set-up on the heat exchanger. modified an all aluminum Honda Civic radiator. Lots of surface area and plenty of capacity. I cut off the existing end tanks and made my own. I then welded on -10JIC Male fittings for the lines.
I have removed all of the A/C components though.
Make sure you you use the bleeder screw on the reservoir to get an air pockets out of the system. 65F above ambient is too high for a low boost system. I don't think you are getting full circulation of the water.
Posted: Oct 22, 2010 3:30 PM
by Nebraska_e28
I did check the system & it didn't need to be bled, was still full. Guess it's e-fan time to tame things a bit. By the way if I didnt mention, I'm running a new t-stat, newer radiator & water pump (3 yrs/old).
Today I tipped over 1000 boosted miles & everything is still running great. Not to forget a tune that Mike was able to put together in maybe 2 hours or less!
No broken parts or major leaks. All this on a motor that's probably in the neighborhood of 230k+. Hopefully that will all change over the winter but for now I'm having fun & being lazy about doing any upgrades.
Next major step now is to graduate from my FI embryo state in tuning.
Will be doing a cozying up over the next week or so with my latest investments...
Posted: Oct 23, 2010 1:22 PM
by JesterMX6
yep. i have that first book. great read.
Posted: Nov 08, 2010 11:20 AM
by Nebraska_e28
Posted: Nov 08, 2010 11:33 AM
by tsmall07
Looks like a solid install. Can you remove the fans without removing the radiator?
Posted: Nov 08, 2010 11:38 AM
by M. Holtmeier
"Recovery Vehicle."
Posted: Nov 08, 2010 12:11 PM
by Mr Project
Fans look good! Details on what they are/where you obtained them?
I have a 16" electric on the E23 and wish I had gone with two smaller units for space considerations...it is TIGHT.
Posted: Nov 08, 2010 12:51 PM
by Nebraska_e28
tsmall07 wrote:Looks like a solid install. Can you remove the fans without removing the radiator?
Honestly I'm not sure, but I probably can remove the whole radiator in less time. It is quite a bit easier to get at that "pain-in-the-azz" bottom radiator hose clamp.
Mr Project wrote:Fans look good! Details on what they are/where you obtained them?
I spent the last 2 years studying
Mike's notes before I pulled the trigger. The fan's can be had on Summit racing, or do like me, print out their price, take to local auto store & have them price match, then use $ saved for bottle of Jack Daniels
It sucks that I wasn't able to make street night at the 1/8" mile strip last friday. From what I understand they are shut down for the year, so no breaky break for me till 2011.
Posted: May 05, 2012 4:53 PM
by Nebraska_e28
Posted: May 09, 2012 6:55 PM
by Mab1957
How is that Hobart 140 working for you? Keep posting, this is very interesting to observe.
Posted: May 10, 2012 12:06 AM
by Nebraska_e28
Mab1957 wrote:How is that Hobart 140 working for you? Keep posting, this is very interesting to observe.
So far working great! Prior to purchase I also researched Miller & Lincoln. Then I went to a local exhaust shop. The owner has been using a Hobart regularly for 8 years with zero issues. I was sold.
Posted: May 13, 2012 6:50 PM
by Nebraska_e28
Posted: May 14, 2012 8:22 AM
by Bill in MN
Nebraska_e28 wrote:Mab1957 wrote:How is that Hobart 140 working for you? Keep posting, this is very interesting to observe.
I've got the same welder and love it. It's done several car projects and gets used most every day. Worth every penny!
