The Fleet (SFW)
Re: The Fleet (SFW)
bravo!
Re: The Fleet (SFW)
Uglina's back!
Recap:
- Purchased in 2006
- Refurbished as my first real 'wrenching adventure' through 2013
- Solid her like an idiot in 2013, but kept in touch with buyer (Houston, TX)
- He sold it back to me last spring and I have it in Utah so I can play
1978 Toyota Land Cruiser FJ40 in Mustard Yellow. Mostly original. Build thread on ih8mud.com here:
https://forum.ih8mud.com/threads/uglina ... ead.79672/
I'm going to avoid commenting on the shop that did the work until I'm 100% confident in the results. However, I can say that after a 15 minute freeway drive from the shop to my place of work the key stuff feels great. Here's a summary of what has been done since Uglina went under the knife starting last August.
I realized I haven't posted the story yet, so here's the deal:
After driving her last spring I found drivability to be a real problem. The biggest issue was the carb. Whether it is the higher altitude of Salt Lake City vs. Seattle, or the additional miles and patina since I sold her in 2013, she just wasn't running well. It all came to a head when she simply died on I-80 outside of Park City and I had to get a tow truck. In addition the steering had gotten much sloppier over the years. The CCOT "mini truck" power-steering setup that was installed in the early 1990s was poorly fabricated from the get-go and just tired. Finally, smell of hydrocarbons (which is normally something I love) had either increased or I have just grown up. Either way, I felt I needed to clean this up if I was going to be driving it a lot. It was important that my wife would not be disgusted riding in or driving the rig ;).
I debated how far to go, recognizing that I don't have the facility to do any real work myself here in Utah (until our home here is completed). I talked to multiple shops and got lots of options and rough estimates. These included building/buying a 'built' 2F, going the V8 route, going with a Cummins R2.8 crate motor, and just extending the life of the original 2F with either a Holly or FiTech EFI unit. In the end, I decided my tenet would be
"Stay mostly stock, but make it reliable; bet on the 2F having many miles left in her. Avoid going down the cosmetic rabbit hole; prepare to drive her into the ground for a few years so an full frame-off restoration makes sense."
This led to the EFI solution and it was a toss up between the Holly Sniper or the FiTech. The shop I choose had experience with Holly so that sealed the deal.
I also decided the only way to fix the CCOT hacked-up-power-steering system was to rip it out and do it right. Right or wrong, I decided the "right" way to go was to do the FJ60 route after seeing several rigs with that conversion.
Finally, because I plan on actually adventuring out into the Utah wilderness now, I wanted SOME recovery options, so I decided to add a winch.
  • Holly Sniper 2300 EFI - Replaces carb; self contained and looks almost-factory once installed.
  • Mosley motor in tank fuel pump weld in ring
  • TRE in-tank fuel pump
  • Red Horse black anodized A/N fittings
  • Reed Horse -6 black braided high pressure fuel line
  • Mosley motor aluminum factory air cleaner adapter
  • Red Line Cruisers throttle cable bracket
  • Steering box rebuild seal kit form Cruiser Outfitters
  • Steering pump rebuild seal kit for Cruiser Outfitters
  • Air pump delete idler pulley from Spector Offroad
  • EGR block off plates-made in house
  • Ssteering shaft- made in house with Borgison 36 spline joint at box keyed joint from fj40 at top end
  • Column bearing kit from cruiser outfitters
  • Fittings for box made at House of Hose
  • All steering joints are 555 from Cruiser Outfitters
  • Steering tubes are OEM fj40/fj60 mix
  • HFS front bumper from cool cruisers of Texas - warn 8274 ready
  • Toyota battery
  • Tesco tape for under hood wire protection
  • Exhaust Generic Master muffler - quiet/stock series muffler
  • OEM Toyota ignition switch from cruiser outfitters
  • Warn 8274 winch
  • Adjusted shifter to not be so far forward (I had previously adjusted it too far after installing the center console ages ago).
  • Ripped out stereo amp under seat, new Continental head-unit with bluetooth and built in amp.
  • Toe kick seals
  • R&R headlight switch
  • LED knob/dash lights
I am going to drive it today & tomorrow and then get it back to the shop Friday to have the winch installed. More to come... Great to be back (again).
