Mike W. wrote:
I don't think so. My experience on M30s is that it's just a simple switch that tells the ECU to return to idle speed, can affect idle quality and dying when coming to a stop particularly with the A/C on, but doesn't affect idle speed. It's a simple make at idle, break just off idle, then make on a different contact on WOT, but does nothing in between. The idle side will also cut fuel off above about 1300 RPM. But testing is simple enough too.
What does it feel like, engine speed wise? On my 535 it showed about 650-700 at idle, but when doing smog tests it was always a bit over 800. Also if they tried to do a 2500RPM test using the tach it would fail because they weren't within the allowable range of engine speeds.
My car has the M20. Does what you're saying apply to M20's as well ?
And as far as feel, ever since i put the new sensor in, the car pulls a lot smoother. It pulls all the way to 4-5k rpm no problem and comes back down without stumbling (not that it did that before). My only issue is that now, itll rest at 1000 RPM's. Dead even. Smoothly.
ahab wrote:Do you have a copy of the ETM? It just occurred to me that you can disconnect the ECU connector to test the TPS there, and maybe avoid all the pain of removing it just to test. Ideally you'd want two people but I suppose you could use the accelerator pedal to open the TPS. If you need the ETM, search for posts by user "a", he has a link in his signature. Then look up the pinouts for the TPS in the Injection Electronics section and test the pins at the ECU connector instead. If it passes the test you can rule that out. Congrats, you're getting closer. You should also check for vacuum leaks, those are a great source of high idle problems.
I dont have the copy of the ETM. I'll search that user up to see what information I can gather. As for "testing the pins at the ECU", can you tell me what i'm testing for? Continuity?
