off to the scrapper tomorrow - part out 1986 535i Running/driving
ThisOldJeep
Re: Complete part out 1986 535i Running/driving
Tried PMing I guess it didn’t take.
Curious about the trunk lid - cost, condition.
Theotherotter
I'm interested in one an antenna if you have one (the mast is broken off on mine) and maybe a RF window regulator and a sunroof motor too, if they work. (My sunroof works, but it's slow and I haven't diagnosed it yet). I just joined (I just bought an E12) - I can't PM you, so I'm not sure how to reach you.
The antenna mast can be purchased separately. OEM is very expensive but there are aftermarket options that are less costly.Theotherotter wrote: Jun 28, 2023 11:24 AM I'm interested in one an antenna if you have one (the mast is broken off on mine) and maybe a RF window regulator and a sunroof motor too, if they work. (My sunroof works, but it's slow and I haven't diagnosed it yet). I just joined (I just bought an E12) - I can't PM you, so I'm not sure how to reach you.
I've sold al the window regulators and an keeping the sunroof motor.
Put a WTB (want to buy) post in the parts sub forum, you should find what you're looking for.
Theotherotter
Thanks for that - always happy to know I can just replace the mast.
B pillar covers ok?
No, but I have 2 that are in very good condition. They don't have the seat belt bottom plastic trim.
Shoot me a PM, with contact info, I'll send images.
Punnzzells
Chimi-Changa
Long shot....Hows the passenger rear door rubber widow guide?
Yeah, regret but I'm keeping those.
calspyderman
I need right (passenger) side rear door? Is it available and condition please? Feel free to PM me.
Thanks.
Thanks.
SpruceBringstien
Heyo, looking for a complete engine wiring harness, willing to pull and how much, if yes?
s
s
Sorry, I'm keeping that as a spare.SpruceBringstien wrote: Jul 20, 2023 2:48 PM Heyo, looking for a complete engine wiring harness, willing to pull and how much, if yes?
s
ThisOldJeep
How about a fuel tank? As in one without rust inside it?
Have it, shoot me a pm.
Do you have the instrument cluster?
Car is a 1986 535i with 175K miles, life long CA car.
https://drive.google.com/drive/folders/ ... share_link
Cosmos Blue / Blue interior
Interior is rough, the only parts worthwhile are the center console + HVAC surround, glove box, front Black seats (I need the manual bases)door panels, door caps may be good. It's been pouring rain here and I really haven't had a chance to dig into it.
Good running 3.4 engine with a DOT R head.
Complete 5 speed conversion
Rust free doors/sunroof panel/trunk lid
Full key set with locks
3.25 LSD
Manual conversion- Starting from the front…
Good manual radiator
Getrag 260/6 + all the hydraulics, lines, new brake master cyl & fluid reservoir, clutch master cyl w/ hard & soft lines, clutch slave.
Flywheel, pressure plate, clutch. Clutch feels really good and engages well.
Pedal bracket W/pedals
Shifter carrier & shifter (needs a rebuild) but it’ll be out of the car.
Drive shaft (recommend a new guibo & CSB)
Still in the car if you’re local and want to see the car running/shifting into gear.
Car is located in the Bay Area (94587)
[/quote]
3.25 LSD
[/quote]
Do you have the instrument cluster? 5179143753
It sold a while ago.
alexjcowan
Assuming the engine and trans are gone?
Fanclutchnut
Do you know if this car has the molded padding/insulation that is separate from the carpet?
Both are long gone.
Re: off to the scrapper tomorrow - part out 1986 535i Running/driving
How will it drive to the scrapper w no engine and transmission? I'm guessing a can of starting fluid.
Are the hood latches available? I'm looking for a full set, so the pieces on the hood and the receivers on the body.
PM's looking for the upper trunk latch that attaches to the underside of the trunk lid
Hood has soldEuroShark wrote: Aug 02, 2023 2:49 PM Are the hood latches available? I'm looking for a full set, so the pieces on the hood and the receivers on the body.
Sorry, the complete key set was pulled for someone else.gwb72tii wrote: Aug 02, 2023 8:32 PM PM's looking for the upper trunk latch that attaches to the underside of the trunk lid
Yes, long gone.