Re: The Fleet (SFW)
Yesterday afternoon I had one of the most fun "shakedown drives" ever.
I wanted to exercise the rig at altitude, ensure it worked well in traffic, and see if I could get off road a little. I succeeded on all fronts.
She drove great. I have a minor punch list of things to fix, but so far I'm very pleased with the investments I've made upgrading both the steering and engine. The Sniper 2300 EFI is still in learning mode and I'm not sure it's quite right yet (a little rich), but I had no issues driving up to Alta. Once up there I saw the sheriff and asked if he knew of a trail I could go on to quickly shake her down off road and take some pics. He said "follow me!". Yes!
Here's some pics for y'all to enjoy and comment on.
knunger
Re: The Fleet (SFW)
Post by knunger »
You have impeccable taste in window stickers Charlie:
ImageDSCN0582 by Kim Unger, on Flickr
Hffvdbl
Re: The Fleet (SFW)
Post by Hffvdbl »
Ugly a looks fantastic. I’ve always loved that color. Thanks for sharing.
Re: The Fleet (SFW)
She's back (again). For the past two weeks the shop has been tackling a healthy punch list:
  • Fixed Fuel smell. Install an active vent/charcoal system.
  • Running rich; Smells rich. AFRs low.
  • TPS never shows more than ~60%. According to docs WOT requires above 90%
  • Fixed Charging system
  • Turning on headlights causes head unit to power cycle
  • Parking brake light flakey
  • Steering wheel is not straight
  • Tick at idle. Exhaust manifold not tight.
  • Cig lighter socket inop.
  • Right front caliper smoking when hot. Sticking. Replaced.
  • Add Rear hitch receiver
  • Add a 12v, switched cig socket behind dash. Plug usb-c adapter that's in car in, and fish wire through little hole by phone mount. "
  • Install Warn 8274 winch
  • Radiator pin-holes. Replaced radiator.
I picked her up yesterday and drove hard. Hard enough to cause one of the speakers to break from it's (lame) mounting. Tee-hee.
Found a few more issues that I'll really need to address before I can declare this phase complete, but none are major (fuel gauge stopped working, heater fan inop). I'm loving driving her around (and looking back after parking).
Next up is some heavy duty work on the paint. I want to preserve the current patina as much as possible so I'm going to do a polish and protect with ceramic.
Re: The Fleet (SFW)
Back in Seattle, I have finished putting the doors on the 911 back together. The project started with the passenger inside door release not working. It lead to me discovering the passenger door had been replaced (on a car that I bought with 6800 miles on it 23 years ago; I've always believed the car was pristine. Bubble burst.)
Feels good to have that episode behind me.
She was so dirty, I just had to wash... tee-hee.
Zengineer
Re: The Fleet (SFW)
Post by Zengineer »
That's quite the wash rig you've got there - what type of filters are in the big blues?
Re: The Fleet (SFW)
Zengineer wrote: Sep 06, 2020 11:44 PM That's quite the wash rig you've got there - what type of filters are in the big blues?
The spotless water treatment system is www.crspotless.com. Only H an 2O comes out. No need to dry cars. Love.
The pressure washer is https://www.kranzleusa.com/.
The stand is by cek.
Zengineer
Re: The Fleet (SFW)
Post by Zengineer »
cek wrote: Sep 07, 2020 11:39 AM The stand is by cek.
Would have expected some nice powdercoating, zinc plating and new chrome on that... :rofl:
Re: The Fleet (SFW)
Zengineer wrote: Sep 07, 2020 12:34 PM
It's in the plan, but I wanted to make sure it was right. Plus I have my welding cart to powder coat too. I was going to do them together someday...
Re: The Fleet (SFW)
I was able to pick Uglina up a the shop Monday afternoon.
Since the last report here's what we've done:
  • Polished paint and professionally ceramic paint treatment to bring out the shine and prevent further oxidation/patina (by Dusty @ Envision Detail in Salt Lake city; class-act and very good).
  • Remounted speakers
  • Attempted to fix PS belt squeal (not fixed)
  • Really fixed fuel smell? - Changed out check valve, re-did fuel hoses (all vent lines with new clamps), fixed cracked plug on fuel tank line, removed the VSV valve from between canister and manifold, swapped vacuum line from charcoal canister from throttle body to correct port on intake housing.
