As Chris stated they are still available from a couple of sources. I bought a set from PMB and the other came in a centric brand rebuild kit from Amazon.Burnze wrote:skylere28 wrote:Just curious, when you split those calipers did you just reuse the rubber seals you find on the inside of the caliper? Just wondering since those seals are N/A now days and I have had the issue of finding those seals or and now replacing to e32 fronts.
I found differences between them though.
Here's the PMB seal.
Well hot dam! Sweet means I'm going to rebuild mine too then! I'll have original M and now e32 fronts as well, thank you very much for that small piece of info that just made my day! Cheers
