[QUOTE="345is"]Just so you know, You can spend all the money you want on doing head work and and other mechanical internals, that wont do much when your turbo cant support more than say 320 whp. try this put a bigger new style turbo on your m106 and I garantte you that you will be blown away with the power. Oh and by the way if you raise your compression you will not gain hp, you will loose hp. and also retarding the timming to much will indeed raise your exhaust temps![/QUOTE]
Hu,
Raising compression 1pt will not make the system lose power, it'll only lose power if you don't properly adjust the timing and boost to compensate for it, and use the appropriate fuel quality. Raising compression will increase power output for a given air volume, I beg to differ. Just using the formula here, with explanation:
All motors have a static compression ratio. This is the amount that the air inside the cylinder is compressed. It is a ratio of the cylinder volume at BDC to the volume at TDC. When a supercharger is added, additional air is forced into the cylinder effectively raising the compression ratio. The result of this is called effective compression. The formula for finding the effective compression is very easy: ((boost psi / 14.7) + 1) x motor compression = effective compression.
So, if you agree with that, motor with 15psi and 8:1 compression has an effective CR of:
((15/14.7)+1)x8=16.16
Working the formula to now find psi needed to make the same power with 9:1 CR:
((x/14.7)+1)x9=16.16 gives a new psi of 11.7psi.
The air flow rate does not change for this formula to work, the turbo is putting out less air going from 15psi to 11.7psi. The mixture is compressed further with higher compression, giving a BMEP higher with the same air flow. Andrews E34 with the M30b35 easily make 360whp with 12-13psi and 9.2:1 CR. And that engine isn't way different than the M106. Well, I guess it is a little bit....
But with the stocke M106, your still need the appropriate fuel/ingintion upgrades.
I don't have the CR formulas right in front of me to calculare the torque increase for a given system ie air flow vs CR. But that is a fact, we all know this. Now, heat is increased, so you need to compensate for that, even using the above formula and boost with better ICs, better fuel/ingnition management.
I also disagree with your very first statement, that all the headwork and internal mods won't make a stock M106 make more power. What are you basing that statement on?????? The system with all those mods will make more power as your raising the VE of the engine, this is essensially free power, as it was always there, your just realesing it now to be realized. Like Jesse said, the Porsche guys are getting 400hp crank, now granted the Porsche engines are better at making top end power, so it's a little easier. Bit its still there.
Anyway, theres my take, its still MHO that it's not the k27 thats liming you to 400 crank, its the engine, IC and ECU.
RussC