  • Fixed leak in EGR block off plate - billet EGR block off plate.
  • Replaced ammeter - now working correctly.
  • Found and reattached cap for transfer case knob.
  • Replaced screw in bezel.
  • New wipers.
On Tuesday I went for a drive up Little Cottonwood Canyon because it was snowing. I've actually never driven this rig in the snow and was a little nervous about the tires since they've been on her since 2007. They were fine. I know technically they are too old, but they show no signs of rot and only have about 6,000 miles on them. Plus, I understand you can't actually buy 33x9.5x15 BFG ATs anymore and I love the tall/skinny look! The weather provided for some pretty good photos; too bad I didn't have a 'real' camera.
The shop damaged the left front fender previously and had it repainted. The paint does not match. They've agreed to fix it correctly and I'm going to have the rust on the passenger door fixed and it repainted because it just needs to be done. I will drop her back off at the shop Friday...
Pretty safe to say Uglina likes Utah. And I like having her back. I'm excited about being able to wrench on her myself in a few months when the house is done and we're out of the apartment.
New list of to-dos:
  • Driver's side defrost vent always blows cold. Passenger blows hot when DEF is on. How could that be?
  • I've not played out winch and re-wound it yet (you are supposed to this according to the manual).
  • Re-do door seals (I put gaskets in in 2006-7 and didn't do a great job and a few are loose).
  • I think one of the speakers' cones is bad as I get distortion sometimes.
  • Figure out a different mount for the Holly Sniper LCD; that's where my phone goes.
  • Fix Alternator/AC belt whine
On the last one, this truck has done this since I got it in 2006 (to some degree). We suspect it is do to the belt not getting enough wrap around the AC compressor. Thoughts?
travisj
Re: The Fleet (SFW)
Post by travisj »
Fucking Fantastic FJ Fcharlie!
Looks right at home in Utah!
RoyW
Re: The Fleet (SFW)
Post by RoyW »
Simply awesome Charlie! Love them all.
-RoyW
Re: The Fleet (SFW)
I finally got all three E28s together for a photoshoot. I had fantasies about doing this in some spectacular location, but in the end, I ended up doing it quickly the morning Minerva was to be shipped to Utah. I am a master of procrastination.
muleskinner
Re: The Fleet (SFW)
Post by muleskinner »
What do you mean you were looking for a spectacular location? That is a spectacular location. Also, some spectacular cars.
Re: The Fleet (SFW)
Gorgeous pictures, location, and E28 fleet.
dsmith
Re: The Fleet (SFW)
Post by dsmith »
Amazing! The amount of work on those 3 cars is not let down by those pictures.
Re: The Fleet (SFW)
:rofl:
Bonsaibacker
Re: The Fleet (SFW)
Post by Bonsaibacker »
True eye candy!
Re: The Fleet (SFW)
Helga, the 2010 Audi Q7 and Deiselgate victim, continues to be amazing at 105k miles. Just drove her round trip from SLC to Jackson Hole. Here she is all cleaned up afterward.
muleskinner
Re: The Fleet (SFW)
and people wonder where that huge kidney grill on new bimmers came from.
Re: The Fleet (SFW)
Uglina time!
She's back from the shop. Again.
I'm happy with the paint now. My ceramic guy (Dusty at Envision Detail) has offered to re-coat the door and fender and I'm grateful for that.
While it was there I had them install a Kioto headlight kit.
We figured out part of the defogger problem: The hose connecting the heater box to the vent was FUBARed. With that fixed, we thought all would be good. However, the amount of hot air the blows out the top is about the amount you'd expect a baby butterfly to generate. I know these things were never great, but there should be more air. In Vent, there's tons of flow but almost none in Heat or Def. The output of the fan seems strong. I suspect it is either the fan or the resistor pack at this point. Any insight?
We also discovered the hoses from the heater to the dash are pre-78 and don't have connections for the side window vents! Are those parts still available somewhere as I'd really like to have those vents work?
Hit a nice "mile"stone driving around today:
But, best of all, I got some more great snow pics and *had* to put her in 4H ;)
Love.
