Jeremy wrote:There's no need to modify anything. Get the cap from a 2 light e21 and you'll have all the connections you need. I have a pair sitting around somewhere . . .
Jeremy, what's the chance you STILL have a pair sitting around somewhere and would be willing to sell them?
Would anyone know the part # for the E21 cap. Is it the same on ALL E21s?
Nope, that's not it. That's a 4 headlight e21. The 2 headlight models were the lower end euro models, such as the 315 and 316. I believe it's part # 63121358819, Covering Cap, #11 on the diagram as seen here: http://www.realoem.com/bmw/enUS/showpar ... Id=63_0023
Unfortunately I don't remember where mine wound up. They're probably in storage, and I don't know when I'll be able to get over there to look.
Thanks for the wiring info for Euro lights. I looked at another method that required rewiring at the fuse box .. I sure wasn't comfortable with that.
In your description you show putting a female connector in the housing with a wire that you say goes through the black plug. I don't understand that - is it to make an electrical connection in the male plug? Or where is the wire going?