Still to do:
  • Re-do door seals (I put gaskets in 2006-7 and didn't do a great job and a few are loose).
maybeillbuyit
Re: The Fleet (SFW)
Post by maybeillbuyit »
This constant posting of pics of that FJ40 is going to cost me money. A friend of mine who is from Brasil and spends time there, imports Land Rover Defenders and can get cheap probably clapped out FJ40s and the like. These pics are pushing me to make a grave mistake in my pursuit of more rusty stuff I don't need. :laugh: More please!
Re: The Fleet (SFW)
Hmmm... Didn't quite line it up right. Will try again tomorrow.
gray635
Re: The Fleet (SFW)
Post by gray635 »
I just stumbled up on this CEK car porn post. What cars!!! :shock: Well done, sir! Three beauties. And what great photography - even if it is a bit of photoshop magic. This doesn't look like middle GA to me. :laugh:
e28Sean
Re: The Fleet (SFW)
Post by e28Sean »
cek wrote: Oct 10, 2015 6:42 PM Image
I cannot get over how well the E28 wears that color.
Re: The Fleet (SFW)
I'll use this thread to post an update on life.
The last 16 months have been pretty life-altering for me. The upshot is I am now:
1) Single
2) Homeless
3) Unemployed
All but the first was what I wanted. But now that it's true, I'm completely embracing it. I'm currently on what I call my "new life walkabout" which means I'm away from my cars. Except for Minerva and the Tacoma, the whole fleet-and-kaboodle, including all my tools, are in storage near Seattle. The Tacoma is being useful to my kids and friends in Seattle, and is what I've used for getting around Seattle while there. Minerva is at Carbahn in Northern CA...why is a long story that I'll tell once I know for sure how it is going to end; let's just say for now that I'm getting free storage.
Just to put some flavor on my walkabout, here's where I've been since early Sept 2021:
- Montana (pheasant hunting)
- Reno (I drove Minerva from Seattle to play with a bunch of dudes I met on the Internet)
- Portugal
- Houston (again to thang with a bunch of dudes I met on the Internet)
- Across the US SW in my daughter's sprinter van (NV, CO, NM).
- Belize/Costa Rica/Columbia
- Tucson (quail hunting)
- Across Colorado skiing (Steamboat, Vail, Aspen, Purgatory, Silverton, Wolf Creek)
Now in Europe... and the reason I'm posting in THIS thread:
After many years of lust, I finally added a Defender D110 to my fleet. His name is Mario - named Ivo's 4 year-old son.
I've been planning a long European ski trip this Winter and a driving trip through Southern Europe in the summer. Plus there's a potential I will be working/living in the Netherlands (I'm nominally from the Seattle area). Instead of renting an SUV for this epic ski trip, I decided to go big and just buy a used Defender. I considered a 25+-year-old D110 that could come back to the US with me, but I realized I really wanted the creature comforts of a later model (2007+). If I end up living in Europe then I'll keep it. If not, then after my European travels are over later this year I'll sell it.
I found my dream rig on an online sales site in NL and Ivo graciously did the inspection and purchased it for me. Last week I landed at AMS and hung with Ivo and Tim and Francis and Ingrid and did a stereo upgrade, ate stroopwafles, and drank Dutch bier. I also had Ivo's mom's home-cooked meat and potatoes. I've been driving around Holland for the past week getting used to Mario and having a blast. It's everything I hoped it would be.
Details:
2009 Land Rover Defender D110
Tamar Blue (code 817)
Trim: T (anyone know what this means?)
Originally sold in Italy and imported to NL last year.
95k km on the clock (I've put almost 1500 km more on it in the past week!)
Pr0n:
Cheers to all of you and sorry I've been AWOL. I am planning on going to The Vintage in May...
knunger
Re: The Fleet (SFW)
Post by knunger »
Why does NONE of the above surprise me?
I've known you to be a different breed of cat since the day I met you. We'll miss you at StPaddys day next month. Hopefully our paths will cross again...
Good Luck and God Bless!
Re: The Fleet (SFW)
Thanks Kim.
Guess who I just ran into at the Hamsterdam Airport? @motronic!
